Question about Car Audio & Video
97 ford in console cd changer
Changer cartridge will not eject - may have two cds in one spot. shows "no cd" when cd button is pressed.
    Scholar:
  • 176 Answers
The reason why the changer cartridge will not eject maybe because of the rubber in the motor of the disk that push the cd open is misaligned or loosen. You can check it if you open the cover of the disc in look in the front the black rubber that hold the rotation to push the cd outside. and you can put some lubricate oil in the side of the disk maybe they cannot open because of some dust. Clean also the lens by using of cotton bud or the cotton cloth don't put any liquid to avoid damage the len. I hope my solution is help you to solve the problem.
Posted on Apr 18, 2008
    Genius:
  • 3,422 Answers
The first thing i would suggest you to do is a hard reset by unpluging the the player for 30min and then try again.
If this does not solve your problem then please see if the player tries to read the disc.
Load a disc and listen.Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.
If the problem does not get solved then you have to get it repaired.
Goodluck,
Please don't forget to rate the solution.
  • Priya darshan Apr 18, 2008
    Aslo see if there is a small tiny hole near the tray.If there is a hole then insert a small pin or a needle it will eject.
    Genius:
  • 1,447 Answers
If you can slightly open the from cover where you actually insert cd and can view 2 cd in it, remove cd player from hood and manually remove the stucked cd by dismantling the cases, make sure you keep track of the screws that you remove from the cd player so that when you put it back it'll not miss a screw. Best i got...
    Genius:
  • 1,142 Answers
Please provide the model and the make to assist you better
  • Anonymous Apr 18, 2008
    As for its installation, you may connect it to the head unit’s preamp. You can have a direct cable that needs to be attached between friendly CD changer and the head unit. This way you will help your used CD changer to be equipped with the power to adjust with rest of the audio system. Not all the used CD changers work well with the OEM head units of the CDE changer control. Therefore, you should examine your product related t this function. You must ask about its disc holding capacity and frequency response.
    On the other hand, the best way is to connect the CD changer to the FM modulation. In this, your CD changer will have an outboard control unit that will receive h signals from the hanger followed by converting it to an FM radio signal.
    **** OVERALL WHAT YOU NEED TO DO IS TO CALL A SERVICE TECHNICIAN WHO CAN OPEN THE CD CHANGER UNIT AND GET IT CLEANED AS THE CD LENS IS NOT READING THE DISKS CAUSE IT MIGHT BE DIRTY DUE TO DUST OR THE LENS HAS GONE BAD******
SOURCE:
I have CDs jammed in side 6 disc changer (factory)> I have tried resetting the system by removing and replacing the fuse, but still get CD Error> If I need to remove the unti, is there an easy way...
Press and hold eject button,insert a credit card under cartridge
Push card fully in and move left /right right/left
This will locate micro switch to release cartridge
May 30, 2011 | 1992 Ford Explorer
My cd changer in the trunk wont eject so i can change cds can anyone help
PRESS AND HOLD EJECT BUTTON
Insert credit card or similar firmly under cartridge,move left/right to locate micro switch
Mar 19, 2010 | 1994 BMW 5 Series
I have a 1997 Ford Explorer purchased new with te
is there a coin holder in front of the changer? if so, there may be a coin lodged inside the changer preventing the carrier mechanism from moving. look on the bottom of the changer to see if a coin might be stuck.
Mar 11, 2010 | Clarion DC625 6-Disc CD Changer
I have a 1996 ford explorer and the 6 disc cd changer is stuck and will not eject, I can hear it trying when I press eject button, any ideas???
good day. well if some kinda stuck you should open it manually. you can find a little hole on the cd changer just use a paperclip then insert it to the hole it will be open manually. and hope that it will not trip right after you put the cds again. hope this helps
Feb 04, 2010 | Car Audio & Video
My cds won't play and they will not eject. I have an in-trunk cd changer.
If your radio works and you press mode .Does head unit recognize cd,s
It should display no cd,s cd error etc
The reason i ask this is to confirm that connection is ok to stacker
To eject PRESS AND HOLD eject button,insert credit card under cartridge,push fully in and move left/right untill eject
This will locate micro switch,so you can check discs
Jan 25, 2010 | 2004 Mitsubishi Endeavor
The cd changer won't eject any cd's - shows "CD error". How can I get it to eject? Also - the cigarette lighter in the center console does not work so I can't use my charger. I know there is another on the...
If you have a stacker /changer
Push fully in and move left/ right.
This will locate micro switch and release cartridge
Dec 26, 2009 | 2003 Ford Expedition
Cd player in ford expedition quit showing CD
If you can not eject cartridge
Press and HOLD eject button insert credit card or similar under cartridge.Push firmly in and move left to right untill it ejects,this will locate micro switch.
The fuse is located on the back of the stacker,this is ok because your head unit recognizes stacker.
Nov 14, 2009 | 2003 Ford Expedition
I have a 2003 E46 and the CD changer will not eject the CDs. Is there a manual eject?
Make sure cd changer is recognised on display on dash using mode on radio.This means it has power and correct connection.Next hold eject button on changer and insert credit card under cartridge,move left to right .This will locate micro switch and release cartridge.
Oct 06, 2009 | 2003 BMW 325
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
Car Audio & Video Logo
57 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
