Question about Polaroid FXM-1911C 19 in. LCD Television
Region code how do i change region code with remote
  • 2 more comments
  • trence Jul 18, 2009
    i tried it but it didn't work ,please find another solution.
    Thank you
  • trence Jul 19, 2009
    I LOOKED AT IT BUT NOT MUCH HELP.PLEASE TRY TO FIND ANOTHER SOLUTION TO MY PROBLEM.
    THANK YOU.
    Thanks for trying please search for more solutions.
    Hello, anymore solutions.
  • 3,037 Answers
Can you please confirm the make and model number of the unit in question so I can make sure I find the information that you need.
Benjamin
Posted on Jul 22, 2009
  • 1 more comment
  • Anonymous Jul 19, 2009
    I am searching for it now
    Try these different combinations to change your DVD players region:
    1. Open the disc tray
    2. Press SETUP
    3. Go to Preferences
    4. Enter 1, 3, 6, 9
    If that does not work then try this:
    1. When power on, press EJECT
    2. Press TITLE, PREVIOUS PAGE, NEXT PAGE
    2. Enter 9, 7, 3, 5
    3. Change region
    1. Press SETUP
    2. Go to "Preferences"
    3. Enter 1, 3, 7, 9
    4. Change region using UP/DOWN
    5. Press ENTER
    Let me know if any of these work...I will continue to search
    Try these one out first:
    Using the remote control, press the "setup" button and use the right arrow key to advance to the far right-hand tab entitled "Preferences"
    Note: If there is a disc in the player, you will NOT see the "Preferences" tab!!!!
    Enter code number 1379 and then use the up and down arrows to change the arrow code to match the DVD you want to play.
    If that don't work, try this:
    1) turn on the dvd
    2) open the tray
    3) enter 9735
    4) change the region code
    5) exit to main menu
    If that don't work, then try this:
    When power on, press the "eject" button to open the drive
    b) Press the button of "Title" on the remote control
    c) Press "Previous Page"
    d) Press "Next Page"
    e) Now enter the region code you want
  • 101 Answers
Hi, its seems like theres a bit of confusion out there on the web about region codes, on new dvd players (last 5 years) it is not possible to change the region. The technology that controls region coding is hard wired into the dvd player itself it can't be changed via the remote or by a software update etc..
The region is decided by the manufacturer in production, so U.S dvd players are manufactured to
region 1 (U.S, Canada) specifications, I live in the U.K so if I bought an FXM-1911C where I live it would be manufactured to region 2(Western Europe) specifications, and I would not be able to play U.S dvds
This is common amongst the majority of dvd players
http://www.polaroid.com/service/userguides/ce/lcd_tvs/fxm1911c_ug.pdf
Your player states on page 33 that it will only play dvd's from the region that it is intended for.
I know its annoying and I think its arguably not fair that they do this, but it was a decision made by the manufacterers, this is not the case with blu-ray discs which tend to be a lot more forgiving region wise.
If you nee dto watch films with a region different to that of your player, you can either try running on a Pc's dvd player, where often you are allowed to change region a limited number of times , or if you intend to watch a lot think about investing in something like
http://www.overstock.com/Electronics/Philips-Multi-region-DVD-Player-with-HDMI-Refurb/3032261/product.html?cid=133635
Its £31 or $50 and will play dvd's from any region, plus you could hook it up to the video inputs on your fxm-1911c
Hope it works out for you
Tim
Posted on Jul 21, 2009
  • 525 Answers
    President:
  • 2,777 Answers
There is no way to unlock the region on this LCD / DVD combo. I have tried in the past and it's not possible.
Thanks
Tim
  • 3,741 Answers
You will have to get new remote.it comes with company book let that has all the region code.to make it function and work.
as this codes are only available with company.also if the remote circuit becomes faulty the orignal region code will not get detected.the other reason.if you try the faulty region code more then 5 times the circuit gets blocked and stops detecting region code.
you can go for new remote.to get all the required codes.
www.radioshack.com
or at
www.partstore.com
or at
www.shopjimmy.com
or at
www.bestbuy.com
Please do rate the solution. Thank you for using fixya.keep updated. thanks.
