Question about IBM NetVista A40 PC Desktop
2 ethernet cards can't work together
I'm using windows NT 4.0.
1 nic is Intel Pro/100 VE Desktop connection which has extension PCI slot, the other one is IBM 10/100 EtherJet PCI Management Adapter which plug in the extension PCI slot. I install the Intel pro/100 drivers, both nics can be seen in the network. But only IBM one can connect to other PC.
After I disable IBM one, the Intel one works.
If I delete IBM adapter and then install a IBM driver, the Intel one works while the IBM one doesn't.
If I disable the Intel one, the IBM one works again.
Seems they just could't work together.
I tried in windows XP, there is no that problem. The 2 nics can work fine.
I appreciate if someone could help me!
  • bearcat318 Apr 01, 2008
    Thanks for response.
    I use the switch and hubs in the network to connect other PCs. For other PCs like Dell and IBM 300GL with NT4.0 and 2 nics can work fine. But with the this IBM Netvista with the intel nic plus IBM nic on the extension PCI slot could not work together. And there is no PCI slot to put a nic on the motherboard directly.
  • bearcat318 Apr 06, 2008
    The ip address isn't conflict. I use 2 different ip address in same subnet. I also checked the interrupt conflict which is ok.
  • 1,027 Answers
If in your network you are connecting computers directly to a PC thru multiple nics and not a router or hub leaving one as server and the others as clients and that server is NT 4,0
NT 4,0 can not auto configure the cat5 cable and would need at least 1 cable to be a cross-over and not a patch.
Posted on Apr 01, 2008
  • Mark Williams
    Mark Williams Apr 04, 2008
    Have you checked the ip address and make sure there is not a conflict that way?
Where can I find Acer 661fx-m71.2a ethernet controller? can anyone give me links?
  • Intel 82557-based Integrated Ethernet PCI (10/100)
  • 82557-based Integrated Ethernet with Wake on LAN
  • Intel 82558-based Integrated Ethernet
  • Intel 82558-based Integrated Ethernet with Wake on LAN
  • Intel(R) PRO/100+ PCI Adapter
  • Intel(R) PRO/100+ Management Adapter
  • Intel(R) PRO/100+ Server Adapter
  • Intel(R) PRO/100 Network Connection
  • Intel(R) PRO/100 VE Desktop Adapter
  • Intel(R) PRO/100 VM Desktop Adapter
  • Intel(R) PRO/100 VE Network Connection
  • Intel(R) PRO/100 VM Network Connection
  • Intel(R) PRO/100 VE Desktop Connection
  • iSeries 2892 10/100 Ethernet Port
  • Intel(R) PRO/100+ Alert on LAN* 2 Management Adapter
  • Intel(R) PRO/100+ Alert on LAN* Management Adapter
  • if these arent right you will find ethernet drivers and more
  • on the home page you should see a search tab just type in what you are looking for
    (be precise)but don
  • Oct 04, 2011 | EliteGroup 661FX-M7 (661FXM7V11)...
    Compaq Presario 5220 Desktop Windows 98 internet: Dial-up Can a DSL card be installed or would I need to go with a wireless USB? And would wireless USB work on Win98?
    You can install a network card inside the computer. You will need a PCI or an ISA card. (I know PCI network cards are easy to find at most of the computer shops.) See this site for how to install a card: . However you should open your computer and check the space between the devices in the slots in the computer. There is an AGP slot with a video graphics card, 1 PCI/ISA slot with a modem (default specs), one free ISA slot and one free PCI slot. However depending on the graphics card one of these slots may be blocked by the card. You'll either need to get a card that fits the available slot or remove the modem and use that slot.
    Here are some PCI 10/100 network cards: . Most of these are compatible with Win98. I'm not sure if there are any gigabit NIC with Win98 drivers.
    Wired and wireless USB NIC adapters exist. However, you will be limited to the USB speed. If you have USB 1.1, that will be really slow. Most likely your computer will require a reboot anytime the connection is lost.
    I hope this helps.
    (who recently removed an internal modem to put in a PCI gigabit card in a newer desktop than yours. The procedure was straightforward and improved network performance in the household immensely. The failing on-board NIC was tying up the router for everyone.)
    May 12, 2011 | Compaq Presario 5220 (388098-003) PC...
    What type of video card can I use on this motherboard? D945GZIS AGP? PCI? PCI EXPRESS?
    Your MoBo has (1) of each PCI Express x1 & and PCI Express x16 slots, and (2) standard PCI slots. There are NO AGP bus slots on this board. You'd want to use buy a PCI Express x16 video card instead of a PCI video card due to the better performance offered by the PCI Express cards.
