Question about Canon PIXMA MP510 All-In-One InkJet Printer
Error 5100 printed a photo on paper after error 5100 showed up.
  1. check the user manual if you had one for that error code,
  2. and I suspect the ink level of your printer,
  3. and also check if there is any paper jam exist,
  4. disconnect the power source for 2 mins and turn on again.
  5. try to print again.
Posted on Apr 07, 2008
SOURCE:
Canon pixma mg2120 error 5100
I just bought this Canon PIXMA MG2120 PRINTER about 2 weeksago, I've been able to print untillast night, it's giving me error message 5100, what do I do to fix this?
Jul 15, 2012 | Canon Office Equipment & Supplies
When i want print the printer show 5100 error
The 5100 error generally is usually caused by an obstruction, check very thoroughly for small pieces of paper. Gears, rollers, and anything that can stop the cartridge from moving back and forth across the paper.
Aug 15, 2011 | Office Equipment & Supplies
I am getting service error 5100 while trying to print page..the page passes through but nothin is printed....suggest me a solution????
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Getting a 5100 error . put in new ink and camera card it works till hit print then shows an error -5100
5100 means the carriage is not moving freely because of paper scraps inside or grease or ink on the encoder strip behind the carriage. you can try cleaning the strip gently with just a damp Q-tip, moist with water, and look inside for scraps or things that don't belong.
Nov 04, 2009 | Canon SELPHY DS810 InkJet Photo Printer
Keep getting a service error 5100 notice
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Oct 21, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
CANON IP 1300 SERVICE ERROR 5100
ERROR 5100 means that there is some foreign object blocking your ink cartridge carriage that disables it from moving. It may be a piece of paper or a scotch tape or a staple wire. You may try cleaning also the encoder strip with a moist tissue paper. Furthermore, you may also try cleaning CAREFULLY the contact points of the cartridge holder and the cartridge itself (those shiny bronze pins) with a moist lint-free cloth.
Jul 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Paper jam under print cartridges
Stick a 9x12 piece of cardboard down into the tray to force out unseen pieces of paper.
Jan 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Error code 5100 shows onscreen and there are no comments in guidebook
move ink tank to right and turn of then turn on, found in another canon printer fix it.
Jan 28, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Error 5100
I Have the same problem. Greece.  This is the second services and I a lot overwrought with this instrument.
Him I was deprived 2 times and now one more time will again make installation of other instrument for the time of repair.
Rather I will reverse the sale in order to I finish with problems with canon.
[email protected]
Nov 17, 2007 | Canon SELPHY DS810 InkJet Photo Printer
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
167 people viewed this question
Clive
Clive
old marine
old marine
Ekse
