Question about Mitsubishi WS-55813 55" Rear Projection HDTV
Blinking timer light on mitsuWS-55815
Moving TV from one place to another and it tipped over in truck on its backside pretty good. and when we unloaded and plugged in to check it pwr/timer light continues to flash we held menu button in for 10+ sec. and nothing did i break something inside or could have knocked the DM out?
  • 1 more comment
  • wa2fst Apr 02, 2008
    what is the YOKE and where is it located?
  • wa2fst Apr 03, 2008
    thanks it was 4 capacitors were ballooned out. cb something numbers. guess they pop all the time
  • Anonymous Jun 17, 2008
    We had moved several times and never had this problem but we just recently had moved again and now on our Mitsubishi WS-55813 it hyas this green blinking light problem so how do you fix it?
My mitsubishi little green timer light will not quite flashing and the tv will not come on.
Posted on Oct 02, 2009
    Genius:
  • 1,153 Answers
Maybe or u need to check loose connector on yoke
Posted on Apr 01, 2008
  • Lashawn Robinson Apr 02, 2008
    This is a line that comes from the CRT or tubes inside of your set. It comes down to your PCB.
  • Lashawn Robinson Apr 03, 2008
    Yes the go out alot, but never heard of them going out by falling over in a truck.
SOURCE:
Want to know what the black Knob, I think called unloader valve is used
Hubert, The unloader valve is like a by pass for the water and regulates/controls water pressure and redirects water when gun trigger is released. Check the attached links,instruction and guides to learn more about Pumps/unloader, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Pressure Washer Unloader Valve
How to replace an unloader valve on your pressure washer pump
All About Unloader Valves ePowerWash
How to Replace an Unloader Valve on Pressure Washer Repair Guide Help...
May 17, 2016 | Garden
TV will not power up. Timer light continues to flash, will not reset.
You could have shook a fuse loose moving it ,,,or blew a fuse,,take the back off and check the fuses,,good luck ,,
Oct 06, 2008 | Mitsubishi WS-55859 55" Rear Projection...
How do I change the time on a pampered chef clock/timer
Press CLOCK and HOLD until blinking light appears.
Press START/STOP to note a.m./p.m.
Press key "0" to move blinking dash over one place. if necessary, to set time.
Press # keys 0~9 to set actual time. Time will begin as soon as all numbers are entered. Example: Actual time is 4:35. Press # key "0" to move blinking dash into second position from left. Press 4,3,5,0,0. Press CLEAR in case of wrong key~in to stop process. Repeat procedure 1. To set military time, press 12 hr.~24hr. button on the backside of timer.
Nov 02, 2014 | Hardware & Accessories
My Mitsubishi TV W-55815 had blinking light
do the self check to see which of the 5 error codes you may have, it is done with the front keyboard: press after shutdown input and menu for five seconds or more and release both, count the blinks on the power light, 1 then two, pause is no error.
Sep 05, 2012 | Televison & Video
Mitsubishi T.V WS-55815 How to go INPUT , NO
Please check with your remote , the input or video 1 will be found on the source or menu selector which can be scrolled with a view on the display.- on screen.
Check this out.
Sep 25, 2011 | Mitsubishi WS-55815 TV
Kenmore dryer turn on no heat and timer will not shut off unless moved to the off position
I would suspect the timer itself. These have small button contacts and if they stick
they can pull themselves right off the flat spring. These timer buttons operate off
a cam drum and several of them operate the timer motor itself at various intervals.
The model and serial number is inside the door. and usually there are two
philips head screws to remove at the base of the front control panel. It should hinge back. If not, then the access panel will be on the backside of the control panel.
The timer will be
a plug in type so no issues with miswiring. The knob will either pull off or unscrew
(counterclockwise generally)
and beneath it will be two screws which hold the timer in place.
You can call a local appliance store or order the part online using the model and
serial number. Remember to shut off the breaker and unplug unit before servicing.
Hope this is useful.
Mar 26, 2011 | Dryers
Yesterday, my dad brought me a working GE upright freezer from his house, transport time about 45 minutes. The freezer was working fine before he left his house, he did tip it little bit to load, unload...
You should try to un-plug the freezer and let it stand up-right over night to re-settle the freon back down inside of the compressor.
The compressor should normally get hot if it is doing it's job right, and there is a starter for the compressor motor (usually it looks like a large capacitor) that could have failed, or the defrost timer (if it has one) could be stuck, and you should be able to see the small dial on the defrost timer slowly turning, and if it does not turn, then replace the defrost timer.
Jun 07, 2010 | GE 13.7 cu. ft. General Electric Upright...
Screen went black you could still hear the tv, timer/standby light is blinking. Is there a projection bulb that goes out. Can this be an easy fix?
U have a LED light indicator said lamp on ur tv?It is blinking?If the LED indicator said lamp is blinking.Than yes,ur projection bulb require changing.Yes replacing bulb pretty easy.
May 01, 2010 | Sony KP-53S70 53" Rear Projection...
The front cover has the power button. the cover was removed and none of the wires on the backside are connected to the motherboard now. which of the wires need to be connected to which spot on the...
The leads on the wires are usually grouped into two's or three's and will have some letters stamped on them (i.e., pwr for power, pwr led for power LED, etc.), on the motherboard, there will be a block of connectors for these to plug on to and they'll usually have the same lettering as well. Just match the leads to the block and you should be good to go.
Dec 16, 2009 | Gateway 831GM PC Desktop
Mitsubishi WS-55813 55" Rear Projection HDTV Logo
274 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
