Dns server address
I need the dns server address so i can play my ps2 online
  • Anonymous Jan 15, 2009
    What is an ISP?
  • 36 Answers
DNS server addresses are specific to ISP. contact your ISP and they can help you with this.
take care.
Posted on May 09, 2008
Tip
Check Your Playstation 3 Error Code
<span style="font-weight: bold;">Error Code - Meaning/Suggestion/Possible Fix:<br /><br /><span>0710102 - DNS Error: No DNS server available.</span><br /><br />80010001 - Major Error, Game ability stopped.<br /><br /><span>80010006 - An error occurred during the start operation. - Corrupted folding install.</span><br /><br />80010007 - An error occurred during the start operation. - During the (internal) hard drive disk swap tests. suggests a failure with the hard drive.<br /><br /><span>80010017 - Can't start Blu-ray Game</span><br /><br />8001050B - Will not play demo game from the hard drive. When a Blu-ray disc is inserted. - Cause unknown".<br /><span><br />8001050D - An error occurred during the start operation; PS3 game swapped using the eject function and then play pressed quickly. - Insert PS3 game again.<br /></span><br />80010510 - Will not play games installed on the hard drive. - Cause unknown.<br /><br /><span>80010516 - An error occurred during the start operation: PS1 game swapped using the eject function and then play pressed quickly. - Insert PS1 game again.</span><br /><br />80028EA5 - Unknown. User cannot connect to Playstation Network ("PSN"). Contact Sony for resolution.<br /><br /><span>80028EA6 - Connection Error: Turn off PS3, unplug router and modem. Turn on modem and allow it completely boot-up and synchronize. After the modem shows that it is "online", then plug in the router and allow it to completely boot. Lastly, plug-in and turn on the PS3.</span><br /><br />80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automatic.<br /><br /><span>80028F17- PS2 Disc Boot Error. An error occurred during the start operation: PS2 game swapped using the eject function and then play pressed quickly. - Insert PS2 game again.</span><br /><br />80028F18 - PS2 Disc Error. Unsupported disc: eg. Utility discs, BB discs, IQ Remix game etc.<br /><br /><span>80028F19 - PS2 Disc Error. Fsck: the internal PS2 disk was corrupted. You may be able to use the HDD utility disc to fix it (use with caution), otherwise, contact Sony.</span><br /><br />80028F1A - PS2 Disc Error. invalbnnetcfg: network config error.<br /><br /><span>80029023 - Exchanging Key Information: exchange has timed out.</span><br /><br />80029024 - Cannot obtain an IP address. DHCP failure. Check network connection, modem and/or router.<br /><br /><span>80029301 - An error occurred during the delete operation: attempting to delete PS2 data from virtual memory card.</span><br /><br />80029513 - Copyright Violation when attempting to install game.<br /><span><br />80029516 - Sign in to PLAYSTATION-Network: needed for some games or PS3 processes. Sign-in is required for current operation/request.</span><br /><br />80029564 - Downloaded game will not install: Cause unknown.<br /><span><br />80029945 - Can't playback burned BDr movie: Error in picture.</span><br /><br />80029946 - Attempting to play burned Dual layer NTSC disc on a PAL PS3. The workaround is to transfer files to the PS3 via TVersity.<br /><br /><span>80029C68 - Corrupt data. Usually on an external device.</span><br /><br />8002A10D - Unable to Add friend in XMB. (Normally because you have reached the limit of (100 friends)<br /><br /><span>8002A4A6 - Cannot load game to play online.</span><br /><br />8002A515 - Error Signing in.<br /><span><br />8002A548 - Unable to remain logged in. Either due to game or server.</span><br /><br />8002A705 - Unable to connect to server/host. If you are using a router, check port/DMZ configuration.<br /><span><br />8002A71A - Possible NAT Error. Can log into Game Server but can't join game and can't host game. Turn off the PS3 and wait for 5 minutes.</span><br /><br />8002B241 - DVI has no audio.<br /><span><br />8002F994 - Too many people currently downloading the update. Server(s) at capacity. Wait and retry</span>.<br /><br />8002F997 - Trying to Update the XMB Firmware: Copying to a file and installing from a USB drive failed.<br /><span><br />8003041F - An error occurred during the copy operation. (Using media server)</span><br /><br />8003051E - Game will not Save.<br /><span><br />80030920 - An error occurred during the copy operation. The file may be corrupt or there isn't enough memory. Try copying data from original source.</span><br /><br />80031150 - System Settings Fail to Save. Possible Blue Screen Setting information is corrupted.<br /><br /><span>80031601 - Error Creating Account.