Status light is on tv will not respond. Disconnect from power source and tv will turn on but within minutes tv shuts off and status light turns on. Help
If the "status" light is blinking red than you most likely have a fan failure going on inside the set. there are 5 fans in the tv and it could be any one of them.
Don't open up the TV. You may regret it. Unplug the set for 5 minutes....not just shut off....uplug the power plug from power source and replug after 5 minutes. It may need resetting.
I have a Mitsubishi WD73642 model which I'm having a problem with it turning off. When power is turned on the status light flashes green and appears to be powering up. Then u hear sound. Picture comes on light turns sold green then within a minute the El TV will just turn off no other dianososis lights. TV is not located too close to the Wall. Any ideas why?
Hello! First: disconnect any signal source from your TV, including cable. Unplug TV off the wall or power strip. Let it sit for a minute or two. Plug power back in. TV might turn on itself, might not. Depends on configuration. Turn it on manually, using set's "power" button. Observe the behavior. Lines? TV need repair! Not an armature job. Lines gone? start to connect signal sources back, starting with cable. Observe the picture. No lines? Proceed to the next source: DVD player, and so on. At some point lines might return. Make note, what source causes the problem. Then, you may know what to do next. good luck, Alex.
Unplug the tv for about a minute - plug it in and press the reset button on the front of the tv - hold it until the light blinks. The set should come on in a minute of two - if not try the same routine again.
The easiest thing to do is switch off the power at the wall socket, or disconnect the plug completely. Then leave everything off for 5 minutes. After that reconnect and there is a very good chance the set will respond.
It looks like your ballast board is going bad, this is a common problem for DLP TV's the ballast board is the power source to the lamp and if for any reason this board does not send enough energy to the lamp it will turn off, It looks like your ballast it starting to get weak it gathers enough energy to turn on but gets weak again and turn back off you have a new lamp and it requires for the ballast to be working at it's full potential
Is the status light yellow or red? If it is yellow, then check the dust filter cover. That cover might be off or not secure. If the status light is red and blinking, then try unplugging the TV for a minute. If the error doesn't resolve the TV needs service. If it is out of warranty, you might want to open up the set and look for any obvious problems on the circuit boards (scorch marks, soot, bulging or leaking capacitors (look like cylinders on tripods)).
Manually turn on the device you wish to scan for (e.g. TV)
Perform Power Scan by pressing and holding (approximately 3
seconds)the desired DEVICE MODE button TV, VCR, CBL, DVD or SAT until
the status indicator light begins to blink.
Press and release the PWR (power) button. The status indicator light will stop blinking and stay ON at this point.
Press and release slowly and patiently the blue UP ( ? )
button to scan forward through the code database. To scan backward
through the code database, press and release the blue DOWN ( ? )
button. Each time you press the up or down arrow, the remote will try
and turn off the device (TV, VCR etc) you originally selected.
When the device (TV,VCR etc.) responds by shutting off, press the ENTER button. This will store the code
in memory and you will see three blinks of the status
indicator light to confirm the code input. Be patient, there are over
100 codes to search through.
Red light blinks
Red light blinks
is it a constant red light? or does it blink at all?
