Question about Samsung Blackjack SGH-I607 Smartphone
TTY Enabled/Disabled Error
My phone just suddenly started freaking out saying that TTY was Enabled then disabled and wont stop. I tried power cycling the phone but to no end. Is this something that needs to be replaced?
  • 3 more comments
  • Anonymous Apr 27, 2008
    tty disabled keeps flashing.
  • Vkennedy May 13, 2008
    I have done a hard reboot and the tty enable disable still appears for incoming calls and teext messages.
  • Christopher Buchanan
    Christopher Buchanan Nov 10, 2008
    Same exact problem. Out of nowhere it started with messages "TTY Enabled" you click "OK" and it immediately pops up "TTY disabled" you click "OK" and it goes back to "TTY Enabled" and repeats.
    Power off, hard reset did nothing. What really irrating is that there is no setting for TTY, so you can't manually turn it off.
    I just changed out the battery to see if it makes a difference.
  • Anonymous Jan 08, 2009
    Mine just started doing this as well, I spilled a glass of water on it, but the water only got on the screen, idk if that matters, but on the water damage strip it doesnt say there's water damage. Also, my phone will NOT turn off, i turn it off and it restarts itself.
  • jude_Pascoe Feb 06, 2009
    My black jack keeps coming up with tty enabled and then disabled, I cant get rid of it.
I am having the same issue - just started today. The phone keeps saying TTY enabled - TTY disabled and it won't stop.
Posted on Aug 16, 2008
Taco 007 circulating pump stays on even though boiler shuts down
Don't know your specific unit, but in general, heating systems are two-stage devices:
1: Its too cold: the motorised HW/CH valve moved to the required position, and on achieving it, the circulaion pump starts and the boiler is enabled. (The circ pump may start immediately - its not usually important.) The hot water from the boiler circulates through the heat exchanger and/or radiators until the thermostat thinks its target is warm enough, whereupon it disables the boiler, stops the pump and closes/relaxes the valve(s).
2: The boiler is off while disabled. When enabled, it heats the circulating water to a 'high' temperature and seeks to keep it there. If it reaches that temperature, the boiler will cycle on and off as necessary to maintain the set 'high' temperature. (The circulation pump must run all the time the boiler is enabled.) This may be what you're noticing. Additionally, some boilers will run the circulation pump for a little while after being disabled to reduce the temperature if the water in the pipes and boiler.
Your question doesn't say how the pump running corresponds to thee thermostat settings, but if it were stuck on, I think you'd know!
Dec 31, 2016 | Water Heaters
Why my wifi disabled to connect
To verify the wireless network connection status, please go to the Network Connection Window. For Windows XP, Click on Start. Click on Run. Enter "ncpa.cpl" and click OK. For Windows 7 or Windows Vista, go to "Search programs and files" box. Enter "ncpa.cpl" and hit the Enter key.
If you see the wireless network connection icon is disabled in the Network Connections Window, you may double click on it to enable the connection. Should it is still disabled an no way to be enabled, you may have a AntiVirus software (for example, Kaspersky, ZoneAlarm, Trend Micro Internet Security...etc) installed in your computer and it disabled the wireless connection.
You may completely remove the antivirus software from your computer and restart the computer. Check the wireless connection can be enabled. Then you can re-install the antivirus software.
Jan 21, 2013 | TP-LINK Tenda W311R WirelessN Router AP...
Motherboard when tring to load up windows disc wont boot from CD as it continues to say that i have a floppy drive hooked up which there isnt a flopp drive at all hooked up in it when going into the Bios...
When you reboot your system you have to go into the bios,when you start the setup utility, the main Menu appears. the main menu of the setup utility displays a list of the options that are available. a highlight indicates which option is currently selected. Use the cursor arrow keys to move the highlight to other options. when an option is highlighted execute the option by pressing ( good luck!)
go to the [advanced setup] area
1.quick boot - enabled
2.1st boot device - disabled
3.2nd boot device change it to -cd
4.bootup numlock -on
5.aperture size -64mb or higher
6.dram timing -auto
7.auto detect dimm - enabled
8.spread spectrum -enabled
9. max cpuid value limit- disabled
10.cpu tm function- disabled
11.bios protect - disabled
Jul 12, 2011 | Foxconn WinFast K7S741MG Motherboard for...
