Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
Just rebooted the modem
Now that I have set everything to default, the network is open. I would like to reset a new user name and password. I don't know how and I don't have the disk anymore, we have moved twice since we first bought the modem. Any help would be great shaumin@hotmail.com
Well if everything set to the default, log onto http://192.168.100.1/index.asp
the default user Id: admin
password: motorola
Posted on Jun 28, 2008
Need to hard reset westell 7500 modem to factory defaults..cust chngd admin password and can't remember what they chngd it to and i need to get into modem
  • Note: Resetting your router to the factory defaults not only changes your router user name and password to the factory default values, but it also deletes all your home network settings. This includes the SSID and network encryption key. After you reset your router to the factory defaults, your home network won't be accessible until you reconfigure your router and all your network devices to use the same SSID and encryption key.
To reset your VersaLink 7500 gateway to the factory settings:
  1. Hold the reset button on the back panel of the VersaLink 7500 gateway for 30 seconds.
    • All your settings will be lost including network encryption information and any SSID information you have entered.
    • The gateway user name and password will revert to the default of Admin as the user name and Password as the password.
  2. Your VersaLink 7500 gateway is now using the default settings for the network configuration. This includes the default SSID and network encryption key. You must re-configure your VersaLink gateway to match your previous settings that were assigned to all other devices on your wireless network. Otherwise, no other network devices will be recognized.
Nov 05, 2011 | Westell Wirespeed VersaLink...
Tip
HOW TO SET UP SPEED TOUCH 5X6V6 BROADBAND MODEM
Once you have an Internet Service Provider ,ISP,
you just need a modem and phone line access,
plug modem into phone socket and then into the computer,
My example modem is.........
Speed Touch 5x6v6 - Broadband Modem
Operating System is Windows 7
log on to the modem using Internet Explorer Bar
Type 192.168.254
this will open the modems log on menu
then enter user name and password
its factory default is
user ADMIN
password ADMIN or 1234
once open there are some menu options on the main page
Speed Touch,
Broadband Connection,
Toolbox,
Home Network,
to add new user and password,
go to toolbox,
user management,
add new user
add password,(write down username and password)
change default user
save and test
should have a green tick next to new default user now
selecting broadband ... shows both your,
dsl connection and internet connection status,
with a green tick next to each heading.
Home network will show you...
all devices connected to this modems network ie
the other computers and printers etc,
connected on your network.
In network ,select your computer in the menu tree,
select configure
this give you a menu to add info about your computer
ie name info, comupters ip address,
access to the local intranet or the internet
Now lets connect to the internet
select Broadband from front page
menu will open and display
DSL & Internet Connections
here we test internet functionality.on? or off?
Now we go to your computer,
go to start
my network connections
run wizard in my network places
select new connection
follow prompts to the end.
open internet explorer
if web page opens then we are done and finished,
or
open tools and internet options,
connections and then lan settings
select automatically detect
Apply then close
Test webpage again,
when ok shut down and restart,
to save the computers new settings ,
Test again with internet explorrer.
if no connections run wizard again,
Hope this Helps,Cheers Misterdj
on Apr 18, 2010 | Computers & Internet
I don't remember my network key,so I cannot use it
Try to connect you computer with an Ethernet cord. If the Internet is working check the default gateway of the computer by typing "ipconfig" on the command prompt. Type the default gateway on the address bar. There you will see the login page for your wireless router. Check the default username and password from the router's manual and enter it. If it accept the user name and password, look for the wireless settings, password should be seen there. If not create a new one. If default user name and password doesn't work reset the router. There should be a reset button or pinhole on the back of the router. Press and hold it for 10seconds. Try again typing the default gateway on the address bar then re enter the default user name and password. If it work your router now do not have a network key (unsecured). You can create a new network key on the router's configuration page.
May 21, 2011 | Computers & Internet
What is my WEP key?
open a browser - clear the address bar - type in
192-168.1.1 - then in the password - forget the username unless u set it - in the password type in 'admin' - just admin that's it -
the go to security - - hunt around and you will see your wep numbers - there will be 4 of them most likely - pick one -
Gary
May 08, 2010 | Actiontec GT704WG Wireless Router...
