Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water hose too short
We just bought a GE side by side but the water hose is too short to reach the water connection. Also, the connector at the end oof the hose is a "male" end as is the wall connection. What do we do?
  • Newhousehelp Apr 01, 2008
    Thanks! I guess we'll try home depot. we went to lowe's and no one knew what we were talking about :-(
    Genius:
  • 1,554 Answers
There are retail kits for these at home depot , builders square or such to extend and connect these correctly.you might want to get a filter while you are shopping for kit.
Posted on Apr 01, 2008
  • Karl Whisenand
    Karl Whisenand Apr 01, 2008
    The hoses are clear plastic and shrink wrapped in kit package
    but you can mix and match on the shelf bin items to build your own . and purchase the hose by the foot.
    or you can purchase the copper and fittings if you choose.
    and a filter would be a good addition . not to stress it too much.
    it keeps the sediment and chlorine from eating up your tray mechanism.
Need help, I have a 2001 Chevy cavalier 2.2 L..It hs been over heating, can't find the leak. Put water in it and it is bone dry real fast.We took out the thermostat and let the car idle for a while,...
Dear, check water leakage from the heater's radiator. For this, disconnect water circulation to the car cabin heater.
There are two water carrying hoses for the heater, one is to carry water to the heater and the other one is to carry it back to engine. One end of these two hoses is connected to the engine side and the other end of these hoses is connected to the heater side.
You have to disconnect any first hose's end from the heater's side and second hose's end from the engine's side.
Now connect the hose end, which you had disconnected from the heater
Aug 31, 2011 | 2001 Chevrolet Cavalier
I just bought a Midea MDF!-30AEN3-BA4 dehumidifier and connected the continuous drainage tube to it and it still fills the water tank rather than dumping out the hose. I have tried it with the water tank...
If the hose is longer than 5 feet, that's part of the problem. The hose must slope down and straight to a floor drain. It relies on gravity to drain.
Although you just purchased it, the hose connector and inner tubing may be clogged. This is another reason water is diverted to the bucket. Turn the unit OFF & unplug it.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hose connector and tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reconnect the hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you the hose for water flow. It may take 5 to 10 minutes for water to appear.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
Hope this helps you to troubleshoot & solves the problem. Thanks for choosing FixYa.
Aug 15, 2011 | Midea MDC-45AE Dehumidifier
The hose stopped draining the water. How do I reset?
It's not a question of how to reset the unit. It's a question of how to unclog either the hose or the hose connector tubing inside the unit.
The hose is easy to check and unclog. Turn the unit OFF and unplug it. Disconnect the hose from the connector and either look thru it or blow thru it. If you see light at the other end of the hose or air blows thru freely, the clog is not in the hose. It's in the hose connection tubing.
Using an 18" long, plastic Zip Tie, that's appropriately sized to fit in the hole of the hose connection. Carefully insert it unitl it reaches a bend in the tubing. Gingerly work it past this bend, until it either bottoms out or you run out of usable Zip Tie. Slowly pull it out while rotating (twisting) it. This will dislodge any clogs. As you reach the inserted end of the Zip Tie, be prepared for some water to follow.
If you don't have an 18" long Plastic Zip Tie and don't want to run out to get one, you can use something similar that is flexible and log enough. DO NOT use a wire coat hanger.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 28, 2011 | GE AHG50LB / AHG50LD Dehumidifier
Bought a Hoselock Hose Reel today and cant figure
You need to purchase a Hoselock tap connector. There are two basic types, one has a thread that screws on to a theaded tap and the other type is a compession fitting that can be secured to most other taps.
The full range of connectors can be found on their website
http://www.hozelock.com/watering/hose-fittings/connect-to-tap.html
Mar 16, 2010 | Hozelock Garden
Ge profile does not seem to be getting water to dishwasher. water supply is ok.
HI. This is a water inlet valve issue. I recommend testing this device. it may be faulty.
To access the inlet valve remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel. The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow. There are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced. Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. If your valve has two solenoids, test the second one in the same way as the first.
NOTE_ IF the water inlet valve passes the above inspection, simply replace the floater switch
Jan 02, 2010 | GE Dishwashers
A hose is leaking on G.E. fridge - to water dispenser, I think
It sounds like someone has repaired this hose , due to the connectors . There should be no connectors except for 1 , below the freezer door . This hose can get hot from the compressor heat , and break .
My suggestion , would be to replace the water resivoir in the refrig section , behind the bottom crispers . This resevoir has a hose that goes completely to the water valve , without any connectors , and a hose that goes to the coupling under the freezer door , for the water dispensor . If you remove the bottom kick plate , the hose from the door , goes about 8 " to the coupling which connects to the line from the resevoir .
Sep 28, 2009 | GE Refrigerators
After 3 years we have ice but no water from the dispenser
Remove the bottom kickplate and the hose at the bottom of the door goes underneath the refrig about 3 inches , to a hose connector . Push in on the end of the connector and pull out the hose . Close the freezer door and press water . If water comes sprays out from hose under frig , then your door is frozen internally .If no water sprays out of hose , then your watervalve is bad . One coil is for ice and the other is for water but they come togather as one.
Jul 18, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
My air conditioners is a everstar model mpa-08cr, and i need to instal the water hose on the side of unit.
Hey there, just follow these simple steps then you'll be on your way
To connect the continuous drain option. Remove
the water tank from the cabinet. Inside the
cabinet (water tank area) you will find a section of
hose hanging beside the water tank, which is plugged
at the end. Remove the plug
from the end of the hose and install the drain hose connector
(included with this unit) into the
end of this hose section. Route the end of the
hose (with drain connection) into the water tank,
then through the hole provided in the face of the
water tank. Attach a section of garden hose (to
suit your continuous drain option requirements)
to the drain hose connector. Place the open end
of the hose directly over the drain area in your
basement floor.
Please make sure the drain hose
section routed through water tank does not interfere
with the correct positioning of the water tank inside
the cabinet, or the will fail-safe switch mechanism will
be activated, not allowing the unit to operate.
Jun 19, 2009 | Danby DPAC8020 Air Conditioner
Slow cold water
1.) turn off water valve that supplies cold water to washer.
2.) unscrew the cold water hose-type connector immediately next to the set of 2 water connections in back of unit.
3.) look into the hose you just removed or into the water connector on machine. you will find a metal screen (like a window screen) that is cone-shaped...if none found then remove hose connection at other end of same hose...remove it and then clean it thoroughly and then re-assemble all.
Nov 28, 2007 | Maytag Atlantis MAV6451 Top Load Washer
GE (PSS26MSRSS) Side by Side Refrigerator Logo
55 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
