Projector Serial Port Codes
I'm trying to find the serial port codes to add to an application we developed to turn on/off our overhead projectors from the computer. The computer has a serial connection to our projectors and it works with all of them but out new Sanyo PLC-XU101 and I can't seem to find any documentation on this. Maybe they are the same for older models but I wanted to see if anyone already has figured this out.
Thanks
  • audiovideobl Jan 25, 2009
    I have a Infocus Lp260 after 30 Seconds it shutdowns ,i have cleaned the filters and keep shutting down
    Thanks
The WXU10 has a different serial port and completely different command protocols from the other Sanyo ranges! Assuming you have the serial cable (9D to 6P rather then 9D to 8P on a standard Sanyo, you will need to use completely different codes!
The manual available from Sanyo for this model has a table of codes, but instead of the more common ASCII 'C' Commands (e.g. "C00"+(CR)) it uses a string of 13 HEX characters, each string starting with a BE EF header, some other control parameters and finally an XOR checksum of all the previous bytes....no LF or CR at the end, Just pure hex values.
Not easy to remember, either....you WILL need the table from the manual!
Mike
Posted on Jun 11, 2009
  • 563 Answers
Hi there
They might be the same if the Projectors are from the same series.
First figure out if the RS232 codes are in ASCII or HEX. You will most probably be using the HEX codes.
Best would be to contact the dealer you bought this unit from - they should by all means be able to help you out.
Posted on Apr 01, 2008
SOURCE:
We want to connect a Sinotec RC-356 TV to a LG projector but can't find how to get an output from the TV into projector. Can this be done?
check at the back of your gadget, there are ports that are designed for AV codes , normally with red, yellow and white colors , get the AV codes and insert the matching colours to those port in which red vits audio, yellow its picture and white just enhances sound quality, then connect in the same manner to the projector............
Sep 20, 2017 | LG Televison & Video
Tip
Options for Adding Serial Ports The serial port is prevalent on PC's ...
The serial port is prevalent on PC's as well as scores of industrial, scientific and consumer devices, making it a convenient starting point for communications. Since RS-232 itself is only suited to short connections (50 ft. max.) many applications require that it be adapted to fit requirements. RS-422, typically used for extending RS-232 communications, provides full duplex communications between two devices. It can also provide one way communications from one master to several slaves. RS-485 communications standard allows cable lengths up to 4000 feet. It also provides very high noise immunity. Multidrop connections up to 32 different nodes can be made over a single twisted pair cable along with a signal ground connection.
This article summarizes the choices a system designer has when adding a serial (RS-232, RS-422, or RS-485) communications device. There are many different ways to add additional serial ports to your Desktop PC, Palm, or Laptop PC. USB, PCMCIA, PCI and ISA are some of the methods that will be discussed.
The Universal Serial Bus (USB) provides a high data rate and Hot Swap connection for PCs, providing an easy connection to a wide variety of multimedia and network USB devices. Generally considered to be for home or office use, USB is finding its way into Industrial applications.
PCMCIA Serial Ports are yet another way to add serial ports to a PC that has PCMCIA Slots available. Most Laptops today offer only one (if any at all) DB9 type serial ports. A PCMCIA Serial Card is a good way to add a serial port (or ports) to any laptop that is low on available serial ports (RS-232, RS-422 or RS-485).
PCI Cards are becoming more popular as a way to add serial ports to desktop PC's. PCI type slots are becoming the "norm" in standard PC's today, and PCI Serial Cards are an excellent way to add serial ports. The standard Desktop PC may only come with one serial port standard (if any serial ports at all). PCI Serial Cards use Software Drivers to address the ports to the PC.
ISA Cards are yet another way to add serial ports to the older desktop PC's. ISA type slots are becoming scarce in standard PC's today, but are still an excellent way to add serial ports. The ISA Cards are typically addressed using dip switches and shunts or jumpers to set IRQ's for each port. No Software Drivers are required with ISA style serial cards.
Palm OS PDA's may be connected to RS-422 or RS-485 data circuits using Palm adapters. These adapters offer total portability for collecting data and field service chores. The Palm device and the adapter will usually slip into a shirt pocket. Some models use the PDA's connecting cable, some include a cable and some are cradles that allow the PDA to nest in place and connect directly to the Palm base socket. PalmTerm Freeware allows you to transmit and receive data from the Palm serial port.
on Sep 12, 2010 | Computers & Internet
Connecting projector to desktop using usb
I have to make an assumption here that the overhead does not have a USB port. You will have to get an adapter that will take you from USB to whatever connector that you need but also could turn into getting a scan converter. Let me know what the whole problem is and I know I can help you with this. This is what I do for a living.
Oct 31, 2012 | Epson Office Equipment & Supplies
Cant connect my artista 180 to my pc it says 'serial port engaged'
Try changing to a different COM port and make sure you haven't got any other applications running that might be using the serial port, even if you've nothing connected ... have you recently installed something that might be using the COM port ?
Nov 19, 2011 | Bernina Artista 180
How to connect to IBM Laptop ?. When I connect no image appears.
You have to use a serial port HDMI cable to do the connection,
Also check if your laptop is compatible with the projector, if the laptop is compatible you have to try a new cable Good luck in solving the problem........
Aug 02, 2010 | BenQ MP610 Multimedia Projector
How do I find the control commands for the Serial port of a ViewSonic PJ506D Projector?
I cant program systemlink 4 + RCA to Sont plasma TV and Magnavox DVD + VCR using instructions to hold down Code Search till light blink then click and release Tv button etc.
Mar 15, 2010 | ViewSonic Office Equipment & Supplies
How do I change the input from the DVI-I input to the 15
I found the online manual and followed the instructions to set to "auto" input. Everything works fine.
It had been a discouraging ordeal trying to locate a new DVI cable (which came with the projector)
and as it turns out the 15 pin cable works fine. Thank you.
Rick
Jun 11, 2009 | Sanyo PLC XU50 Multimedia Projector
Connecting a Sharp Multimedia Projector XR-40/30 Series Notevision 30X to a HP Pavilion Zd7000. I cannot get an imageMultimedia projector
use a vga to vga cable. if your HP has a 13 pin serial conector. (looks like a trapezoid), use that.
If not you may need a dvi to vga cable.
if not, the projector may have two ports on the back - use computer in - not monitor in.
Lastly, try the video settings on the HP to see if its picking up the projector as a second monitor as a primary
Makes a difference, NGK
Aug 07, 2008 | Toshiba TDP-S8 Multimedia Projector
No Signal
Try it with 75Hz for the second monitor and use the VGA input.
USB/serial is only for configuration.
Thomas
Feb 19, 2008 | Acer PD100 Multimedia Projector
Open Questions:
1,956 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