Please can you give steps to disable the onboard usb controllers to use the CPI USB Card. I've installed the PCI Card after the onboard stop working
2.4.2 USB Configuration
The items in this menu allows you to change the USB-related features.
Select an item then press <Enter> to display the configuration options
USB Function [Enabled]
Allows you to enable or disable the USB function.
Configuration options: [Disabled] [Enabled]
Legacy USB Support [Auto]
Allows you to enable or disable support for USB devices on legacy
operating systems (OS). Setting to Auto allows the system to detect the
presence of USB devices at startup. If detected, the USB controller legacy
mode is enabled. If no USB device is detected, the legacy USB support is
disabled. Configuration options: [Disabled] [Enabled] [Auto]
USB 2.0 Controller [Enabled]
Allows you to enable or disable the USB 2.0 controller.
USB 2.0 Controller Mode [HiSpeed]
Allows you to configure the USB 2.0 controller in HiSpeed (480 Mbps) or
Full Speed (12 Mbps). Configuration options: [HiSpeed] [Full Speed]
BIOS EHCI Hand-off [Disabled]
Allows you to enable support for operating systems without an EHCI
hand-off feature. Configuration options: [Enabled] [Disabled]
NOTE!!!
Do not disable the BIOS EHCI Hand-Off option if you are running a
Windows® operating system with USB device
hope above given details with give you a detailed description as you desired.
good luck
Feb 04, 2010 | ASUS P5LD2-VM Motherboard
Hi good day, my psp is also having the error 80020148 i tried those two solutions you have posted but none of which seems to works, im using version 5.00 M33-6 please help, i need your advise on this...
TO FIX THE PROBLEM FOLLOW THESE STEPS:
1. Goto Recovery Menu (turn off then hold R and turn on)
2. Configuration -> Use NO-UMD (Disable it)
3. Go all the way back to main menu
4. Advanced -> Advanced Configuration -> (Disable all of them)
Configuration Should be Like This ->
.....................1. Disabled
.....................2. Enabled
.....................3. 1.50 (for Phat but needs 1.5 kernel addon) 3.80 (for Slim)
.....................4. Disabled
.....................5. Normal (Needs UMD game to play Isos) if not try Sony Np9660
.....................6. Disabled
.....................7. Enabled
.....................8. Disabled
.....................9. Enabled
.....................10. Memory Stick
.....................11. Enabled
.....................12. Disabled
Advanced->
.................Advanced configuration->
.................................................. .Disabled
i hope this might help you
Nov 28, 2009 | Sony PlayStation Portable (PSP) Slim...
Message says add=ons disabled but they show enabled on page
Hi hosington
When the word enable is shown, what it means is : it is disabled currently, by clicking on it you can enable if you wish.
Good luck
luciana44
Nov 12, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Display driver problem
Try this:
START/ right click Computer goto Manage/ click Services
Here are the services I have stopped and disabled. You can right click each service and goto properties to disable them.
readyboost
superfetch
print spooler - must be re-enabled and started if you use a printer
server
computer browser
secondary logon
security center
windows error reporting
windows search
windows firewall - must be re-enabled and started to use windows firewall
Hope that works, and please rate my response if it was helpful.
Thanks and good luck
Apr 18, 2008 | HP Compaq Presario SR5350F Desktop PC...
Tty enabled/disabled
has anyone gotten a solution for the problem?
Feb 22, 2008 | Samsung Blackjack SGH-I607 Smartphone
Phone disabled
siemens cell phone was working fine until my son fool around with it now the phone is saying phone disabled! phonecode now how can i get it to re-enabled its still work
Jan 07, 2008 | Siemens SL55
Samsung Blackjack SGH-I607 Smartphone Logo
621 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Brian Sullivan
Brian Sullivan
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
