Question about GE Refrigerators
Freezer fan sounds like a helicopter
GE Profile model PTC22BMBARWW - Top Freezer
Fridge temp is about 40F and freezer temp is just above freezing. Found the freezer fan stuck and when loosened, fan blade strikes ice - making the noise and not forcing enough cold air to go below freezing temp. Has the defrost timer failed or is there a defrost heater that is not working?
  • fix4me May 04, 2008
    We seem to be having a similar problem. My husband removed the ice maker and fan and reassembled, and it seemed to stop--temporarily. Now it seems to begin right after I hear the water refilling the ice maker. It runs for 5-10 minutes making a very loud grinding sound (yes, rather like a helicopter, or a lawnmower!), and then seems to gradually quieten down. Any suggestions as to how to proceed? Could there be a water leak on the icemaker refill that shoots water into the fan compartment?
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
SolutionGuy
  • 331 Answers
SOURCE: Frost in frostless freezer, fan not blowing into warm fridge
There are 2 things that cause these to not defrost. Kinda like the "Achilles heel" of GE fridges. The first one is the Defrost heater itself. And the second is the evaporator thermister (GE calls it a "sensor"). They are both very easy to replace. The part numbers are; WR51X10101 (heater) and WR55X10025 (sensor). If you don't have a local appliance parts retailer, just plug those numbers into a search engine. I highly recommend getting both parts because if the sensor hasn't failed yet, it will. The same goes for the heater...
Now for the fun stuff... Turn the temp knobs all the way counter clockwise to kill power to the fridge. Unload all the food from the freezer and remove all the shelves and the basket. Remove the screws that are holding the evap panel (the flat panel on the back wall, it's about 2 1/2 ft tall). Remove the panel to expose the evaporator. You'll see the heater at the very bottom of the evap connected by 2 screws, remove these and pull the heater out. Your new heater comes with instructions on how to install it.
After you have done that, look at the top of the evap. On the left, you'll see a little white sensor clipped to one of the evap tubes (shiny little clip), that has 2 wires feeding it. Remember which tube it's clipped to then unclip the sensor and pull it toward you. Snip the wires right at the base of the old sensor and completely remove it (leave the wires in there). Now separate those 2 wires and strip about 3/8" of insulation off. At this point, you are ready to follow the instructions that came with your new "sensor". Oh! and if it's all frosted up on the evap? Take this time (before you re-install the panel) to use a blow dryer and melt it away. All that'll be left to do is rebuild it.
There ya go! Job completion time= ~45 minutes. Easy breezy, right?
If this has been helpful, please don't forget to rate my solution. Thanks!
SG
Posted on Apr 05, 2009
Sea Breeze
  • 4655 Answers
SOURCE: My fridge IS NOT getting cold enough. Temp control is maXxed. The freezer seems cold enough and making ice cubes. this is a GE fridge model #TBF16DRB
Try cleaning the coils beneath the refrigerator. Its possible that they are covered with dust and blocking a fresh flow of cool air to help cool the refrigerator inside. Just a little cleaning there will make a big difference. Check your door seals also a small opening will let the cool out and the hot in. Thanks, Sea Breeze
Posted on Apr 27, 2009
jmgldsmth
  • 1906 Answers
SOURCE: Freezer very cold fridge warm.
the freezer circulates air through the refrigerator by using a fan every 24 hours the defrost timer comes on the compressor goes off and, the machine defrosts if your mullion defrost heaters are getting hot
and, staying hot you have miss-wired your defrost timer
Posted on May 25, 2009
Maytag317
  • 1136 Answers
SOURCE: freezer cold, fridge warm
Hi, You have a self defrosting problem.
Remove the rear inside freezer panel and check continuity on the defrost element and bi-metal switch.The bi-metal has to be tested cold. If there is continuity on both parts, you will need to change the defrost timer.
The most common part that goes bad is the element. I hope this helps you. Please leet me know if I can assist you further.
Vic
Posted on May 28, 2009
Why is fridge not cooling?
Did you check to see if the auto defrost mechanism is working? Defrost heater any good? Ice in back of freezer?
Nov 26, 2015 | GE Profile PFSS6PKX Bottom Freezer French...
Have a GE side-by-side profile 25.4. The fridge side is too cold and freezing items in back of top shelf and items in the veggie draw. Settings are 4 for freezer and 2 for fridge and things still are...
there is a air damper that lets the air in frome the freezer side,, it should be in the back top left corner on the fridge side turn the controls to off and listen you should hear a faint sound like a flap closing,, if not it is either stuck wide open, or the little motor has went out,,,( for a temp fix you can tape some of the opening off until you get the parts replaced
Jan 19, 2011 | GE Profile 25.5 Cu. Ft. Side-by-Side...
It stopped freezing and the temperature keeps rising
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Dec 13, 2009 | GE Profile Arctica Stainless Steel Top...
My GE profile side by side refrigerator's temperature is not staying where I put it. It keeps popping to 31 degrees when I set it for 37 degrees. My food is freezing !!
It may need to defrost. Shut it off for 4-5 hours to let any accumulated ice to defrost and see what happens.
There also is a control that directs more cooling to the refridgerator or the freezer compartment. It may need to be readjusted. It will take 24 hours to stabilize.
Oct 20, 2009 | Refrigerators
My fridge keeps freezing my food
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer works, but fridge is warm. Water had been draining from freezer into fridge, and freezing up in the bottom of fridge prior to this.
Sounds as if your evaporator fan located in the fridge part of the appliance is out. This fan is usually located by the temp control switch. If you open the fridge and listen you should hear the fan humming , if not, then replace the fan. Take the model and serial number to an appliance store and they should be able to get you the part. Good luck on your repairs.
Dave
Sep 30, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
GE GSS25LSMFBS IS FINE IN THE FREEZER SIDE BUT FREEZES IN THE REFRIGERATOR SIDE.
Sounds like you need to adjust your airflow into the frig compartment. There are two adjustments for air flow on a side/side one at top next to thermostat and one at bottom next to crisper. If your freezer is working properly like you say then you just simply need to balance the airflow to get the proper temp of just above freezing to 40 degrees
Jul 27, 2009 | GE Profile Arctica Stainless Steel Top...
FRIG DOEN'T GET COLDER THAN 49, WHAT COULD BE THE PROBLEM,FREEZER WORKS GREAT (GE PROFILE) ABOUT 2 YEARS OLD-
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp control. Make sure the fan is running when the compressor runs. Make sure the vent(damper) opens and closes as you adjust the fridge temp control.
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile - Fridge Doesn't Cool But Freezer Works Fine
Had a similar problem with my Kenwood Fridge Freezer
If you're mechanically minded you could check if there's an opening and motorised flap (usually behind a cover) at the top of the fridge - Cold air from the freezer enters the fridge through this flap) The Sound you heard could have been the motor trying to open / close this flap. This flap can become frozen in the closed position - so cold air is unable to enter the fridge compartment) My fix was to thaw it with a hairdryer and reassemble. Another fix would be to empty the freezer and open the doors - it might take more than 24 hours but once completely defrosted if the flap is the issue it will have defrosted. Once plugged in again the door will open and cold air will start to flow into the fridge compartment. I had a quote for €195 for a call out / repair
I fixed it myself in an hour - Hope it works for you ...
Sep 20, 2017 | GE Profile PDS22MHR Bottom Freezer...
MY GE PROFILE BOTTOM FREEZER
Does it freez up? the thermostat could be bad? the compressor fan could be bad. Also try setting the temp. control if not working this may need replacing.
Apr 09, 2009 | Refrigerators
Refrigerators Logo
151 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
