Question about Panasonic CT-27E13 27" TV
CT-13R38SG Guest accidentally set vchip password and can't remember what he did? Is there an easy way to fix this or do we need to call panasonic? Thanks, Marla
  • 934 Answers
Parental Lock Feature
Combo's
With unit on and no cassette inside, hold the rec/time button on the front of unit for 7 seconds.
CTV's Lock Mode
Only the on/off button will work,the others have no effect. Press the action and power buttons at the same time on the front of the set for 10 seconds or so.
LCD TV's, Lock Mode
If customer forgot Parental Lock Code, unit must be re-initialized.
Press and hold the Volume down button on the front panel, press the OK button on the remote for 5 seconds.
Bill
Posted on Apr 01, 2008
I need to know how to get the guess acount password for an acer aspire 5050
Reset password > Possible.
'Get password' > Not possible. Native OS design does not provide this function
Quick fix: If you can login as 'guest', do so. Once done, press CTRL +
ALT + DEL and then click 'change password'. Follow subsequent steps. This becomes the account password.
Assuming you cannot login in with 'guest', do so with an account that has administrative rights.
Before proceeding, remember a key principle. To keep protected information secure, after a password is reset on a local user account, Certain information is no longer accessible, including the following:
  • E-mail that is encrypted with the user's public key
  • Internet passwords that are saved on the computer
  • Files that the user has encrypted
Now that we got that out of the way, Right mouse click 'computer'
Select 'manage' | 'Local Users and Groups' | (all in tree on the left)
Select Users folder
Shift focus to the detail pane on right. You should see 'guest'
If the guest account has an icon [arrow pointing down], it is disabled. This is a default setting in most systems. Not a good idea to activate it coz it leaves a door open for hackers.
Right click 'guest' and select 'properties'. On the general tab, you should see a check box next to the line [Account is disabled]
Enable/Disable per your pleasure. Click 'ok' back to main screen.
Right click 'guest' again. This time, select the first menu item - 'Set Password'.
Populate with your desired password. Remember it lest you are doomed to go through the whole process again.
Dec 07, 2009 | Acer Aspire 5050 Notebook
Need code to mate ONE for ALL to tv
if you goto the remote's manufacturers web site you will get the code from there
May 08, 2009 | Televison & Video
Panasonic CT-30WX54 - shut off while watching
The Sleep timer might have got set accidentally. Try that.........
Apr 25, 2009 | Panasonic CT-30WX54 30" TV
Mitsubishi 1080 rear proj. tv
I can help you unlock your Mitsubishi HDTV V-Chip, but you will need an 'original' Mitsubishi remote control for the fix to work.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Feb 18, 2009 | Mitsubishi WS-65515 65" TV
Panasonic color tv model # ct-13r38sg
The problem here is that the vertical IC either has bad connections or is defective. Look for a small flat IC with about 11 pins attached to a heat sink. It will be marked LA7837 or something similar. Try resoldering the pins on the IC first. If that fails to resolve the problem replace the IC.
Keep us posted.
Dan
Jun 02, 2008 | Sony KV-27S65 27" TV
Panasonic color tv model ct-13r38sg 13"
verticle amplifier is not working on your tv
take it to a shop if you dont know.
verticle IC BE CHECKED.
AND ELETROLITIC CAPACITOR feeding verticle scan coil.
Jun 01, 2008 | Sony KV-27S65 27" TV
Vchip was accidentaly set by guest and password was forgotten
For Panasonic:
Combo's, Screen will say VCR Lock Activated.
During stop or power off, hold the stop/eject button on the unit for at least seven seconds.
Combo's, Another method
CTV's Lock Mode
LCD TV's, Lock Mode
DVD's Lock Mode
Setting Method
The sales demonstration lock function is set by simultaneously pressing the "POWER" button of DVD Player on the remote control unit and the "STOP" button on the main unit. ("LOCKED" is displayed when the lock function is engaged.)
Release Method
The function can be released using the same procedure as for setting. If the remote control unit is not at hand, the function can be released by using the same method as for player initialization (pressing the "PAUSE," "SKIP/SEARCH<<"and "OPEN/CLOSE" buttons simultaneously).
VHS-DVD Recorder (DMR-ES40V), Forgotten Ratings Password
From the Owners manual: Open tray, Keep Pressing Rec and Play/X 1.3 buttons on the remote for 5 or more seconds.
Another servicer found resetting to defaults worked well.
(VCR>DVD Dub) + (Open/Close) + (DVD Rec)
Bill
Apr 01, 2008 | Panasonic CT-27E13 27" TV
Panasonic tv help
my tv screen just turned brown. sound and everything else works fine?????
Panosonic HD tv
Jan 24, 2008 | Sony KV-27S65 27" TV
Re: Vchip code
you need is factory setting!
Oct 05, 2007 | Panasonic PV-C1321 13 in. TV/VCR Combo
Panasonic CT-27E13 27" TV Logo
137 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
