have not had time...hopefully over the weekend i will.........i will reply ...tyhave not had time...hopefully over the weekend i will.........i will reply ...ty
I turned my TV off last night and it won't power back on today. We did have severe thunderstorms last night, but as far as I can tell, there was no loss of power and I have a Monster Power surge protector. I tried unplugging both the TV and the surge protector without success. I also tried using the reset button several times to no avail. I have only had this TV 4.5 years and not very happy with this after spending that kind of money for it. Any suggestions? Thanks, LZI turned my TV off last night and it won't power back on today. We did have severe thunderstorms last night, but as far as I can tell, there was no loss of power and I have a Monster Power surge protector. I tried unplugging both the TV and the surge protector without success. I also tried using the reset button several times to no avail. I have only had this TV 4.5 years and not very happy with this after spending that kind of money for it. Any suggestions? Thanks, LZ
You can't post conmments that contain an email address.
A common problem for these is bad capacitors in the power supply, Remove the back from your TV and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed. This will cure the problem as they overheat being sat next to a heatsink that gets very hot! Try and change them for the same 3300uf but a higher voltage.if otherwise, the power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help to fix the problem and do take care in handling the problem.....
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
capacitors in the power supply, Remove the back from your Tv and look at the
higher voltage. Hope this helps
Thats usually caused by failed capacitors on the power board. The V26 power repair kit from www.tvrepairworld.com should repair that issue. The kit comes with the instructions on Cd.
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
I had a similar problem with my 55' WS Mitsu TV. Their are a number of capacitors inside the TV that were blown (top of capacitor had a convex appearance). TV repair man replaced the capacitors. Ran about $300 for the repair (done at my house).
