Question about Microsoft Xbox 360 Console
Red lights on xbox 360
1 of my games recently froze on the xbox and since then i havee had 3 red lights on the console and it wont load any games or dvds.
Get a ps3
Posted on Apr 04, 2008
3 red lights is the red ring of doom just send it back and get it fixed for free!
Posted on Apr 03, 2008
Just send it back and get it fixed for free!
    Sniper:
  • 53 Answers
Which three lights? if its Top Left, Bottom Left, Bottom Right, then you have the infamous "Red Ring of Death." witch means general hardware failure. If you search around on the internet, there are some Xbox360 modding sites that sell kits to repair this kind of problem (if youre brave enough to tackle it).
Luckily Microsoft is aware of this problem and has extended thier warranty to 3yrs (but ONLY if you have this particular problem).
Otherwise you'd have to send it into Microsoft to get it repaired.
Posted on Apr 01, 2008
SOURCE:
Red light on ac adaptor on xbox 360
You need to replace the laser you can go to www.llama.com for tutorials
Feb 26, 2013 | Microsoft Xbox 360 Console
My ps3 wont play games or dvds
unplug your ps then turn back on this resets it try that ok;
May 01, 2010 | Sony Playstation 3 (PS3) Console
3-red rings fixed, now 2-red rings...can't fix!
ya under the heat sinks there are spacer like washers replace them and i should solve your problem i own 7 of them
Nov 29, 2009 | Microsoft Xbox 360 Console
Red lights go on not green and wont load anything
That is unfortunately a common problem with xbox 360s. It's called the "red red lights" and it means the console has failed / "died". You will need to call Microsoft at 1-800-4-My-Xbox and they will repair it (most likely for free, the warranty is 3 years for this problem).
Thanks, hope this helps =)
Aug 12, 2009 | Microsoft Xbox 360 Console
I dont under stand
This is a very common problem with the xbox heading to the 3 red lights.
Jan 12, 2009 | Microsoft Xbox 360 Console
Xbox fixed itself from 3 lights but other problem
When someone say that his/her Xbox is having 3 red lights problem, It means it needs to be repaired. If you are using Cooler than it is not a cure but a prevention. You could have used cooler before acutally having the problem just to prevent your Xbox. But now you will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Dec 19, 2008 | Microsoft Xbox 360 Console
Xbox 360 plays CDs n DVDs but wont play my games, plz help
try calling microsoft again...and if no luck...then you might have to find a replacement cd drive...you can probably get one off of ebay.
Jun 28, 2008 | Microsoft Xbox 360 Console
Freeze
It might have overheated, After it cools try it again, Make sure your vents are not blocked.
Might be the beginning of the 3 red light problem see http://fix-your-xbox-360.blogspot.com/ for more if you still have the same problem
Mar 22, 2008 | Microsoft Xbox 360 Console
Help: Put 360 games in console, wont load says "put in xbox 360" no red lights?
Ok I had the same problem try this if this doesn't solve your problem call Microsoft.
First, Unplug everything including harddrive.
Next, Wait thirty seconds.
Then, Plug everything even harddrive.
Finally, Try it out see if it works. If it doesn't call Microsoft.
1800-4MYXBOX / 1800-4699869
Dec 21, 2007 | Microsoft Xbox 360 Console
XBox 360 freezing- Not what you think
Your system is headed for the dreaded red ring w/ three red rings. My system started doing the same thing just before this happend. If you have a service plan with it i would suggest returning it and getting a new one.
I tried all the there little tricks as well deleted everything off my harddrive all that good stuff i think it made mine worse. Cuz after all that i turned it back on and bam three red lights and no picture or sound.
Nov 28, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
76 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
