Question about Mitsubishi WD-52631 52" Projection HDTV
DLP Lamp Replacement
Picture is so dim that the menu words are hardly descernable w/o closing the blinds and turning off all the lights. TV occasionaly shuts off on its own. do not see a timer or counter blinking. TV is a 1 year old Mitsubishi one of the following: WD52631 WD57731 WD65731 Lamp part number is: 915P049010. Is the bulb in a cartridge and more or less a plug and play component? Any special precautions necessary?
Thanks.
  • 81 Answers
Yes it is in a cartridge and it is plug and play. and if 1 year old still under wtty. The dimness could also be your fluids??
Posted on Apr 01, 2008
SOURCE:
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
Where is the service menu for the bulb in the Samsung HL-S5087W DLP
if picture dim it is most likely the lamp and resetting the lamp timer will not help that.
Oct 14, 2012 | Samsung HL-S5087W DLP TV
Hitachi 32UDX10S picture is dim with brightness at 100%
The led backlights may be failing or the driver circuit isn't working. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get parts and led testers here.
Feb 12, 2018 | Hitachi 32UDX10S 32" TV
The picture has suddenly gone dark. We can still see the picture, however it is really dark. We tried shutting it completely down and unplugging and restarting it. We tried to adjust the color via the...
The tv LED light on the tv front bazel frame face have the word "LAMP" light up or blinking?Yes.The tv projection lamp been inside this tv like 1 1/2 or 2 years already,tv used it everydays like 4 or 5 hrs daily?Yes.Than the tv projection lamp life are over,that why it dim picture tv now must have it tv projection lamp to be replaced.
Jun 12, 2011 | Samsung SP50L6HX 50" DLP HDTV
My magnavox 50" DLP 50ML815D/17 will turn on and broadcast fine, but after about 30-40 minutes of viewing it will turn itself off & a red light comes on. If you feel the tv close to the bulb area it is...
Yes there is a Fan that keeps Lamp cool if it stops running Lamp will shut off it is designed that way to keep lamp cool also if Fans are OK it means Lamp is going out Call Mats 1-800-628-1118 for lamp
Sep 19, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Samsung DLP TV time, temp and lamp lights blinking... won't turn
Les,
I'm not a TV repair guy but my owners manual states that when all three LED's or lights on the front of the TV are flashing, that the lamp needs to be replaced. Might want to look into this. Good luck!
Greg
Aug 30, 2009 | Samsung DLP HL-P5663W 56" TV
ALTHOUGH tv is POWERED ON NO SOUND OR PICTURE
You should replace it the same way the old one came out.Make sure the lamp compartment door is closed or the TV will not come on.
Aug 01, 2009 | Televison & Video
Grinding Noise
sounds like the light engine there are alot of problems with the light engines and quite a few have had a grinding noise. The only other possibility would be the color wheel. But I would lean heavier toward the light engine being the fault.
Apr 09, 2008 | Televison & Video
Mitsubishi WD-52631 52" Projection HDTV Logo
238 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
