Slow responce running very slow, have done a compressn of all files
  • lcobb4roy Apr 01, 2008
  • 667 Answers
!)Do you have anti spyware and anti adware on your machine?
2) If so are the definitions up to date and do you run them regulary?
)3 When's the last time you did a defrag on your hard drive?
If you answered no to 1 and awhile to 3 that's most likely your problem. Let me know your answer to these questions and I'll tell you what to do about it dependending on your answers. Thanks.
Posted on Apr 01, 2008
Shock absorber
all depends on your weight and what type of terrain your going on , trial and error so just adjust to suit your needs ! while standing on the pegs bounce up and down and make sure the front and rear move at the same time !! test after each adjustment and keep a log of what you done ! slow rides need less responce and softer settings !
Apr 15, 2014 | 2004 Husqvarna TE 510
Laptop runs slow
A slow computer could be caused by a number of things - 1. Insufficient RAM (memory) - if your computer has less than 512Mb of RAM then increase it to at least 1Gb of RAM. 2. Registry problems - clean and repair the registry, it will contain unused registry keys. Use programs such as Registry Mechanic, Microsoft RegClean etc. 3. Uninstall/remove unused programs, this will also free up hard disk space. 4. Not enough hard disk space - swap file space may need to be increased if Windows hasn't been configured to manage it. 5. Install latest Windows updates. 6. Update virus definition files and scan computer for viruses, Trojans, malware etc. 7. Clear the Internet cache for faster browsing. 8. Hard disk maintenance is required at least once a month to keep it functioning efficiently. Run the following programs - Disk Cleanup - removes temporary files that are no longer used and to recovers hard disk space. Disk Defragmenter to make fragmented files into contiguous files and therefore the hard disk access is faster.
Feb 17, 2013 | Packard Bell Easy One Silver 2101 Notebook
My " friend" borrowed my 98 mustang and over
pending how hot it got it may have a blown head gasket or stuck valves a compressn test will have to be done on it to figure out if the engine will have to be replaced
Nov 27, 2012 | Cars & Trucks
Check engen light is comeing on and it sayes miss fire cylenders 1,2,3,4 system to lean o2 responce slow
02 sensors keep the balance of rich/lean fuel--u may hav failin sensors but the computer cant tell if theirs a vacuum leak-a test has to be done-these leaks cause lean conditions which can damage intake valves
Dec 14, 2010 | 2004 Pontiac Vibe
My computer is having slow responce
have you scanned it using the anitvirus? try that, and check for infected files. usually, viruses cause slow performance.
Jul 18, 2010 | Toshiba Satellite A135-S2276 Notebook
Runs real slow and jumpy.slow responce to all commands but downward ok
fuel pressure regulator if it is 4.3 because my truck sits and idles but when u press the gas it die out.
Feb 01, 2010 | 1998 Chevrolet C1500
Responce of my nokia n73 is very slow if it is due
its very easy dont install any antivirus for your mobile just install kasper sky net in your pc and scan the memory card the problem will be solved........
Jun 26, 2009 | Nokia N73 Cellular Phone
Kodak 5300 AiO Printing Preferences VERY SLOW to RESPOND How do I speed up the responce time?
try to check if you meet the minimum requirements to run AIO Home Center, or you can try to upgrade the memory of your computer, is it slow only when you are loading Home Center? Or is it doing the same thing on any other software in your computer
Dec 11, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Slow startup, slow responce.
Well this is an obvious fix but replace your HDD with a 7200 rpm SATA HDD from http://www.newegg.com
It should be a fairly cheap upgrade depending on how much storage you need.
You should see a significant improvement. I be willing to bet your HDD is a slow 5200 rpm and slow seek time.
Remember, the slowest parts of your computer is your HDD and CDROM
Aug 21, 2008 | Acer Aspire 3690-2196 Notebook
Dili...
did you install the windows defender ....
if so run the scan once you may have got attacked with the spy ...
and that day as i told you, you will face this kind of some hanging problems because before your system was attacked by that funny scandal,etc viruses
by that one system file has got attacked by the name smss.exe
this is the system file ...
this is needed for some operations ..
though you have already removed the viruses but you are face the effects of those viruses ...
XP is very much delicate operating system for virus ...
once if it s get s attacked it will become slow if we remove the virus also it will not return to the normal speed ..
so this can only be solved by reinstalling the XP ...
once you have done with the reinstalling process you will never face this kind of hanging problem ...
and about the internet connection as your s is satellite connection the sending and receiving of the data packets will take some time .. so by this it will some what slow ..
and some times when transfer some packets it might get lost in the middle of the transmission so some times you will face connection problem ...
when you face this problem just have a check by pinging ur DNS address in the command prompt ...
by this you will get the clear picture that satellite is receiving the data packets are not ...
Apr 15, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
