Question about Dell 1720dn Laser Printer
Beeping noise Whenever we print a page, there's a loud "tone" or "beeping noise" that the printer emits. We have already returned one printer and the new one does the same thing. Is there a way to turn this off? It doesn't need to make noise-it's a printer!
  • 1 more comment
  • Anonymous Jun 05, 2008
    Same problem here.
  • Richard Lilja
    Richard Lilja May 11, 2010
    I checked the Dell website and there is no mention of anything that would create noises on that model printer. Is the noise that you hear the from a speaker in the printer? or from a mechanical type source?
  • Diana Lynn Feb 18, 2014
    I've had the Dell 1720dn at my desk for years. Worked flawlessly. Moved it to a different workstation and it began beeping immediately while printing. Another site said to plug it directly into the wall, instead of a battery backup. I unplugged it from the battery backup outlet, and plugged into a surge protector only outlet on the same battery backup unit.... NO MORE BEEPING. Hope this helps someone else.
Posted on Feb 18, 2014
    New Friend:
The beeping you hear is from your surge protection (ups) not the printer in my case. I have an apc ups and moved the plug to "surge protection only" port and everything working fine. the batter backup isn't strong enough to handle the load of the printer.
Posted on Mar 29, 2014
  • 49 Answers
This beeping noise cannot be silenced. Sorry to tell you. Just a bad design.
Posted on Feb 27, 2009
SOURCE:
My Canon MG8120 all-in-one makes a loud noise when copying (not when printing). How do I fix it?
Dear
from the question I understand, the scanner move to right and during return it starts noise.
The problem with scanner assembly, It might be dust accumulated on gears, the scanner belt might have loose or the grips of the belt has worn out. Proper cleaning and lubricating the moving parts may overcome also if the belt worn out it has to be replaced.
In case of at home position it gives noise then the home position sensor may dirty/dusty, it has to be cleaned.
thanks.
Feb 15, 2015 | Canon Pixma MG8120 Wireless Photo...
Hp 2200dtn prints fine but makes loud friction noise
Old age printer, Remove right,left, back & top doors. check fuser assm screws tighten or slacked? if its slacked use more lengthy screws for tighten the fuser.Apply grease for the gears to avoid the friction. Open main motor assembly clean entire gears, lubricate & fix it back..Check any gears are warn out, replace it if possible...Best of luck..
Jan 04, 2012 | HP LaserJet 2200dtn Printer
My printer emits a long beeping noise when printing documents
This sounds to be a faulty Primary Charge Roller in the cartridge. Easiest way to diagnose this as the problem is to replace the cartridge. If the tone is the same with the new cartridge then it is another issue. If it goes away then it will be to do with this.
I personally use an empty cartridge to test this since it is usually on hand.
Jun 21, 2011 | HP LaserJet P3005n Printer
Samsung CLP-310N when printing it is very noisy
most probably the printer fuser unit is giving you the noise...
Jun 21, 2010 | Samsung Office Equipment & Supplies
Making noise
Hello tregster,
Is this the first time this happened or has this been the case ever since?
If this has been the case ever since, the beeping sound may just be an indication that the printer is preparing itself to print.
You can also try to check the ink casings if they're properly connected to your printer.
Hope that helps.
Yours truly,
Art Pena
Nov 20, 2009 | Brother Office Equipment & Supplies
Kenmore HE3 washer emits steady, constant beeeeeeeeeeeeeep
Depending on how your washer controls the beeper, it could be a stuck relay or a fried transistor.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Noisy operation and black marks on left side of printed paper
vacuum out the waste toner passages that lead from the drum and transfer belt to the waste toner container. Toner is building up inside the transfer belt and/or drum and has no place to go except onto your paper.
Nov 06, 2008 | Samsung CLP-510 Laser Printer
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Defective brand new cartridge or defective printer
please give the suggestions for colour printing in samsung- 4200 printer
Dec 26, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Scanner bar jammed by cartridge allignment
Any fix for this I have the same issue?
Dec 11, 2006 | HP PSC 2110 Color Printer
Dell 1720dn Laser Printer Logo
684 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