Posted on Jul 19, 2009
  • 11,896 Answers
Polaroid DVC-2000
  2. Press SETUP
  4. Enter 1, 3, 6, 9
Polaroid DVP-0600
Polaroid DVP-1000
  2. Enter 9, 7, 3, 5
  3. Change region
Polaroid DVP-300 / DVP-500
    is region free
Polaroid DVR-0800 / PDV-700 / PDM-0711 / PDM-0722 / PDM-0723 / PDM-0725 / PDM-0822BD / PDM-0824 / PDM-0825M / PDM-0855C / PDM-1035 / PDM-1040 / PDM-2727 / PDV-0700 / PDV-0701A / PDV-0713A / PDV-0744M / PDV-0750 / PDV-077PT / PDV-0800 / PDV-0801A / PDV-0813A / PDV-0820 / PDV-0821T / PDV-1002A / PDV-088PT
  1. Press SETUP
  3. Enter 1, 3, 7, 9
  5. Press ENTER
Polaroid DV700 / DHX-202 / DHM-0100 / DVC-2010 / DVP-110M / DVP-110P / DVP-550 / DVR-0900 / FDM-0700A / FDM-1000A / PDM-1042 / PDV-0703C / PDV-0707N / PDV-0823A / PDV-1042M no known hacksPDV 800 - 1. When playing a DVD, press stop on the DVD Player to ensure that the disc is not spinning. (You may even want to remove the disc from the playing unit.)
2. Using the remote control, press the "Set-Up" button and advance to the far right-hand tab "Preferences".
3. Enter Code # 1379 then use the "up & down arrows" to change the Region Code.
4. Once code is chosen, press enter.
1 - Turn the player on and open the disc tray.
2 - Press 1 3 7 9 in sequence using the remote control. A screen will appear
showing the current region code and software information.
3 - Press "Enter" until the region changes to the desired number (9 is multi-
region).
4 - Press "Stop" to confirm the change.
PDM8551 -
    Scholar:
  • 119 Answers
I am not sure of all the troubleshooting you have gone through already.
Have you tried pushing 1379 on your remote?
If not, try that, it will display the current region... choose 9 (region free).
    Genius:
  • 1,043 Answers
Unfortunately not all dvd players allow you to change region codes. The one built into your unit is one of those kind of players. Polaroid chose to lock the region to the country that the units were sold from. The only way to have the unit play dvd's from other regions is to buy a unit from that country.
Posted on Jul 18, 2009
  • bvanjoff Jul 19, 2009
    I've searched all of the sites that have region hacking codes and your unit is not listed on any of them. As stated earlier, unfortunately the manufacturer chose to lock the region code down for your unit.
  • 336 Answers
Please try the two solutions here...I hope one of them will work. Thanks
solution 1:
1. PRESS THE OPEN BUTTON TO OPEN WHERE THE DISC IS
2. PRESS SETUP IN YOUR CONTROLLER
3. GO TO THE "PREFERENCES" MENU
4. PRESS: 1379
5. SELECT REGION CODE BY CHOOSING 0 TO 6 (CERO IS ALL REGIONS)
solution 2:
1. turn on the dvd
2. open the tray
3. enter 9735
4. change the region code
exit to main menu
    President:
  • 846 Answers
Hello Trence,
After searching for a solution to your problem, checking private and public database's for region hacks. I was unable to find a solution specifically for your make and model of dvd player. ( There are less known hacks for built in dvd players)
There is one universal code for Polaroid dvd players altho this is not 100% sure to work for you but you can try it.
1. Turn on unit
2. Open lid
(All instructions on remote)
3. Press SETUP
4. Use the down-arrow to reach PREFERENCES menu
5. Press ENTER
6. Use the down-arrow to reach DEFAULTS menu
7. Press SETUP
8. Press 1379 (You will see ---- appear one at a time)
9. Press ENTER until you reach desired region (9 for region-free)
10. Press STOP
Post back if this does in fact work for you, if it does not then honestly there is no hack for your built in dvd player. I have put in a request with the private site I belong to and they will have there experts try and find a process that will work with your dvd player.
  • Quickfx PC Repair Jul 18, 2009
    I'm sad to hear that the method described did not work. As I previously stated there are no other known process's to for your DVD player.
    The simple fact that it is a built in DVD player, lowers the chance of there being ANY possible way to hack the region settings.
    These process's are not standard company supplied information. These are mod's and hacks discovered by electronic experts. Built in DVD players are alot harder to test and find solutions thus making it rare that anyone ever figures out a way to do so.
    ****The only other suggestion I can make is that you focus on changing the DVD's region settings. Do you have a DVD Burner/Writer on your PC ? Post back and let me know please, and I can explain how you can change the DVD's region settings.
  • Quickfx PC Repair Jul 19, 2009
    I'm sorry no one else could find a solution for you. I don't take it personal that you didn't believe me when I was the first to say there is not a solution out there for your DVD player. I have asked a group of experts whom run the private site I belong to, to research the matter but it could take weeks before they find a solution if it's even possible. Not all DVD players have region hacks...that is just a fact.
    I am very sorry to say you will not find one, the only option you have is making the DVD itself region free which I can help you do if you have a DVD burner in your computer.
