Posted on Apr 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shutdown during exciting audio
I have a harmon kardon AVR 325 and for some reason it will just turn off during exciting areas of movies and TV. For example, whenever there are a lot of explosions and stuff the sound will just turn off. The volume isn't even all that high, so I don't know what could be causing this. Any suggestions?
i have the exact same problem, different model, but the same none the less. all wires and cables are connected correctly and are not grounded or touching eachother or anything like that. listening to music on the dvd player works fine in both stereo and all surrounds modes. watching movies it shuts off usually durring exciting parts but sometimes it shuts off in other parts. what is going on???
Anonymous
Level 2:
Problem Solver:
  • Expert 44 Answers
  • Posted on Apr 01, 2008
Anonymous
Expert
Level 2:
Problem Solver:
Answers
44
Questions
0
Helped
4258
Points
104
Check the wattage of the speakers, they could be drawing too many watts from your amplifier, if you plug in a speaker that's more than the channel, it could harm your amp.
for example a 200 watt stereo, with 4 channels that equals 50 watts per speaker.
Hope this helps you out
Harmon Kardon AVR7200. How do I access the OSD without a remote?
Question edited for clarity.
Question moved to Harmon Kardon AVR category.
They all need remotes. You just buy a replacement.
https://www.google.com/search?q=harman+kardon+avr+7200+remote+replacement
How do to connect tv from AVR
audio out from tv to audio in on the avr
No sound from tv to speakers
i assume you are hooking up from tv to receiver with an optical cable? Check the settings on your tv. Most tv's have a setting to turn on/off the optical audio output
Harman kardon avr 1500
Try using the RCA outputs once and see if that works..One other thing don't use the phono input on the receiver as it could damage the amplifier
1helpful
Hi, I have a Harmon Kardon Model No. AVR 325 that keeps clipping. When I push the power button the display turns off like a second after I push power. Seems like its a easy fix. Nothing if fried visually...
it sounds like Amp burned, but not all burn parts you can see, you have to measure them by DMM. I guess at least one AMP transistor shorted. you can check SPK terminals by DMM DC, it can be easy to find different with other one
Just bought a Sharp LED TV and there is a slight delay between hearing sound and seeing lips move. Have cable box hooked up to tv by HDMI and have cable box hooked to AVR (Harmon Kardon AVR125) by optical...
Hi if there is an optical out on the television i would use that direct to your Harmon Kardon AVR 125, the sound would be in sync with picture, as the source is the same.
10helpful
3answers
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Hooking up an amp
plug eash units sound in red whites from dvd tv main out the set speaker wires in place front ch a ok turn it on make sure ch a speakers on only select corect video input dvd ect turn it up
I have the same problem also. Customer service told me to double check all my cable wires to make sure there is no short. Heck I just went ahead and unplugged all the speaker wires and then it was fine. I replaced all speaker wires and it worked for a couple days but its starting up again. i did the hard reset like the manual told me to do but the same problem.
Thats what customer support told me to do. They said it could be because its going into a safe mode. Mine is just shutting down no matter what sound is coming out of the tv or movie.
 Grubhead
Grubhead
SmartAviator
SmartAviator