    The full details of your motherboard are below:
    Product Description The Intel Desktop Board D946GZIS delivers an integrated graphics solution in the Essential Series by combining exceptional value with quality and reliability and supports Intel Core2 Duo, Intel Pentium D, Intel Pentium 4, and Intel Celeron D processors with 1066/800/533 MHz system bus in the LGA775 package. This board features a PCI Express x16 connector, integrated 10/100 LAN, dual-channel DDR2 memory, Intel High Definition Audio (Intel HD Audio) and up to eight USB 2.0 ports.
    Processor Model: D946GZIS Chipset Type: Intel 946GZ Express Processor Socket: LGA775 Socket Installed Qty (Max Supported): 0 ( 1 ) BIOS Type: Intel Storage Controler: ATA-100
    Memory RAM Installed ( Max ): 0 MB / 4 GB (max) Supported RAM Speed: PC2-4300, PC2-5300 RAM Features: Unbuffered, dual channel memory architecture
    Audio Audio Output: Sound card Sound Output Mode: 5.1 channel surround Compliant Standards: High Definition Audio
    Expansion / Connectivity Expansion Slot(s): 1 PCI Express x1, 1 PCI Express x16, 1 processor - LGA775 Socket, 2 PCI, 2 memory ( 1.8 V ) - DIMM 240-pin Interfaces: 4 x Hi-Speed USB - 4 pin USB Type A, 1 x serial - RS-232 - 9 pin D-Sub (DB-9), 1 x parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25), 1 x display / video - VGA - 15 pin HD D-Sub (HD-15), 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45, 1 x audio - line-in - mini-phone stereo 3.5 mm, 1 x audio - line-out - mini-phone stereo 3.5 mm, 1 x microphone - input - mini-phone 3.5 mm, 1 x storage - floppy interface - 34 pin IDC, 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style), 1 x mouse - generic - 6 pin mini-DIN (PS/2 style)
    Nov 03, 2010 | Intel D915GAV Motherboard
    Dell Inspiron ethernet card plug bad, either send tower to Dell for 3 weeks or replace and bypass with new ethernet card PCI, any problems with doing this?
    There should not be any problem with you buying your own PCI ethernet card and install it yourself. They are not that expensive. has on for only $7.99 and it will work fine in your computer. It does not need to be from Dell.
    Nov 19, 2009 | Dell Ethernet Card Network Adapter
    Questions about replacing ethernet card on my Dell desktop
    Any ethernet card will work fine. Just be sure it's the fit's the correct slot. You probably have a "white" slot which is a pci slot. If it's a longer "black" slot then it's isa. More than likely it came from a pci slot. Before you buy one, confirm the type of slot. In additon, before installing it go to control panel and system settings, hardware, device manager and remove the old one by right clicking it and select delete or remove. Shut down the computer follow instructions for new card.
    Probably will have to install the drivers first then shut down and install the new card. Good Luck.
    Apr 17, 2009 | Dell Ethernet Card Network Adapter
    Teaming Intel Card
    That NIC is end of life ...obsolete
    Mar 02, 2017 | Computers & Internet
    Ethernet Controller Compaq Evo D310m Intel Pro 100 VE
    try using Microsoft update to scan for driver and software updates.
    Feb 13, 2009 | Compaq Evo D310M 845G P4 Motherboard
    I am not able to connect to internet because i don't have ethernet controller therefore i need ethernet controller
    The ethernet controller is a hardware device either as part of the motherboard -where you will have an RJ45 connector visible to you at the outside of the case -or as a Network Interface Card (NIC) which would be installed as a PCI card which has it's own RJ45 connector.
    If yours is a driver problem you will need to specify which brand/model computer or NIC you have for a link to that manufacturer to download drivers from that site. If you encounter problems or have more specific information please post again here. Steve Medley
    Jan 26, 2009 | Computers & Internet
    Dell 4700 Computer Integrated NIC Problem
    Check for the pins inside the integrated NIC to check if the pins are bent / disfigured. Does not look like the additional card is making any different, looks more like a moving NIC cable is makin the difference.
    Lemme know if this helped!
    Dec 13, 2008 | Dell Ethernet Card Network Adapter
    NIC too close to USB port?
    Hi Antatg,
    Go into your bios and make sure all your USB option are enabled, specially Enable USB for legacy devices, and check to make sure you NIC is enables. Hope that helps!
    Good Luck!
    Jan 07, 2008 | Dell Dimension 1100 PC Desktop
    IBM NetVista A40 PC Desktop Logo
    254 people viewed this question
    Top IBM Computers & Internet Experts
    Alun Cox
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
