GE TV TV broken after fall White Line across center
  • 8,617 Answers
Thats a sign of vertical deflection failure. Try resoldering the vertical output ic. The fall may have cracked the vertical output solder joints or cracked the chassis in the vertical section circuitry.
Posted on Apr 01, 2008
SOURCE:
My television was dropped. The power comes on, but the screen remains black with a white line appearing across the center of the screen.
hi,
how many years, your tv is working .
if over 10-15 years you must try to replace with new one.
if not :
the gun of screen lamp may be damaged or one of diod is damaged or one of the larg capacitor
is leeked .
anyway for solving the matter a technecian must visit your tv.
good luck
gorbesia
Jun 13, 2011 | Goldstar Televison & Video
White flickering line across top of screen
Set the screen format using your TV's menu. Do not set the format of the screen using your provider's receiver. I had this prob with a few channels with a dish provider when I set the format with the remote from the dish provider. I picked up the TV's remote, went into the menu, set the format, problem fixed.
May 15, 2010 | Vizio GV42L 42 in. LCD Television
White line across center of screen
cold solder in vertical ic or bad.
Apr 03, 2010 | JVC AV-27820 27" TV
No video but sound works. white line across center
easy way is 4 wires will come from yoke coil(around pic/tube) green &yellow wires commonly used for verical deflection ..will be connected to soket. trace tracks from that connector points..on bootomside of pcboard..that tracks will lead you to vertical ic..commonly standing type ic..replace ic..check supply25v for the ic will come from l,o,transformer via a resister..good luck...
Mar 16, 2010 | Televison & Video
Same prob w/ white line but now no pic
Bad vertical ouput IC and/or capacitors.
Jan 08, 2010 | Emerson EWF2703 27" TV
I have a Samsung TV, it flat lined
needs fixing, or replacing, sorry!
Dec 01, 2009 | Cars & Trucks
Thin white line across center of screen Fisher PC-32S90
yes there's a lose connection of your tv. It needs to re solder.if you know how to solder .,solder the vertical section specially the vertical I but be careful of short circuite coz it may damage your tv set.
Nov 16, 2008 | Fisher PC-32S90 TV
Toshiba 36AF43 36" just has white line in the center
vertical output IC has loose solder joints.if you continue to let it operate this way it will etch a burn line across the face of the tube so discontinue use.
Aug 22, 2007 | Toshiba 36AF43 36" TV
Horizonal White Line
Your problem could be one of the common ones as this set has loads of bad solder connections. Your problem is most likly the verticle output IC connections or the B+ feed componets have bad solder connection on them. In some cases though the Output IC is defective and will need to be repalce. if you have no soldid state repair or soldering skills play it safe and get a pro to assist you in this repair. It should not cost you more then a hundred bucks or so and thats the high end. good Luck, And Merry christmas.
Dec 25, 2006 | GE 19GT270 19" TV
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
