Question about Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator
Fridge is warm, Freezer working ok
Do we get it serviced or what things could we try first before we call the service man in.?
Thanks for your help
  • Anonymous Jul 28, 2008
    Experiencing the same problem, no cooling in fridge section and freezer working fine? Lowering the temperature controller in fridge section made no difference. Let overnight to check not due to opening door to often.
I had the same problem , you have to clean your freezer compartment out completely and take the covers off the inside back of the freezer being carefull not to break any wires, then defrost the cooling module by hand hot water towels messy job.
Make sure the cooling sensor is attached in the right spot and hasn't fallen down, it has a plastic holder it clicks into.
once clean and defrosted put back together and it will be fine...
Try not to put any frozen chip bags or peas etc right at the back of the freezer this causes the cooling system to freeze up.
How the system works it blows cold air from the freezer compartment down to the fridge to cool it and when the system freezes up no cold air to fridge ,hense the problem you are having...
If you are not confident in doing the job you can call a fisher and Paykel tech and they will charge you $150 to do the job.
Posted on Oct 24, 2008
Called out F&P engineer, cause was suspected to be leaving freezer door slightly open overnight (not enough to set off alarm, but ajar) - result is system freezes up and typically damages one of the internal components/fittings. This is a known fault and the engineer replaced the part with a more reliable component.
Posted on Aug 31, 2008
Freezer stays cold. Why is fridge part warm?
if freezer gets iced up the fan designed to pass cold air from the freezer to the fridge stops working. The freezer is meant to go into a defrost mode when its trtansducer senses too much ice. If the transducer goes fault the ice builds up. Some fridges use a timer to work this out so it could be a timer fault. Talk to a service man about how much ice the freezer should have for them to sucessfully diagnose the fault. Too much ice may prevent the service man from working out if temperature sensor is working and no ice can prevent him from testing sensor. To get rid of ice you have to trun off the power to the fridge and let it melt.
BEWARE remove food to another freezer and fridge to prevent food going off or getting food poisioning
Sep 17, 2015 | Estate TT14DKXKQ Top Freezer Refrigerator
Hi My fridge is 5 year old ,at present the cooling is poor ,only the upper door gets cooling but not frosting the cubes .what the problem would be ,the service man says that we have to refill tha gas and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 01, 2011 | Whirlpool Refrigerators
Fridge freezer freezer ok fridge warm willnot chill
dear sir/madam
i think there can be possible low gas problem it,s naturally if in your freezer there is low gas then it,s coil get warm. it,s coz of low gas so please contact to your service technician for find out leakage and brazing it and then refill the gas. i hope after that your freezer will work well.
hope answer the question
thank you
please vote!
Aug 30, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Refrigerator compartment is warm around 20 centigrade and have foul smell. Freezer is OK.
Hi!!
Have you checked the temp. controls? Sometimes they get moved by accident.
The next thing to inspect is the freezer fan motor. This motor is the one that blows cold air from the evap. in the freezer to the fridge compartment.
If both things are OK, have the fridge serviced asap.
Good Luck!!
Mar 15, 2010 | Refrigerators
Freezer works great, fridge not cold. about 60 degrees in fridge. had repair man look at the fridge, said the mother board, was bad. panel inside freezer iced uped. fridge seem to get better for about 2...
And you are posting because,.......????? You are looking for a second opinion? Don't like the repair estimate?
1. Your freezer is not working great. If it is frosting up, frozen packages will soon beging to soften also.
2. All of the cooling takes place in the freezer compartment. A fan blows air over the coils in the freezer, and directs some of it into the fresh foods side to cool it. When the coils become blocked with frost, the air can no longer flow into the fresh foods compartment. Result is warming of FF area. You may also see freezing in the bottom FF bin, water dispenser not working, FRZ section warm, etc.
3. Manually defrosting the coils will temporarilly solve your problem, but it will reappear in a few days to a week or so. (depending on door openings, ambient temp, etc)
4. The motherboard controls the defrost interval and (although not the most common) certainly can be a cause of defrost failure. If a qualified servicer diagnosed it as such, it most likely is just that.
Sep 16, 2009 | GE GSH25JFR Side by Side Refrigerator
Coils in freezer ice up and fridge gets warm
it could be 3 things...deftrost heater, bi -metal thermodisc, or defrost controller.
Jun 27, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator freezer
Hi bb
The warming of the fridge is not to worry thing and about the freezer you should do some defrosting work time and again .
this would help in defreezing a bit .
and if you want it to get less warm turn it off for a little time.
Feb 16, 2008 | Freezers
Fridge side not cooling, Freezer side is....
(After trying FixYa and paying for the premium service -- during which error codes were not even discussed) I called a service tech. Turns out it was the fan above the fridge side (which explains why the freezer was still working fine) that was "humming" but not always spinning. A quck swap of the fan and we were back in business.
FYI -- The SubZero tech said it was very uncommon for the fans to go bad.
Feb 08, 2008 | Sub-Zero 690 Side by Side Refrigerator
Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator Logo
435 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
