PT-52LCX35 Panasonic How do i fix the problem of the temp light flasing 5 times in 5 seconds and turning the TV off.. How do i self service this problem with the filters and where are they? Service wants me to bring in for 6 $600 to clean. I am quite handy how do i do this myself... Thank you in advance "V"
  • 3 more comments
  • JohnnySparks Jul 20, 2008
    Hello, I have been experiencing the same problem with the temp light blinking 5 times then turning the set off. My repairman thought it was a loose thermol connection. But the problem still remains. repairman attempted to order parts to repair including thermal fuses and some board for something, only to find that Panasonic no longer makes the required parts to fix it. This problem has been happening for two months now. still waiting for word from from my warranty service in their attempt to find the parts...
  • Anonymous Dec 09, 2008
    happened to me call panasonic it has to do with sea level and air pressure some how trying to fix tonite but dont have the right remote
  • tabass1 Dec 13, 2008
    Mine started with yellow, now I get purple and red splotches as well, now I am getting some color squiggly lines on the actors faces.
  • mmwood20 Feb 07, 2009
    The temp light flashes 5 times. Tv says the filter needs clean. I took off the back and never saw a filter. I clean the inside and still have the temp light and the tv auto shuts off. How do you fix this
  • sabposey Feb 21, 2009
    Our Panasonic 52LCX35 says clean filter....does anybody know how to do this? I downloaded owners manual and for this warning it says contact service. Thanks!
I think i have found the fix
I kind of feel dumb for all the mess i have gone though to get here and if im right it is soo simple
Dont buy a panasonic haha jk
Directily under the panasonic logo is ur air filter
Pull off you speaker cover at the bottom of ur tv
Then directily under that log is a pannel with two screws
Take that off
now take can air and blow out the foam u see on your optical lense
top and bottom
be careful the optical lense cost $800 so dont turn ur caned air upside down
this is what i finaly did and so far so good
it has taken me over a month of taking my tv apart every night to see what was right infront of my face i hope this helps everone
Posted on Apr 03, 2009
  • tlclandscape Apr 03, 2009
    please excuse my spelling in my post but i hope i helped
I have a panasonic PT-52LCX35. Everything is working fine except for one thing.
There are patches of yellow on different parts of the picture being displayed.
Tried to adjust in the settings did not do any good.
Could this be a problem with the lamp?
Posted on May 10, 2008
My 52 inch panasonic rear projection TV has yellow spots or shadows.
Posted on Jan 28, 2009
  • 3 Answers
Eat poop out of your ****
Posted on Jul 16, 2009
Where is the air filter located on panasonic tv PT-52LCX35
Download the manual. It should tell you there. You may need to locate the Repair and maintenance manual, not the user manual (and surely not the quick guide)
Oct 24, 2015 | Panasonic PT-52LCX35
I have a Panasonic Model PT-50LC13 flat TV. Was working when got it brought it home, it is used and now when I go to turn it on --- we get a green light then a flash of 5 yellows blinks then no light for...
This tv has 3 indicator lights on front, Power, Lamp and Temp
I assume Temp light is blinking 5 times after every 5 seconds, if that is correct then it is problem of clogged air filter located in light engine that need to be cleaned.
Below is an image of light engine and air filters locations are marked with red circle, it is job of professional to fix this issue because complete light engine need to be take out from tv cabinet.
Hope these info will help you, let me know if you have additional question or need service manual copy if you want to repair tv by yourself.
Thanks.
Nov 10, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I have a Panasonic 52lcx35. I contacted Panasonic, and they sent a repairman to "repair" the green spots we were seeing (this was the only problem). He did something, and afterwards, the tv only turns on...
amber weaver,
It sounds like the repairman forgot to reconnect one or more of the fan motors. There are several in these units and if not connected you will get the error you mentioned. Unplug the unit and remove the back. Locate all the fans (this may take some time to make sure you have them all).
There could be 3 or 4. Check each one's wire to make sure they are all connected to wires or an appropriate board. If this is your problem this should solve it.
Thanks for using FixYa and for the great rating!!
hardrocko
Aug 23, 2010 | Panasonic PT-52DL10 52" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I have a pt-52lcx35 and there are lines of either green or orange that appear and move about in various locations on my screen
YOUR TV HAS A CORRUPTER MICRO CONTROLER
YOU MUST GO TO A SERVICE CENTER THE SERVICE CENTER WITH A SPECIAL TOOL THATS AVAILABLE BY PANASONIC WILL REPROGRAMME YOUR EEPROM THIS SHOULD NOT COST MORE THAN 100 DOLLARS IT IS NOT NECESSARY TO OPEN TV
Jan 22, 2010 | Panasonic PT-52LCX65 44" HDTV
My 52" PANASONIC PT-52LCX35 does not come on after a power surge went off due to lightning. I press the Power Button to turn TV on, but green light just blinks a few times then stop without any sign of...
Remove the Lamp and look for a white fog inside. It is bad if it looks that way.
If thats not it, Call a good TV Tech to troubleshoot the problem. Lightning can do about anything to electronics.
Jul 29, 2009 | Panasonic PT-52LCX66 Projection Television
On my pt 52lcx35 it says the lamp hour meter needs to be reset.
press the down volume on the tv at the same time press the up dvd/vcr split button on the remote. do this for at least 5 seconds and it should reset
Apr 02, 2009 | Panasonic PT-52LCX66 Projection Television
Tvscreen is all orange
Hey Missfire1, try following these steps to see if they fix it.
1) Unplug Everything from your Television.
2) Wait 60 seconds and plug Everything back in.
3) If that fails, then Try restarting your television by the Buttons located on your TV, or by the Remote Control.
Hope this Helps. - Evolution
Jul 14, 2008 | Televison & Video
Repair on problem blue dot
Good Day, flavrlen;
This is your fix it is not costly and if you handle a screwdriver you can do this in 30 minutes:
PANASONIC:
MODELS: PT-44LCX65, PT52LCX15, PT-52LCX65, PT-52LCX35, PT-61LCX65,
PT-61LCX35.
SYMPTOMS: 1. FUZZY SPOTS
2. FUZZY SPOTS
3. FUZZY SPOTS WITH STAINS
4. FUZZY SPOTS & UPSIDE DOWN
5. FUZZY SPOTS WITH LINES
CORRECTION: SYMPTOMS CAN BE CORRECTED BY EEPROM
CORRECTION TOOL; (LSUQ0100).
Good Luck, big IRISH.
Jul 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic 52lcx65 52in projection tv
I have the same TV had the same problem while under Warranty Panasonic tech replaced the lamp
Apr 15, 2008 | Panasonic PT-52LCX65 44" HDTV
Televison & Video Logo
1,596 people viewed this question
Top Televison & Video Experts