</span><br /><br />8013013D - A connection error has occurred: Causes may include the actual SSID of the wireless access point/router or signal strength. If the connection drops, try enabling DMZ functionality on your router (if supported) for your PS3. Otherwise check WPA key. The PS3 wireless interface [currently] does not support WPA2 - only WPA, WEP or none.<br /><span><br />8013013E - WEP Key error: Change WEP key to *only* numbers and try again, or switch to WPA.</span><br /><br />80130203 - PS3 connects to the internet (you can go a website via the PS3's browser), but cannot connect to the Playstation-Network. Typically this means that the required ports are not open/accessible. Check your router's configuration.<br /><br /><span>8013030 - System Error: Due to failed update download.</span><br /><br />8013030F - Access Point was not detected. Check your router's configuration and make sure that SSID broadcast is enabled.<br /><span><br />80410418 - DNS Error.</span><br /><br />80410A0B - Internal error: "Hardware Fault". Send unit back to be replaced/fixed.<br /><span><br />80710016 - The Playstation Network is down.</span><br /><br />80710092 - "An error has occurred. you've been signed out from the Playstation-Network". Connection dropped? If your PS3 is wireless (least preferred), the association between the PS3 and the access point may have been dropped. You may need to "reboot" your PS3 if your PS3 and router are unable to establish an association.<br /><br /><span>80710101 - Connection error.</span><br /><br />80710102 - IP Address conflict. PS3 cannot connect to your router with it's current IP Address information. Try rebooting your router and PS3. Occurs when two devices on your network have the *same* IP Address.<br /><br /><span>807101FF - An error occurred during communication with the server. This is a DNS error. It occurs when your PS3 tries to perform a DNS lookup to connect to the server.</span><br /><br />8071053D - Hard boot the PS3. Turn off the PS3 via your controller (this is stand-by mode), Turn off the PS3 switch on the back of the PS3 and remove the power cord. Next, turn-off/unplug your modem (and router if applicable) for about 5 minutes. Then turn on the modem and wait for it go "online". If you have a router, turn it on and wait for it go "online". Then turn your PS3 back on and make a new network connection.<br /><br /><span>80710541 - The connection to the server timed out. This is usually due to: high traffic (between you and the server), high traffic at the server [itself] or you have a "poor path" to the server. Depending on result: Press the 'X' button to repair and restore default.</span><br /><br />80710723 - Possible Port Error: Try opening ports. Configure your router to pass the following ports to your PS3:<br />TCP ports: 80, 443, 5223<br />UDP ports: 3478, 3479, 3658<br />Another option is (if your router supports DMZ functionality) to configure your router's DMZ functionality to pass traffic to your PS3.<br /><br /><span>80710A06 - An error occurred during the install operation. Error when downloading game from the Playstation-Network. An error occurred.</span><br /><br />80710B23 - Playstation-Network is down or Playstation-Network is too busy to respond.<br /><span><br />80710D23 - Turn the PS3 off for a bit. For 30 minutes give or take. Make sure that you either unplug or actually turn off the switch (located on the back of the PS3). "Stand-by" mode is when you see the red LED on the front of the PS3. If you see the red LED on the front of the PS3, your PS3 is *NOT* off.</span><br /><br />81019002 - Error copying saves from location "A" to location "B" not open to connect to store but PS3 can connect to internet.</span>
on Feb 21, 2011 | Sony Playstation 3 (PS3) Console
I am trying to get online but everytime i click the entrnet explorer it just says dns error i dont know what to do
A "DNS" server is a "DOMAIN NAME SERVER" -- you feed it a name, such as 'www.ebay.com', and it returns an IP-address. Then, the Internet "routes" your traffic to that IP-address, and eBay's web-server responds to your request, and sends a web-page to your IP-address.
A "DNS error" means either:
* there is no IP-address associated with the name, as you spelled it, e.g., 'ww.ebaay.co', or,
* your computer could not connect to the DNS-server, and so could not send the query,
* your computer does not know the IP-address of the DNS-server, and thus has "nowhere" to send your DNS-query.
Jul 19, 2011 | Computers & Internet
How do I configure my laptops IP address to my router to get online? I'm using windows vista. I tried a few times and I can't find the window to type in the laptops IP address. How?
