Question about T-Mobile Dash Smartphone
Problems With Your Dash!!!!!
So I'm sitting here with my girlfriend as we try to explain to T-Mobile that the Dash is a defective item. With the SIM card in, it doesn't even start up. If enough people call into T-Mobile, maybe they will realize that the phone is, in fact, defective. It is impossible to solve. I have a 1st edition Dash that I upgraded from WM5 to WM6 and I haven't had any problems.
Insert 2 drops of water within the Q and W keys on the keyboard of the phone. This is how tmobile fixes the heating and small bug fixes on their Dash phones.
Posted on Apr 18, 2008
Plug it into the wall and everything will be fine. Trust me I had the same problem
Posted on Apr 07, 2008
Just bought from Amazon. Supposed to be unlocked. Not working. Service provider said phone is NOT unlocked. How can I fix?
well contact Amazon for sure and complain /explain what has happened .perhaps you will get an exchange so you can get new there .
Jun 01, 2015 | Dual Cell Phones
My 2002 Lincoln ls 3.9 v8 is taking long to start please help?
Can be many things. The car relies on a temperature sensor to set the engine for starting. Usually there are 2 sensors with one working the dash controls, while the other does the engine management.
You need a clean fuel filter, air filter, and so forth to expect good performance. The fuel pressure should be checked. There is a test port on the fuel rail and a gauge can be borrowed from any autoparts loaner program.
The onboard computer would catch many possible defects. So you would look at defects not covered by the computer. Vacuum leaks on intake manifolds, bad batteries, bad gas are among the items.
Get a full battery diagnosis. I'll explain. The engine controls are set at values of power. If the power available is low, then all the engine settings will be low. Even the Antitheft can create starting problems.
Since you need to start somewhere, many autoparts stores will do free battery and charging system checks. These are separate from the engine scans which require a trouble or check engine light to appear.
After you eliminate some of these common items, you can try other things.
Sep 15, 2012 | Cars & Trucks
When i answer a call I cannot hear the caller and they cannot hear me. there does not seem to be a problem with me calling people and speaking to them. and on occasions it goes straight to voice mail.
I will start to search for the culprit (SIM or phone).
Try to change the SIM card in your phone. Just take out your SIM and insert another one, have another one borrowed.
If the problem is gone than probably it is the SIM (dirty contacts, chip malfunctioning, bad network access). Call your mobile company and ask for a replacement.
If the other SIM has the same problem then it is probably the phone. Try to turn off the device or, better, try to apply a soft reset.
If the reset does not solve the problem contact device assistance and explain the defect and the test you have already run.
If you are using a handfree set try another one.
May 24, 2011 | HTC Desire HD Cell Phone
My motorola l6 when ever i turn it on it just says contact services provider ???
Remove the Sim Card then insert it again. Then turn it on. Now, if the problem still occurs, try using other mobile phones by inserting your sim card into it. If the problem did not appear on the other mobile phones then your mobile phone is defective. You have to replace your mobile. But if the problem occurs in other mobile phones then your sim card is defective. Report it immediately to your provider for replacement.
Aug 03, 2010 | Motorola Computers & Internet
My son dropped his T Mobile phone into a swimming
I would go for it. Battery may be discharged. It is either going to work or not. Water damage is the worst thing tp predict. Circuits may have corrosion unless you have looked at the boards.
Jul 19, 2009 | T-Mobile Dash Smartphone
Unlock code for my girlfriends Nokia 2630
Ask in the forums in moneysavingexpert.co. There are a few techies there who will give you the details. You will need to tell them your make model and IMEI number. They will tell you if it cannot be unlocked this way-they do not charge-I had my nokias unlocked via them!
Jun 12, 2009 | Nokia 2630 Cell Phone (Unlocked) - Black
My t-mobile dash service comes and gos when it wants
rule out if u have any network problem..contact them and explain ur problem..also try removing the sim card and put it back..hope this wrks for u
THanks for using Fixya
Have a nice day!
Mar 13, 2009 | T-Mobile Dash Smartphone
T-Mobile Dash White Screen, Not Re-setting!
If your screen is white then the lcd cable probably is not seated all the way.
Follow this guide and just reseat your lcd cable instead of replacing the lcd screen:
How to Replace T-mobile Dash LCD Screen
Dec 02, 2008 | T-Mobile Dash Smartphone
T mobile dash sd card problem
sir might a problem with port where u r insterting ur memo. card so contact service centre for that coz hardware issue
Oct 19, 2007 | T-Mobile Dash Smartphone
T-Mobile Dash Smartphone Logo
96 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
