Slow To wake-up
Hello there,
When I put my computer in sleep mode, it sleep like normal computer.
But when I try to on it back it do not respons
I can hear the fan and the light also is on but there is nothing on my screen.
Each time I try to put my computer in sleep mode, this problem will happen.
This is my computer desription:
Acer Aspire M3600
Windows Vista Home Premium
Intel Pentium Dual Core @ 1.6 ghz
1 Gigabyte RAM
Phoenix - Award BIOS v6.00PG[American Megatrends (AMI)]
My Display Description:
Name: Intel(R) 946GZ Express Chipset Family
Manufacture: Intel Corporation
Chip Type: Intel9R0 GMA 3000
DAC Type: Internal
Total Memory:251 MB
Current:1440*900 (32 bit) (60ghz)
Monitor:Acer Lcd Monitor x173W
# I don't know how to check graphic card, so I hope the information is enough. Can you teach me?
  • Anonymous Dec 10, 2008
    my pc desktop does'nt wake up with normal time
  • goatmeat May 01, 2009
    i have the exact same problem ,sure to do exactly what u said.i have a compaQ presario, compaQ pc, windows vista home premium with service pack I want to get rid of this problem.
    Problem Solver:
  • 6 Answers
Just replace ur CMOS battery & reinstall the os with NTFS file system.ok
Posted on Apr 03, 2008
Monitor slow to wake up
A computer uses sleep mode to save power and save certain key functions so that users can resume work quickly without waiting for the computer to completely restart.
There are usually at least two types of sleep modes: an ordinary mode in which the current state of the computer is kept operational, and a deeper hibernation in which current settings are saved to the hard drive.
When a computer does not leave the sleep mode, there is most likely a problem with power settings.
Power Button Use
Some sleep modes, especially the hibernation modes, remove the ability for the computer to sense outside movement.
If the user puts the computer into hibernation, then typing on the keyboard or moving the mouse will not wake it, even if these actions work in a light sleep mode.
The only way to wake the computer up is to press the power button.
Power Settings
Computers have power settings that tell them when to perform certain actions, including powering down and going into sleep mode.
Normally, computers will do this automatically when they have low battery power, but if the settings are changed it is possible the computer will only exit sleep mode when connected to a power adapter.
Users can change power settings themselves to more appropriate levels, if necessary.
BIOS Settings In BIOS (basic input/output system) mode, a PC shows not only the last actions that triggered the computer to go into sleep mode, but also what wakes the computer up from sleep mode.
Typically several devices, including keyboard and mouse movement, are listed.
However, if the computer is not programmed to wake up from sleep mode when these devices are used, it will stay unchanged. Users can add or remove devices from the BIOS system itself.
Vista Problems
Microsoft Vista has been known to develop several errors associated with the ability of the computer to wake up once it has gone into sleep mode.
If the user has Vista, it is possible an internal error, possibly connected with the USB ports, has caused the computer to remain in sleep mode.
Users can fix these malfunctions by downloading "hotfixes" from Microsoft's website.
Video Card or Screen Problems
If the monitor refuses to wake up from sleep mode but all settings appear applicable, then the problem could be with the video card or the screen itself.
In this case, the computer is resuming activity but the monitor cannot show it, so it looks like it is still asleep.
The user should make sure the monitor is working properly and make sure the video card is not malfunctioning.
You should also check ram Hard Drive & vga lead
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd and floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
Check your RAM.
The RAM is located in the middle of the motherboard.
There are tabs that you can push to release the RAM.
Remove it and put it back in place until the tabs pop out.
Loose RAM can cause your computer not to start properly where you want to see a video signal.
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
Make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
Restart your computer then reinstall it this should activate found new hardware wizard
Check the vga lead for secure dust free connection or try another vga lead.
Aug 11, 2013 | HP Computers & Internet
Trouble coming out of sleep mode
enter the bios on startup and there should be an option to wake on mouse or keyboard
Mar 26, 2013 | HEWLETT-PACKARD Touchsmart IQ526 PC...
HELLO, I have Princeton VL1919 monitor. Recently, the monitor is in the sleeping mode and does not display anything from computer. How can I wake it up?
If your trying to wake your computer/monitor up try pressing a button on your keyboard or move your mouse. This should wake up both your monitor and computer.
Mar 15, 2011 | Princeton Digital Computers & Internet
Have a problem with my computer. I clicked on sleep mode and it turned off, but when I tried to wake it up after about 5 -7 minutes, it gave me a sign that said ?No signal ?..?something.? I don?t know how...
Hello
1st try clicking mouse and moving it around.
2nd turn monitor off then back on.
Last unplug pc and monitor from all power for a minute or two to reset motherboard.Plug back in and start up pc.
Should wake it up.
You may get a notice the windows did not shut down correctly,just choose to start windows normally.
Hope this helps.
Jan 23, 2010 | Acer Aspire L100 PC Desktop
I am running a model 1045 on VISTA. The sleep key puts my computer to sleep but what key wakes it up?
Normally when you put your computer to sleep with your keyboard you only have to press a key on the keyboard to wake the computer again.
I normally use my spacebar to wake my pc but any key should work fine.
Kind regards!!!
Jan 06, 2010 | HP Multimedia Cordless Keyboard/Mouse...
Waking from sleep mod
Hello
The hinge is a very fragile part of the Macbook. In the hinge goes all the video and sound cables, as well as the backlight power. You can have a hardware problem here with your connectors.
However the sleep mode can also take its time to wake up:
- The hard dive needs to wake its 5400 rpms - The system has to wake - The video has to wake
I would think that a fast internal hard drive, as a SSD drive for example, will wake up much faster.
Hope this helps
Aug 04, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Computer won't wake after sleep mode
there is no other solution part from this..............all brand follos the same procedure to come out of the sleep mode do not worry.................................Sameeraryan
Jan 13, 2009 | Sony VAIO VGN-FW230J/B Notebook
Sleep button
u have to aigain press ur sleep button tehen he will be wake uo
or power off ur pc & restart its
Mar 31, 2008 | Labtec 9675120403 Keyboard
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
Computers & Internet Logo
884 people viewed this question
David Payne
David Payne