SOURCE:
Changing region code to all on a LG DV550 DVD player?
icon_minipost.gifRegion code hack posted by hackaroto, December 27 2010:
1. Switch off the DVD player in to Stand By mode
2. Open the DVD tray using the remote control
3. Press "pause" in the remote
4. Enter 0, 0, 0, 0 (zero 4 times)
5. The display should indicate the regional code set in the DVD and prompts for the new regional code.
6. Enter the new regional code
7. Press Pause to exit the setup
8. Switch off the DVD using the remote and wait for a while before switching it on again.
works for other LG DV55X players
Aug 03, 2010 | LG Televison & Video
I have a LG HT554PH home cinema and would like a region code to enable it to play region 1 dvds. i have just paid £5 from a website and it is no use my dvd player wasnt on the list. there is a reion...
Hi
To make the player as region free, switch on the LG HT554 Player. Push the eject button to open the tray. Now, press “0” on your player 4 times or until the region code settings shows up on your player. It will show the current region code and will then ask for new region code. Press “0” on your remote to set it as a new region code(0=All Regions). Press Enter key on remote, now restart your player and check the player by playing the DVD’s. It should be region free now.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Jul 23, 2010 | Audio Players & Recorders
How can i change regional code on panasonic sc-bt207
Please follow the steps : To change the player region code
1. Be sure players drive is empty (nodISC)
2. Enter following key sequence using remote control:
Enter, 6, >=10, <<, 00F2, Audio, 8, * requested region code here (1-8) *, Subtitle, 1
3. Player will reset and requested region code will be set.
- For example to set region code to 3 press: "Enter, 6, >=10, <<, 00F2, Audio, 8, 3, Subtitle, 1"
To set the player to RCE proof region free
Enter, 6, >=10, <<, 00F2, Audio, 8, 1, Subtitle, 4
3. Player will reset and set to "region-free" and "RCE-free" mode
To restore players factory region code
Enter, 6, >=10, <<, 00F2, Audio, 8, 9, Subtitle, 1
3. Player will reset and set to factory region code
Regards, Jay__yhg6
Nov 16, 2009 | Panasonic Home Theater System System
Change DVD Region Code
Regards, Jay__okj4
Oct 15, 2009 | Panasonic DMP-BD60K Blu-ray/DVD Player
Unlock region code for Insignia IS-HTIB102732
Call this number for Insignia technical help. Service : 1-877-467-4289. Hope this helps you with your problem.
Apr 01, 2009 | Insignia IS-PDVD10 Portable DVD Player
I have a region 2 samsung dvd r155 and i changed to a multi-region, now wont play any dvd's
HI,
1. Press the Menu button on your remote control
2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the onscreen display
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Aug 07, 2008 | Televison & Video
Need to change my Crown CDV 1100B player to multi region, have tried recommended options from other sites, but to no avail. This what I've tried so far. 1) Press set up 2)press 1369 (which was...
a) Press SETUP button on the remote control to display the setup
screen
b) Press "1369<<<>" on the remote control ( "<" = left navigation
button; ">" = right navigation button)
c) A new item "VERSION" is added on the menu
d) Select thr VERSION item and press SELECT button to enter
e) Press the right navigation button ">" on the remote control to
f) Press SETUP button again to exit the region code change mode
Note: Region code 0 is "all region code".
OR
1.press eject to open the draw.
2.type 9-8-1-7.
3.press select to go through regions.
4.change to region 9 for multi region.
5.press eject to close the draw.
OR
1. Press the Open/Close button on your remote control to open the drive tray
2. Press the 8, 4, 2 and 1 buttons on your remote control, in order, one at a time
3. Press the Enter button on your remote control until the hidden menu appears
4. Select 1 for region 1, 2 for region 2, and so on, or All for multi-region
5. Press the Open/Close button on your remote control
To alter the Macrovision settings on this player
1. Press the Open button on your remote control to open the drive tray
2. Press the 4, 5, 6 and 1 buttons on your remote control, in order, one at a time
3. Select Enable to enable Macrovision, or Disable to disable Macrovision
May 03, 2008 | Televison & Video
Dvd recorder region codes
7. The currently selected region will be indicated on the TV.
Tested with Region 1 DVD's on my UK player (Region 2 bought from Comet)
Jan 28, 2008 | Apex Digital AD-1110W DVD Player
CHANGE REGIONAL CODE
CAN U TELL ME HOW TO CHANGE THE REGIONAL CODE ON MY JVC XN-N650B USING REMOTE OR FROM THE UNIT ITSELF.
Dec 01, 2007 | JVC DR-MV5S DVD Recorder/VCR
Polaroid FXM-1911C 19 in. LCD Television Logo
465 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
