Question about Ricoh Aficio SP C410DN Laser Printer
Getting "service code 442" on startup
Cannot start it up as i am getting this service code 442
  • 114 Answers
SC442 Transfer belt contact error The transfer belt contact sensor does not detect the movement of actuator at the sensor while the polygon motor rotates. • Dirty transfer belt contact sensor • Defective transfer belt contact motor • Disconnected connector of transfer belt contact sensor or motor • Disconnected cable 1. Replace the transfer belt contact sensor. 2. Replace the transfer belt contact motor
Posted on Mar 21, 2010
Ricoh Aficio MPC 2500 error SC 442
image transfer belt contact sensor is dirty clean it
Feb 17, 2014 | Ricoh Office Equipment & Supplies
Recently bought & installed Roxio 2011 on Windows XP and it worked fine. Upgraded laptop to Windows 7. Roxio stopped working. Uninstalled all Roxio programs and reinstalled Roxio Creator 2011. No...
If you are getting the error at startup, roxio service might not started or disabled. What you can try to do is to enable all roxio service. refer to the steps below.
- click start > run - type services.msc - look for all roxio service i.e roxwatch.db - double click it then select the startup type to automatic - save the changes then restart computer
Cheers . . .
Feb 02, 2011 | Roxio Creator 2011
I keep getting a service hang report, it says HP CUE DeviceDiscovery failed upon startup. When I go to windows reports and solutions it says a minidump.MDMP error.
change the following services.
Click on the Start button, then type "services.msc" in the "run" dialog box and click OK.
in case of vista/win7 type it in "start & search" box(you can find it once you click on windows logo)....
Set as "Automatic" the startup type for:
-Windows Firewall
Set as "Manual" the startup type for:
-HP Network Devices Support
-HP CUE DeviceDiscovery Service
you can right click on the particular service and click on properties....then change the startup type....
this issue will fix for sure....
pls do rate if its found useful...
Apr 02, 2010 | HP Hewlett Packard Pavilion A6200N PC...
I'm getting an 442 error code which says it's a evap leak
Make sure the gas cap is tight and if it still stays on and has a code it can be the purge canister valve.
Aug 30, 2009 | 2002 Dodge Caravan
What do codes p 442 and p 455 mean????
442 evap small leak 455 evap large leak
Apr 17, 2009 | 2001 Dodge Caravan
Error code at startup
Re: windows Vista will not start I had the same problem and came across this solution that worked for me as well: 18 Aug 2009 07:28PM I was getting a the same error codes and couldn't get Windows to boot up at all. I went to BIOS set up (restart your computer and hit F12 when the BIOS screen comes up), went to onboard devices and changed the SATA Operations from ACHSI (don't know how it got there) to the factory default setting ATA. Then I started up in "repair mode" (which was an option that was coming up when I tried to boot up before but never worked) - it went through a repair check and went to login screen.
Prior to finding this - I tried several things including start up from the Reinstallation disc, but nothing worked. I was ready to buy a new hard drive, but don't have to. Works fine!
Not sure what caused the problem to start with. It is an "Inspiron 1520"
Apr 11, 2009 | Computers & Internet
Error codes 442 and 456 on 2003 Chrysler Town and Country
Could be the gas cap.  Do you fill the tank with the engine running?
Otherwise, check the hoses near the Evap canister.  I have 2003 T&C and had the small leak and large leak codes.  I looked at the evap cansiter and the hose coming from the fuel tank vapor line had a huge crack in it, to the point it had fallen off the evap caniser.  I trimmed the end of the hose and reconnected and voila, no codes.
The evap canister is on the driver's side of the van, underneath, slightly behind the drivers seat.
BTW, to clear the codes without an OBDII reader, remove the negative cable for 5-10 minutes (15 to be safe).  The computer resets and clears the codes, except for one that it sets saying loss of power to the memory.
Jul 22, 2008 | 2003 Chrysler Town & Country
Ricoh cn 4100 printer
Its a problem with your transfer belt. Either not turning, or bad connection.
Apr 01, 2008 | Office Equipment & Supplies
Ricoh Aficio  SP C410DN Laser Printer Logo
1,045 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
