Question about LG Refrigerators
LST243C-2 Air COnditioner
I have an LG LST243C-2 air conditioner in my unit. The previous owner did not leave a manual. They air conditioner appears to be working but does not cool. I would like to try cleaning the compressor, but do not have the instructions. Can you provide these or suggest other reasons why it may no longer be cooling even though it appears to be in working order otherwise. Thanks.
fridgetech
  • 473 Answers
SOURCE: Freezer works; fridge side doesn't
First thing to check is look and see if there is  thick frost build up on the back lower panel inside the freezer?  If not there must be a problem in the damper (vent).  Let me know what you find so I can help.
Posted on Oct 21, 2007
fanny
  • 146 Answers
SOURCE: LG fridge suddenly stopped cooling.
If the fan inside the freezer is running and the compressor behind the fridge is running and is hot to touch, you have a gas problem or the compressor is inefficient. This can only be confirmed by connecting refrigeration gauges to the gas system and should only be performed by a fridge tech.
Posted on Nov 04, 2007
proJekttaLon
  • 91 Answers
SOURCE: the air conditioner is not giving coolness
Try adding more freon. Over time you will eventually need to add more. I would try this first one can at a time.
Posted on May 24, 2009
  • 54 Answers
SOURCE: Danby DAC5020 Air Conditioner fan works but not compressor
It could be as simple as being low on refrigerant. Depends on how expensive the unit is if its worth recharging and how big the unit is. Some small units will need to have a recharge point fitted which cost more of course.
Posted on Jul 02, 2009
jim9813
  • 124 Answers
SOURCE: 1998 Crown Victoria air conditioner
Fuse 9, 50A under hood, Fuse 5 15A Instrument panel. If they're ok, make sure the compressor clutch can be turned by hand (engine off, obviously). If not replace the compressor. Most common problem is the cycle switch. That should be the electrical connector on top of the accumulator. Just jump that by backprobing the connector on both sides with a pinand connect them, with the car on and a/c on if the compressor clutch engages, replace the switch. If it doesn't, try wiggling wire harness and watch it, if it engages, find a broken wire and repair it.
Posted on Aug 11, 2009
Lg unit showing fault
Look at my website www.60cubits.com. You need to find the owners manual. I can help you find one online if have a model number for your LG air conditioner. Without the manual, there is no way to know whats wrong.
Jun 27, 2013 | Heating & Cooling
Air condition unit is not cooling
looked if it works in the outdoor unit if the compressor is not replaced pyknoti.an again does not work then you should buy a new air conditioner.
Apr 20, 2012 | LG Heating & Cooling
My air conditionner is not working properly. It sends cool aire keep getting code E3 What can I do to fix it Tks
micheline, according to the LG Owner's Manual for the Model Number you listed, there is no LED display on the casement window unit (please see the Owner's Manual link below). How are you getting an E3 error code? Or by chance, did you list the wrong model number? Even Goldstar, that is made by LG, doesn't show your model number.
Please advise. Thanks.
Jun 01, 2011 | Goldstar LG LC1200 Casement Air...
Hi I manage a rental property in Mawson lakes with a ducted Mitsubishi R/C air conditioner, model number PUHZ PAR21 MAA (BP100VHA) The new owner has been unable to access the service manuals etc as the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the Mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Sep 14, 2010 | Mitsubishi MS12TN Air Conditioner
Do you have to add water to the air conditioner?
NO
if its an air conditioner not humidifier etc, then no!
it will create condensation which can mislead people into thinking it has a leak, this is normal. it is only moisture taken from the air we are cooling
cheers
Jul 05, 2010 | LG Goldstar GWHD5000 wall/window Air...
24000 BTUs LG split air conditioner external unit board leds flashing. What does it mean?
Hi; Look into Your owners manual for troubleshooting codes. If You dont have a manual call or google the manufacturer...alpharome416
Jan 19, 2010 | LG LM-2430C2L Cool Mini Split Air...
I have a ch-2 code on a lg air conditioner and curious what is the problem or how to fix it
HI; Look In Your owners manual. If you dont have one goggle the company, pull up on front cover then out be very gentle. Info for company is on a data plate. The company will need the model and serial numbers..alpharome416
Jan 18, 2010 | LG LP120HED Wall/Window Air Conditioner
I HAVE MISLAID REMOTE CONTROL INSTRUCTIONS TO CHANGE FACILITY REQUIRED IE COOL, OR HEAT
You can download the owners manual; here is the link for it.
http://www.generalmanual.com/Air-Conditioners/LG-LA121CNP-Art-Cool-Air-Conditioner.htm
when you get to the page scroll down and you will see Download Now and under that "Owners Manual" just click on it.
I hope it helps.
May 27, 2009 | LG Art Cool LA121CNP wall/window Air...
LG LST243C-2
- Check your air filter at the indoor if clean.
- Check your evaporator fins if clean.
- Check if no icing in your evaporator and outdoor pipes.
- If your air filter and evaporator fins is clean and icing is present then your unit is under charge.
- When your indoor drips check your drain pipe if there are water comes out. If no water drain from your drain pipes then your drainage is restricted.
- Flush your drainage with water using your garden hose to flush out dirts from your drainage.
Jan 14, 2008 | LG LSC121PMA Split System Air Conditioner
LG BG8000ER Air Conditioner Problem!!
go to ca.lgservice.com find find owner's manuals under quick links and then fill in your product information to obtain a copy of the instruction manual.
Jul 31, 2007 | LG BG8000ER Air Conditioner
Refrigerators Logo
97 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
