Question about Brother HL 1440 Laser Printer
Printing dots on Brother HL 4040CN
My printer is printing tiny dots about 3" apart vertically on the left side of the paper. They are about 1/2" or so from the left margin. Printer only 2 months old. Called tech support, cleaned everything they suggested. What now?
  • Anonymous Apr 11, 2009
    Same thing: dots on the left side of the paper. Even on labels, ruining every other one. This printer is only several months old, too. What gives?
  • thenetcase May 05, 2009
    Mine does the same thing. Did it straight out of the box. Cannot find a solution.
    New Friend:
  • 159 Answers
Do this procedure
1.print test page then stop the printer on the middle print proses by turn the printer of or open the rear cover
2.remove the paper jam carefully
3.look to the paper if the problem found change the drum unit els the fusser unit cause the problem
Posted on Apr 01, 2008
My Brother HL 4040cn showes a Jam MP Tray. There are no papers jambed but it will not reset.
Hi James,
Remove the paper from the MP tray.
Remove any jammed paper from in and around the MP tray.
Fan the paper stack, and then put it back in the MP tray.
When loading paper in the MP tray, make sure that the paper stays under the maximum paper height guides (1) on both sides of the tray.
Press Black (Mono) Start or Color (Colour) Start to resume printing.
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother HL-4040CN Laser Printer
Brother HL-4040CN is printing a magenta line on the right edge of the paper - can't find any reference to this in the manual - suspect it might need a new drum?
This is because you have left the corona cleaning wire pushed to the right hand side. Slide it back to its proper position (on the left) and you should be good to go.
Jun 03, 2011 | Brother HL-4040CN Laser Printer
Can someone please help me i have just printed off 400 prints with my brother hl 4040CN laser printerits brand new and its now saying my cyan toner has ran out this is impossible i am right in the middle...
Your toner usage will depend upon how much of each color toner is used on each page. (To conserve colors when printing in Black and White only, specify monochrome in your printer setup) <div>I had similar problems when printing publicity flyers. The toner cartridges claim to be good for about 2000 prints each, but I was lucky to get 3 or 400 pages when printing blocks of color. The TN115 cartridges hold significantly more toner, and the cartridges that come with the printer are TINY.</div>
Jul 06, 2010 | Brother HL-4040CN Laser Printer
My brother hl 4040cn is printing fine, except there is a blank vertical line in the middle of the page. what is this?
Usually just toner dust on the laser lens, you remove the toner and drum and look on top inside for a window about 1/2 inch wide. You wipe that window with a dry cloth, and also check for paper scraps inside or on the drum assembly.
Nov 18, 2009 | Brother HL-4040CN Laser Printer
Brother HL-4040CN Fuser Cover
Click this link below;
http://www.uninetimaging.com/newsletter/Brother_HL_4040_TN_115_Reman_eng.pdf
Sep 08, 2009 | Brother HL-4040CN Laser Printer
Brother HL-4040CN Laser Printer does not feed the paper and stops. I open the paper drawer and the paper will be just above the drawer and I will push back down and close the drawer. Sometimes it will...
i have brother 4040cn printer but its not working any more its showing me no paper load paper in multi purpose tary.
so fi any one there for help me please help me .
thank you
Jan 28, 2009 | Brother HL-4040CN Laser Printer
Difference between Brother HL-4040CN and HL-4050CDN printer
The D stands for duplex printing (both sides of paper)
Dec 16, 2008 | Brother HL-4040CN Laser Printer
Brother HL 2070N Drum Unit changed but printing with dots on the left hand side
If toner leaked into the machine and got on the fuser that could cause this, but the dots would go away after a few prints. Try another drum unit.
Oct 28, 2008 | Brother HL-2070N Laser Printer
Printing envelopes on HL4040CN
I just bought a HL-4040CN and all my envelopes wrinkled, regardless of the size, paper thickness or software settings (thin envelope, thick envelope, etc.). Here's how I solved the problem....Open the rear panel and you'll notice a small gray lever on each side, which is probably pointing to "A" on the scale (A, B, Envelope). Move both levers to "Envelope" and close the back panel. The troubleshooting manual says the levers should be moved back to "A" after printing the envelopes, but I left them in the Envelope position and can't see any difference when printing regular or test pages or envelopes, except the envelopes are no longer wrinkled. I called Brother and asked them if there was any reason why the levers can't stay in the Envelope position, and they told me they could be left there if it wasn't negatively affecting other documents. Now, I have a great printer that prints everything without any problems. Hope this helps.
Sep 08, 2008 | Brother HL-2040 Laser Printer
Brother HL 1440 Laser Printer Logo
893 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
