Question about Raymarine Ray45VHF (53 Channels) 2-Way Radio
VHF Radio The VHF radio on our boat is able to transmit clearly and over long distances of 35nm, however we are unable to receive any responce over about 6nm. Are you able to suggest a solution?. Kind Regards, Capt Geoff Botha
  • 47 Answers
Check ther frequency tuning.
Sounds like it is off frequency.
Is the VSWR on the aerial Ok
Posted on May 26, 2008
Transmitting and Receiving fault
Ray marine has an extensive library on-line. I have usually been able to find what I need there. May take some digging though.
May 10, 2014 | Raymarine Ray218 Vhf Radio
Unable to transmitt
Read your Radio and enable transmit
May 24, 2013 | Icom Ic-a110 Vhf Mobile Aviation Radio
GME TX3340 not transmitting
You may have a bad microphone, not uncommon problem.
Apr 18, 2012 | Computers & Internet
Dear sir I HAVE VHF MARINE TRANSCEIVER IC-M34 for 2 years ago, suddenly, I can't receive any signal ( transmitting without receiveing ) but if I set the squelch to 0 level I can reveive signals and...
This is a front end issue that has to be remedied by a radio tech or the factory. The front end is the receiver and it takes special tools and equipment to test and calibrate it correctly,, The only thing you can do is check the ICOM page to see where it can be serviced.
Nov 27, 2017 | ICOM Informatique Floating Hand Held Vhf...
My uniden ltd 715 receives from my handheld but when I transmit to handheld it just buzzes.
Just to clarify something, you say that your hand-held VHF can receive a clear transmission from the Uniden, now which of the radios are buzzing, the Uniden or the HH?. If it's the hand-held buzzing try transmitting on the low watt on the Uniden, get some distance from the radio, because if the hand-held are to close to the on the Uniden on high watt you will get a buzzing, the signal are overpowering the receiver of the hand-held, try getting the minimum of 30 feet away. Good luck.
Mar 24, 2011 | Uniden Solara DSC VHF Marine Radio
My VHF Marine Radio transmits very well -over 30 miles but only recieves about 6 miles. The boats that are calling me also have very high antennas so hight is not the problem. The boat is new and we are on...
I don't have much experience of radio transceivers but I do have a couple of ideas.
The big question is how do you know your radio transmits 30 miles but receives only 6 miles?
Clearly you have a friend with a transceiver and you have been playing around together until you formed those conclusions.
What if the other radio received well but didn't transmit so well? Have both radios been checked with a field strength meter to ensure they are both radiating similar power outputs?
Do you receive the carrier wave but no audio at a range greater than 6 miles? If so your friend's radio (and others) might have a modulation problem. Has the signal(s) been analysed with an oscilloscope?
It is often imagined the transmission envelope is circular radiating from the antenna at the centre but that is often wrong. The radiation envelope is often distorted by a ground plane. Imagine an antenna mounted at the centre of an aluminium boat hull, the radiation envelope would be elliptical in line with the hull.
Even with a fibreglass hull the presence of metal masses can pull the radiation envelope out of shape lengthening the range of both transmission and receiving in one direction and shortening them in another.
There is another possibility to poor reception and that is a high amount of interference that might be airborne being received by the internal radio circuitry, by several means - antenna or the poor screening of the downlead and could be aggravated by poor grounding. Interference can also be on the supply line and both types can be generated by a host of electrical or electronic equipment.
Generators and motors, voltage regulators or stabilisers, local oscillators, fluorescent lighting, inverters, computers...
The basic radio of the old days could have the Squelch turned off and an experienced operator can hear much of what is or isn't happening.
Nov 23, 2017 | ICOM Informatique Icom IC-M402 VHF Marine...
With engine running on boat, radio transmitts with
This is almost always caused by a poor ground. I would suggest you run your ground wire (larger the better) back right to the negative terminal of the battery.
Hope this is helpful.
Jul 14, 2010 | Uniden Solara DSC VHF Marine Radio
I just purchased two radios. How far will they transmit and receive with good clarity in the city? I need to transmit and receive from about six to eight miles away clearly. Thanks.
bobengelman,
Typically and unmodified handheld CB will have a decent talk distance of 1-2 miles with both being a handheld. Further distances can be had if one of the radios was a mobile or base station with distances of more than five miles with weak signals. In some cases the antenna can be changed to a better longer antenna. Extention type antennas typically transmit about a mile per watt. Conditions such as terrain will have an impact on signal specifically mountains or buildings. Better results may also be had by purchasing a mobile magnet mount with a PL-259 to BNC to fit the radio. A magnet mount placed on a air conditioning unit or large cookiesheet as high as possible will make decent gains for distance if the radios are intended to be stationary.
JT Radiojunkie
Jun 21, 2010 | Midland 75-785 Handheld CB Radio
Navman VHF 7100 Radio neither receiving nor transmitting
I would suggest checking your antenna/coax connector. I am not sure what kind of antenna or ,mount you are using but I would suspect it being something in the antenna. Most radios are designed to not transmit if the antenna is broke or not connected at all. When you say bent do you mean metal bent or bent at the base? So that would be where I start. Can you try a different antenna? Hope you track it down. N5ARK
Aug 10, 2009 | Navman Tracker 5600 GPS Receiver
Raymarine Ray45VHF (53 Channels) 2-Way Radio Logo
131 people viewed this question
Top Raymarine Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Raymarine Radio Communication Expert? Answer questions, earn points and help others
