Question about Magic Chef 31000 Gas Kitchen Range
Searching for plastic push on control knobs
I need 6 plastic control push on knobs for a chef kleenheat all in one cooker hob model num gbc5246w or model gbc 5266w
  • 1 more comment
  • watershed Apr 02, 2008
    thankyou but i had already tried without success that is why i contacted your company as i needed further assistance
    thanks
  • Anonymous Mar 18, 2014
    the cut off gas to the hob isnt allowing gas through there doesnt appear to be anything to push the button down
  • Dennis Faulkner
    Dennis Faulkner Nov 19, 2015
    There is a neat company that does high-end knobs, I think it is coulter - they come with adapters for different widths, and tell you how to measure to get the correct knobs.
    Genius:
  • 1,226 Answers
Hello.
I search it however, not to find the replacement parts, in this case i would rather suggest you to contact the vendor of your kleenheat, maybe they know where to find the service center of that machine or their tech maybe can cater the problem.
mlenavz
Posted on Apr 01, 2008
  • Anonymous Apr 02, 2008
    I search almost all the resources in the net but no luck. maybe there is service tech in your area. please try some expert here that is near in your location.
    for me i will notify you later if i found the solution you need. ikeep on digging, melnavz
6ya staff
SOURCE:
I need a Manuel for my Russel Hobs Slow Cooker 13792
Instructions for slow cookers are fairly generic.
I assume your control knob says "OFF", "LOW, "MED" and "HIGH".
If I were you I would just google recipes for crock pots.
Feb 02, 2015 | Crock Pots & Slow Cookers
I have an old belling farmhouse cooker the hob works fine but the oven isn't igniting manually or by the electric ignition The timer is manual and is stuck on the red patch I can't seem to shift it ...
, push in and turn the control knob to the full on position (large flame symbol). If your hob has an ignition switch on the facia, press it in until your burner lights. • Hold the control knob in for 15 seconds then release. If the burner fails to light within this time, release the control knob and wait one minute before attempting to re-ignite.
or
Push in the control knob and after a couple of seconds press the ignition switch. • Hold the control knob in for 15 seconds then turn to desired heat, If the burner fails to light within this time, release the control knob and wait one minute before attempting to re-ignite.
Feb 03, 2018 | Belling FarmHouse 931 Gas Kitchen Range
Please can anyone help? We are in a rented property and we have an NEB Venezia SS electric oven with gas hob and all the writing on the knobs has been erased over the years. The hob works fine we need to...
Look up the oven on the web the knobs vari in calabration figures so I have never worked on this model, try a search engine you may find a showroom near you pop in and have a look.
hope this has been helpful
John
May 31, 2011 | Ovens
I need to replace the top oven thermostat control how do i remove the front panel ???oven is a stoves 800DF DOm 050565031
you dont need to remove the front panel, you need to undo the two black screws on the side of the hob unit, remove the two plastic plugs they went through allowing you to raise the hob, and remove just the back off the cooker this provides you access to all the areas you need you can then follow where all the cables go oh yes nearly forgot the thermostat is held in place by two screws you simply pull the knob off and there they are. ive just done the fan oven one and it seemed fairly straight forward, but please do remember to turn off the power to the cooker first all the connections push on using spade connectors, oh yes for legal reasons this is for information only and i wont be held liable for injury or damage caused by unqualified people following this information to fix it themselves as i would always have to recommend that you use a competant person ie a person who is trained, experienced and has sufficient knowledge to do the job, but those that do want to fix it do so at their own risk and i hope all goes well with getting the problem fixed
Feb 15, 2010 | Stoves 800DFDOm Dual Fuel (Electric and...
Owners Manual Franklin Chef Slow Cooker
I broke the power control button on my cooker. Can I buy a replacement button and if so where.
Apr 02, 2009 | Rival SCV601 6-Quart Slow Cooker
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
Ignitor will not stop sparking on AEG Electrolux Cooker Hob
gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
Jan 09, 2009 | Cooktops
Control knob
You can either try the GE web site or replacements.com. If those two fail, try eBay.
Please remember to rate my solutions! Thanks
Aug 25, 2008 | GE 106851 6-Quart
Magic Chef 31000 Gas Kitchen Range Logo
184 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
John Tripp
John Tripp
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
