Question about Mitsubishi WS-55859 55" Rear Projection Television
Have mitsubishi with same problem blinking light
Do you have any pics of the board that needs the 4 thngs replaced.
thanks
wont turn on ...green light flashes..... shuts off. Already changed capacitors.....next?
  • 1bear4u Apr 04, 2008
    have not had time...hopefully over the weekend i will.........i will reply ...ty
  • 149 Answers
Try unloading convergence yokes and and turn tv on if turn on your problem convergence IC's
Posted on Apr 01, 2008
SOURCE:
Green Blinking light on Mitsubishi Unisen lt 40164, tv wont turn on?
Blinking light means your bulb is blown and needs to be replaced. Very easy to do. Check owners Manuel . Shop the bulb on ebay
Dec 19, 2014 | Mitsubishi Lt-40164 40 Inch Unisen Led Tv
Mits 525 started blinkng green standby light today makes a muffled sound as it beeps. wont turn on just beeps.just under 4 yrs old. have replaced bulb 3 times. reading some of these posts seems like...
The first generation mitsubishi V26 chassis which is what your model is has a bad habit of failing capacitors. The steady blinking green power light is related to the DM not completeing the boot up sequence. You can get the V26 DM repair kit at the following link which contains the replacemnent caps that are prone to fail and has the CD with step by step instructions on how to duisassemble the cjassis and replace the caps. Its very inexspensive and will usually repair that issue. Its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Mar 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green light on Mitsubishi 65513
Instructions sent. Please remember to rate this answer!
Jan 09, 2009 | Mitsubishi WS-65513 65" Rear Projection...
MiTSUBISHI T V WONT TURN ON
The problem with your set is 4 capacitors are bad on the "DM: board in the unit. These capacitors are 1000 microfarad at 16 volts. Unless you are experienced, this repair should be done by a qualified tech due to the complexity of getting to the capacitors
Dec 04, 2008 | Televison & Video
MITSUBISHI 65 INCH HDTV, GREEN LIGHT BLINKING, WILL NOT POWER UP
There are four (4) caps on the 'DM' board that need to replaced. Parts: 680ufd 16 volts, orig are rated at 1,000 ufd.
Nov 01, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mit 52525 from blinking green light to still green light.
bad capacitors 1000uf on the PWB, FMT and DM boards will cause those symptoms. All capacitors 9 in all need to be replaced
May 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blinking light will not turn on
replace C81A2 C81A3 C81B2 C81B3 on the dm module and C8F19 C8F21 C8F22 C8F27 on the fmt pcb all new caps should be 680uf at 16v instead of 1000uf at 16v
May 06, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Blinking green power light & shut down
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Apr 07, 2008 | Mitsubishi WS-55515 55" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
