I doubt it is the belt because if the belt is slipping you should hear it. The alternator could be about to crash and not charging at lower speeds. You would check alternator output to find out. The battery and brake warning lights are on the same circuit.
CHECK ALTERNATOR DRIVE BELT COULD BE LOOSE NEED ADJUSTING OR GLAZED NEED REPLACING. IF ALL IS GOOD, CHECK ALTERNATOR VOLTAGE OUT PUT AT BATTERY SHOULD BE 13.5 - 14.5 VOLTS. IF NOT ALTERNATOR FAULTY BUT CHECK ALTERNATOR BATTERY FEED AND VOLTAGE REGULATOR WIRES FOR LOOSE CONNECTION OR DAMAGED FRAYED WIRES. CHECK ALTERNATOR FUSE.CHECK THOSE THINGS BEFORE BUYING NEW ALTERNATOR.FIRST TURN OFF RADIO BEFORE DISCONNECTING BATTERY CABLE TO KEEP FROM LOCKING OUT RADIO.
run the fault codes
possible a vacuum leak
when it happens, leave in drive apply the handbrake and take the foot of the brake
if it fixes the problem . replace the brake booster
need radio code for 2001 Mitsubishi Montero sport. Serial number J44mT21H91P001563. I replaced the battery which reset the radio. My email: [email protected]
