Question about As Seen On TV Handy Stitch Mechanical Sewing Machine
Handy Stitch sewing machine
Hi
I hope you can help me, I don't know how to change the needles in the hand held sewing machine
  • 1 more comment
  • breezy23 Jul 27, 2008
    i cant thread my handy stitch correctly. every tine i try to stitch something it doesn't work
  • shutakeke Jul 30, 2008
    need instuctions for As Seen on TV Handy Stitch Mechanical Sewing Machine.
  • marvannclink Apr 04, 2009
    I ordered this handy stitch sewing portable sewing machine how do you operate it. Is this a joke?
    [email protected]
    How do you make it sew?
How do you thread and use the Handy Stitch?
Posted on Jun 26, 2008
I cant sew i try and do all i can i just seem not to get it to work.
Posted on Jun 13, 2008
SOURCE:
Tip
Sewing Machine Needle Guide (Schmetz)
Want to know what sewing machine needle to use? Here's a handy guide.
http://www.schmetzneedles.com/learning/pdf/schmetz-needle-chart.pdf
Change your needles frequently. If you are experiencing problems with your stitch, the first thing to do is change out the needle. Needles get damaged and worn over time and are frequently the cause of stitching problems. Needles are the least expensive repair cost on your machine, so don't spare the expense!!!
on May 20, 2015 | Sewing Machines
Where do i get the needles with out getting them on line
How many. Do u need
Have them in stock
Call Wedtern Canada. Wayne
403 529 7965 moment singer dealersay have them in stock
Apr 05, 2015 | Singer Handy Stitch Hand Held Portable...
My machine turns on but it doesn't actually sew. The needle just pokes holes in the fabric and I don't know how to fix it
Is the bobbin full of thread, and is the needle threaded?
These are very inexpensive machines; some will only sew with what is in them when delivered, then you buy another. :-(
Mar 15, 2015 | Singer Handy Stitch Hand Held Portable...
What is the difference in the length of the needle on a "handy stitch" as opposed to the "stitch sew quick machine?
Check your manual for the "System" of needle
a normal sewing machine needle has a "System" or dimension
called 15x1 or 705 H. That indicates the length, the circumference
etc. If the needle you received with the machine is the same length as the above system then you should be ok. Also most often the needle package for most machines will be labeled "Universal"
Aug 04, 2014 | Singer Handy Stitch Hand Held Portable...
How do i thread my needle with the singer handy stitch?
  1. Loosen needle screw & insert needle with shank's flat side facing front of machine. Push needle in all the way, then tighten screw to hold needle in place.
  2. Install a fully wound bobbin by loosening bobbin nut & placing bobbin on top. Re-attach bobbin nut & tighten. If standard thread spool will be used, then attach spool pin to bobbin shaft & place thread spool onto shaft. Attach white spool cap on end of thread spool, then tighten. Bobbin/spool should unwind facing forward toward needle.
  3. Bring end of thread through thread guides & over tension control. Pass end of thread through needle eye, from back to front, & pull it out about two inches.
  4. A spring pushes pressor foot onto fabric that is being sewn, so lift pressor foot & place fabric underneath.
  5. Turn large handwheel on side of machine (handwheel can be turned in either direction) to raise needle arm to its highest position.
  6. Holding the Handy Stitch in place with your right hand, press on power switch & begin sewing. Guide fabric (being sewn) with your left hand.
  7. To end this sewing session, turn off power. Turn handwheel to raise needle to its highest position. Carefully pull out about three inches of thread through needle & snip, then lift pressor foot to remove fabric. Turn fabric over & loop needle threader through last stitch. Place end of thread from underside through eye of needle threader, & pull to loop through. Pull to tighten and snip end of thread.
Nov 11, 2010 | As Seen On TV Handy Stitch Mechanical...
Stitch unravel
Try changing the needle it might be dull
Feb 16, 2009 | As Seen On TV Handy Stitch Mechanical...
As Seen On TV Handy Stitch Mechanical Sewing Machine Logo
817 people viewed this question
Top As Seen On TV Sewing Machines Experts
Harjeet Singh
Clive
Clive
R.A. Ellis
R.A. Ellis
Are you an As Seen On TV Sewing Machine Expert? Answer questions, earn points and help others