Not able to go online
have you been online with this computer before?
or
Are you setting up for the first time?
Type 192.168.254
user ADMIN
Speed Touch,
Toolbox,
Home Network,
go to toolbox,
user management,
add new user
change default user
save and test
select configure
select Broadband from fornt page
here we test functionality.on? or off?
start my network connection
Apply then close
Test webpage again,
Apr 18, 2010 | IBM ThinkPad T30 2366 Notebook
My moms cable company installed a new modem and left the router disconnected--I reinstalled the software and hooked everything back up and my laptop recognizes the network but seems to be stalled out at...
Hi ,
This is Neo . Thanks for contacting us .
Reset your Netgear and Try it again .
The step to be followed are ,
STEP 1
Reset the Router by pressing the RESET button on the rear till the Test Light blinks.This takes about 10 seconds . Use a pen or paper clip to access it .
Release the button and wait for the Router to Reboot.
STEP 2
Login to the Router with the default Password. The Router has the default User Name as 'admin' and the default Password is 'password' .
STEP 3
If the Router was not cleared after rebooting, unplug the Router's power . Then Press and hold the Reset button.
STEP 4
While the button is held down, reconnect the Router's power . Continue to hold the Reset button for 20 seconds after reconnecting the power . Wait for the router to reboot .
Then Login to the Router with the default Password. The Router has the default User Name as 'admin' and the default Password is 'password' .
Do the setup and try to connect to internet .
The Router will work .
Thanks & Regards
Neo
Thanks for using FixYa.com.
Feb 07, 2010 | NetGear WGT624 Wireless Router
I have a DNA-A211-I ADSL2+ Modem. It went fo repair by BSNL and they exchanged it for another. Now I cannot access the user settings (http://192.168.1.1) as the default user name and password were...
hey buddy u need to press the reset button only for 3-5 sec( it look like a hole u have to use a pin to reset it. it is located at the bottom of the modem.) don't press the button more then that otherwise it won't get reset. once it get reset go back to the modem page this try admin as user name & leave the password blank. if case if it doesn't work with that try admin as user name & admin password or admin as user name & password as password.
Jan 15, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Rest password on DNA-A211-I ADSL2+ Modem
hi..
the only way to restore the router is to hard reset the router,which will reset the router to the factory defaults and then setup the router as the first time installation and the default username and password will be restored,i kno this is much of a work to reset the router and again setup the router like 1st time installation but this is the only way to retrieve the default user name and password..
vedhick
Tipps pls?
The error you refer here are due to Bad Username/Password.
Please type 192.168.1.1 in your web browser, a pop-up window will show which require User Name and Password. Type both as admin (Please use only the lowercase letter). You will then be carried out to your Modem Configuration Page. In the Left Pan select first Reboot. From the right Pan select the lower button i.e. Restore Default setting. Your Modem will be rebooted. After booting the Modem (When all the lights are ON), again type 192.168.1.1 and use the process as above to acess the Modem Configuration Page. Now select the WAN from the left pan. Press the Edit button in the row for PPPoE settings. Don't change any setting shown by default and press the next button. At the end you will get a text box to type your User Name and Password. Use your Broadband User Name and Password here (Not the Portal ID & Password). click next and then save. Now again just reboot your Modem by using the upper button in the Reboot page. You can use your broadband now.
Note: If you are unable to open the Modem Acess Page by typing 192.168.1.1, ask the BSNL person to change your Modem.
Hope this will solve your problem.
For any clarification, do contact me.
Jul 21, 2008 | Computers & Internet
Speedstream 6520 wireless router
log into the firmware by the following steps
1 open browser and type 192.168.2.1
2 goto advanced
3 user name and password should be admin and admin
4 click on home networking modem
5 click on reboot
6 click on reset to factory defaults
7 click reboot
once rebooted repeat step 1 this time it will ask about setting it up make sure to select router only configuration
reboot modem and setup wireless cinfiguration
Feb 23, 2008 | Computers & Internet
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
713 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
