No service support for mitshubishi air conditioner
We are having more than 20 air conditioner unit at our compony, Accutest Research Lab, Ahmedabad, Gujarat, India.
All AC's are in warranty period.
We are not getting service support for the same.
    Genius:
  • 1,226 Answers
Hello.
In this case i suggest you to contact the vendor of all your AC's let tell them about the issue of the air con so that they can render service support.
you can contact also the service center of the mitshubishi aircon.
melnavz
Posted on Apr 01, 2008
  • Anonymous Apr 01, 2008
    what a very good rating you made. how do you interpret the statement you wrote. " We are having more than 20 air conditioner unit at our compony, Accutest Research Lab, Ahmedabad, Gujarat, India.
    We are not getting service support for the same."
    We are trying to cater about the problem. We are not the distributor of your air con. we are just suggesting and helping people with technical problems, but in your case you only tell about your air con and there is no problem except for the service of the said air con.
    i will suggest you post it to the premium not the solicited one.
    melnavz
  • Anonymous Apr 15, 2008
    jangid,
    wala jud kay klaro, maayo pa kaunon nimo nang imong aircon diha.
    Genius:
  • 1,554 Answers
That is normal for a exporter to not provide warranty unless you ship it back.
SOURCE:
The air swing button is not working
moat air conditioners suffer this fault after time
research has shown the the small plastic gears in the actuator , break teeth
the only repair is a new louvre actuator assembly unit if they are available from the service agent
May 27, 2015 | Heating & Cooling
Room temp 78 degrees with unit setting at 68 degrees. The unit is running (i.e. compressor) but unit not pumping out cold air. To be specific the unit is pushing out cool air just not cold with such a...
Sounds like it could be low on freon I believe these units have about 1.5 pounds of freon in them and are critical in not undercharging or overcharging them if it is a freon 410 ac unit the pressures should be about 135 and both lines cold if is low on freon a service tec will need to be called to try to repair the leak if possiable
Jul 21, 2013 | LG LAN240HSV2-LAU240HSV2 24000 BTU 20 SEER...
How do I change the fan motor in a whirlpool air conditioner
Might be best to have it looked at but if you want to try---see if a service manual and the part number for the motor are available---you may find it is a rather expensive part so research the unit and parts first.
Jun 15, 2012 | Whirlpool Heating & Cooling
My air conditioner cooling coils get frozen approx\.after 2 hrs of running i have showed it to the service boy they first serviced filled gas and even changed the fan motor. but still the problem...
Hello, the evap coil will freeze from either low airflow or low charge. I would clean the coils, check air filter and replace or clean if dirty. If you have a thermometer measure the air entering the ac and the air leaving the ac, the differance should be 15-20 degrees, measure this after cleaning the coils. If it still is below 15 degrees the unit is underchraged.
May 26, 2011 | LG Heat cool Window Air Conditioner
Our wall unit just quit working. we moved in four years ago so i'm not sure how old the unit is and don't have a manual. from my research, the product matches the Carrier XQB153D. We have never serviced...
Would you be using this Air Conditioner, as Heat Pump--
and so, when you say it just stopped---
Is that meaning that it stopped supplying HEAT?
Or are you using for cooling purposes?
Thanks for telling us that yo have NOT serviced it in 4 years!
You could pull the front cover off, and clean the filters--
Possibly a mouse or a bird or ?-- has built a nest in a wrong spot, and caused problems.
Give us some clues as to alarm lights, or sounds it used to make when you turned it on, versus what you hear now when you turn it on?-- any humming?-- clicking, etc.?
Tell us more, and we'll try to help to the next step.
Mack B
Jan 25, 2011 | Carrier XQB153D Air Conditioner
My Hitachi AC needs maintenance/Service. It is out of warranty period. Please guide me to someone available in or near Bopal, Ahmedabad
dear sir /mdam
i am giving you a link of hitachi air conditioner dealer at bhopal . please contact them for solve your air con maintenance problem,
thank you
hope answer the question.
please vote!
http://bhopal.justdial.com/capital-refrigeration_m-p-nagar_Bhopal_ugjdfnSDTSybaPwexq.htm
Sep 23, 2010 | Hitachi Heating & Cooling
Air con unit saying 'C6"
According to the service manuals:
6 is:
Excessive current at inverter
DC power circuit
so the unit shouldnt run?!?
The fault is also coming up as:
indoor unit coil sensor faulty
source:
http://www.mylg.co.uk/data%20for%20site/LG%20Fault%20Codes%20for%20SMS%20%2807%20Sept%29.pdf
all the best
Jul 05, 2010 | LG LSC183VMA Split System Air Conditioner
I has a split AC there is problem of electrical wiring between compressor and in house machine. I need some service center address in Ahmedabad city Gujarat to recify the same. My model No. is SAP-K184ML
hi,there is a problem commucating...possible one of the wires has gone bad....you will need to to turn off all power to both units at the breaker at the panel or disconnect...you will need to go to walmart purchase a electronic test meter..they have one for 20.00 ..i bought one yesterday...yiu will need to remove one wire at a time from the indoor unit...get a piece of paper befor removing any wires...mARK NUMBERS....
Mar 26, 2010 | Sanyo Split System Air Conditioner
AC is not working for the past 20 days, we have complaint to your office, the serivce person took our ac unit to there workshop and they brought to our house' 19.1.09 still now is not working huge amount...
We are not associated with any manufacturer. We only offer free service assistance. Ice formation indicates insufficient air flow. Clean or replace your air filter. Make sure you do not have unit set to draw in outside air while operating. This should be a Fix-Ya for your air conditioner.
Jan 20, 2009 | Heating & Cooling
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
