Question about E-Machines eMachines Desktop PC
E drive runs wild
Ok....we're on the computer...just doin our thing....when all of a sudden we hear this loud noise coming from the tower.....and it makes a sound much like a drive is running in high gear....and the only way to get it to stop is to shut down the computer completely.....we have an emachine and are running windows vista.....it just started doing this and i have had it for a year and a month.....now i don't know if it's the e drive or not....(and i am assuming that the e drive is where you put in cd's when you want to burn one)....but it sounds like that's what it might be....please help....jeneviev3@verizon.net
    Genius:
  • 1,027 Answers
Take all cd's out. it seems the system by default is looking for information on the cd and if it is a 52X cdrw than that baby is gonna spin.
Posted on Apr 01, 2008
High pitch grinding noise coming from motor when starting idling or driving
Seven ways to pinpoint that high-pitched, whining noise
www.losaltosonline.com/special-sections2/sections/on-the-road/45742-
Oct 2, 2013 - I recently had new fan belts installed after hearing a high-pitched, ... Do you hear the noise when the engine is running and the vehicle ... Just replaced water pump (and timing belt) yesterday and squeal ... When driving it make a noise but change out and caught speed the noise is coming from driver side.Missing: 1999 ‎plymouth ‎breeze
What is causing that irritating noise? ' DSMtuners
Troubleshooting Strange Sounds Coming from Your ...
www.dummies.com/.../troubleshooting-strange-sounds-coming-from-yo...
You hear a high-pitched squeal that stops when you shut off your engine: Readjust or replace the belt. These belts should have about half an inch of play and ...Missing: 1999 ‎plymouth ‎breeze
Nov 25, 2015 | 1999 Plymouth Breeze
Hp 1018 printer making really load grinding noise and not printing
ok first try restarting your printer, then try uninstalling the driver for your printer off your computer, restart your computer and printer and then reinstall your drive for the printer, see if you get a replacement for your printer or a refund
Dec 01, 2014 | HP LaserJet 1018 Printer
When I plug my drive into my computer, it doesn't work. When I listen closely (this isn't a loud noise) I hear the drive trying to start, then a two tone sound. It then tries to start again, then I hear...
seal it tightly with nylon put it in freezer for about an hour or so ,the remove nylon and connect it to your PC, with some luck hopefully it runs OK, other thing can be done that you replace controller board for faulty HD with exact same one from exact same working HD
Oct 02, 2013 | Western Digital Computers & Internet
My 1984 mustang only has 60,000 miles. When i put my car into drive I hear a loud noise coming from the engine. it has enough oil, its not the brakes, or driving belt. the car drives fine, like nothin
Not much we can do without knowing where the noise is coming from. It could be something rubbing because the engine is shifting. It could be moving around when in drive such as a weak motor mount. Or the crankshaft could be moving under load.
You may need to have a friend watch the engine from the side to see if anything is changing when you go from park to drive. You can also use a section of hose as a hearing device to pinpoint where the sound is coming from.
Apr 24, 2013 | Cars & Trucks
Loud noise when driving on the interstate, so loud...
Where is the noise coming from? If it is coming from your wheels then it would be your wheel bearings. They can get so loud that you cant hear a thing inside your car due to vibration.
May 20, 2010 | Cars & Trucks
I have a Lenovo A61 Thinkcentre that is about one year old. I am now hearing a fairly loud noise that comes and goes. When the system starts, the noise appears and lasts 10 - 20 minutes, then disappears....
Ok it still sounds like an fan. look for fans, one in power supply, one on cpu, one in case(frount or back), one on video card. before you start from cold unplug the fans that you can. and stop the one in power supply. then if there is no nosie you have to start pluging them back in till you hear the noise. **NOTE!!** don't run it long without fans!!( 40 secs) is long enough..
Feb 26, 2010 | Personal COMPUTER - LENOVO THINKCENTRE A61...
1998 dodge ram whine noise..PLEASE HELP
how does the trans fluid look?at proper level?it sounds like the front pump in trans is starving for fluid..filter may be plugged..does it shift ok?any fault codes?i would check these things and probably drop trans pan to see if any debris/dirt/metal in pan indicating an internal problem..i hope this helps
Aug 15, 2009 | 1998 Dodge Ram 1500 4WD
My computer makes a loud noise,how can I fix this problem please?
there are a limited number of things that could be making noises. take off the cover of your computer and listen close when you start it. A fan would be the first thing i'de suspect. check them all- cpu fan- motherboard fan-videocard fan- powersupply fan.
I would also listen to the powersupply (rear top of computer)
only things left to check that could be making noise are the cd/dvd rom, floppy drive (both wont run without a disk in them) and your hard drive which would be the last one to make noise. the hard drive runs everytime your computer moves data, if it is getting loud, i would suggest backing up important files and shopping for a new one. Post again here if I can be of further assistance.
Regards..
Apr 06, 2009 | E-Machines eMachines Desktop PC
Loud humming noise coming from 360
The loud humming noise is usually the DVD drive. It is very fast but is very loud. If you have the NXE dashboard you can download games to you Xbox 360 to run them from the hard drive (you will still need to put in the disk for copy protection issues). The Xbox should make less noise then. Try to mount the Xbox 360 on a hard surface which is in contact with a soft floor to reduce the noise travelling through your home.
If it is making a loud noise while there is no disk in the drive then take the console to a Microsoft dealer whenever you can to have them take a look at it.
Feb 13, 2009 | Microsoft Xbox 360 Console
Loud noise
Typical problem in most computers, the fan is experiencing a "burn out." This means there is either something caught in the fan causing it to create noise, or the motor is going bad. there are two fixes for this problem.
1) open you computer's case according to its manual and remove the system cooling fan and give it a thorough cleaning.
2) you may need to replace the cooling fan with its recommended replacement model.
Hope this helps!
Jul 08, 2008 | Gateway 506GR PC Desktop
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