Follow the following steps to change your TCP and IP Settings on Windows Vista
1. Go to the Control Panel from the Start menu.
2. Click "Network and Internet" and then "Network and Sharing Center."
3. Click "Manage network connections."
4. Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
5. Click the "Networking" tab.
6. Choose Internet Protocol Version 4 (TCP/IPv4)
(Note that "Obtain an IP Address Automatically" works fine generally)
7. Click "Use the following IP Address" to enter your own IP settings.
- Enter IP address (eg. 192.168.1.125) into the box marked "IP Address, press tab "Subnet Mask" would appear automatically (255.255.255.0) and in "Default gateway." type 192.168.0.1.
To specify DNS server address settings, do one of the following:
- To obtain a DNS server address automatically, click Obtain DNS server address automatically, and then click OK.
- To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.(which can be obtained from your internet service provider (ISP).
For visual help, check out step by step guide here
Hopr it Helps!
CreativeTECH
Nov 25, 2010 | Linksys Wireless-G Broadband Router
DNS error (80710102)
When configuring your PS3 network (regardless of wired or wireless), use the manual option. If you use DHCP, leave address resolution at automatic but change the DNS Server enter to manual.
I replaced the Roadrunner (or any other ISP's) DNS entries with addresses from the Open DNS project which is a free, secure DNS server that anyone can use. It's safe, easy, and works.
The DNS addresses are:
208.67.222.222 or/and 208.67.220.220
Once replaced, you should have no problem logging in.
You can also use these DNS servers for your entire network if you like by configuring your router. That however is up to you, and won't be discussed in this particular thread by me since I'm too lazy to make a writeup for every single router out there. However, I do guarantee that this fix will work (or at least get you online with your PS3) for the time being. If it doesn't work, then please re-read this thread and try again before wasting five minutes of your time telling me that it doesn't work.
Also, for those that think that this is a PSN issue; consider this: With TW, I could still browse the net with the PS3. I could also use any of my home PC's without problem. The only time I ever encountered a fault was when trying to log into the PSN network using the TWC supplied DNS addresses. Once I replaced those, the problem went away.
Think about it now. If it was a PSN issue, the OpenDNS addresses woudn't have worked for me or anyone else here either. But, since it did I think it's safe to say that the problem lies with your ISP. Don't forget that alot of ISP's including Time Warner depend on 3rd party DNS hosts. Just because you have TW (or Comcast, or Cablevision, et al), doesn't mean the DNS servers are owned and operated by them as well. Perhaps the DNS provider changed something in their routing tables preventing a connection with PSN. There are ALOT of variables at play here...
That alone could be a reason why others have similar issues with different ISP's. Maybe their ISP uses the same DNS host that Time Warner uses. All you're doing by replacing the DNS address is simply using a different DNS provider; nothing else.
Feb 03, 2010 | Sony Playstation 3 (PS3) Console
Oops this link appears to be broken dns error - cannot find server windows 7 explorer 8
The error refers to the Domain Name Server (DNS) that your system uses is unable to translate the Uniform Resource Locator (URL, web address either Typed in the address line or linked using a hyper-link, favorite or default home page) (In english, the translation of a web address link www.google.com to the Internet Protocol (IP) address that computers actually use to show the page)
Possible causes:
  1. The URL is wrong. (Typed wrong, link no longer active, link changed)
  2. The DNS server listed for your ISP configuration is not working.
  3. The web site is offline.
  4. The DNS server settings for your internet configuration are wrong.
Possible resolutions:
  1. Try a different Web Address, see if it works
  2. Restart (Completely power off your Cable/DSL modem and then do the same with your router)
  3. Check you IP address configuration settings and ensure that auto-assign DNS is selected (Default setting)
  4. Boot to safe mode with networking, see if you can get online that way.
Dec 21, 2009 | Computers & Internet
I cannot communicate with primary dns server 172.29.71.1 is there a way i can reset it automaticaly or manually
You cam try doing a power cycle. Turn off the modem, router (if you have one) and your computer. after 1 minute turn on modem first then router and computer. If you still can't communicate or ping the DNS it could be a firewall that is blocking it.
Oct 08, 2008 | Computers & Internet
Playing madden 09 online
If it says ea servers not available that means the servers are down for maintenance, this is not unusual for video game servers, happens once or twice a month....
Also keep in mind playstation servers and xbox server are totally different.
Aug 19, 2008 | Sony PlayStation 2 (PS2) Console
Playstation 3 online
go to ur network settings and then go to deatils and it tells u ur ip adress and dns server and othe stuff to type in
Jul 05, 2008 | Sony Playstation 3 (PS3) Console
PS2 Online
Try reading this http://www.gamenationtv.com/features/ps2online.shtml
Dec 29, 2006 | Sony PlayStation 2 (PS2) Console
Computers & Internet Logo
305 people viewed this question
David Payne
David Payne
