Question about Ricoh 6513 Copier
Error code on ricoh copier..
Hi, I got one of these (that is giving me this error message) and I dont feel like paying some clown 150 dollars who doesnt even know what that code is or take the time to look it up..! you clearly know what you are doing. I was wondering if I can adjust this myself../? is this relatively easy or does it require training..? Im pretty handy.. since you are not in marina del rey (where I live) im guessing that I cant get you to fix it.. Any help you can give me woudl be wonderful.. THANKS SO Much.. my email is the_bystander_98@yahoo.com
also, there is a small (what appears to be like a fiber optic) double wire running from the feeder unit to the main unit itself. that wire is severed and the optic looking deal is exposed.. Im guessing that this isnt doing the unit any good either.. I guess it may be if I replace this it would solve this problem perhaps..??
thanks.. oh do you knwo were I can get one of those little cables..??
thanks
chuck
  • 64 Answers
What code you are got ?
acording to your message i thing your problem in DF unit change the fiber optic cable.
Posted on May 26, 2008
How to Remove error code SC865
Hi there
I managed to find a list of Ricoh error codes with brief explanations of their causes here:
Ricoh copiers error code messages
It details the SC86? as hard disk or disk controller problems with SC865 being specifically the hard disk. I therefore doubt if you will be able to get rid of this fault without replacing at least the hard disk and possible the disk controller board as well.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 23, 2014 | Ricoh Aficio MP2352 Copier
My ricoh aficio code a 990 how to fix them ?
An SC990 is usually an error indicating maintenance is overdue. The only way to verify that is by printing out the SMC report and seeing the subcodes. In the case of this model when is the last time the drum and developer was replaced?
Nov 15, 2014 | Ricoh Aficio 1015 All-In-One Laser Printer
Ricoh 2022 giving error code 392 what should I do
If you are happy with my response please give me 4-thumbs up. Thank-you.
Enclosed is a link to the user manuals.
Last set has error codes.
Message 3xx is interface problem. That is the communication from your printer to your computer. If this message exists and does not go away. You nned to check the connections to the computer hardware.
Good luck.
http://www.ricoh-usa.com/downloads/local/manuals/multifunction_bw/aficio2022-27.pdf
Aug 04, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
Hi, I am receiving an E-1 error message on my FT5832 copier.Then when i press gain to (,)to know more about this eror i receive 41.. please give me a solution thnk u
The E 1 code is the exposure malfunction code.Please verify the exposure lamp continuity and the components(thermistor,thermofuse) continuity conditions.Reset the malfunction code to open and close the front door.
Dec 22, 2009 | Ricoh FT5832 Copier
Hi I have Ricoh Alficio 2032 copier. There is C545 error message
I'm assuming it's SC545. It pertains to temp not being correct in the fuser. Possibly a thermistor, thermal fuse or lamps are bad. It's one of the codes that need to be troubleshot and replace whatever is needed before clearing the code. This is to prevent further damage to the machine. Thanks Colin
Jun 28, 2009 | Ricoh Office Equipment & Supplies
Am having ricoh 1013 photocopier, and its giving an error message that "functional error,switch off mainpower and on"!
Low fusing temperature. Either the thermistor is bad or power supply board (unlikely). Service code can only be reset in service mode by a technician after problem is fixed
Mar 24, 2009 | Ricoh Aficio 1013F Copier
Error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
Dec 17, 2008 | Ricoh Aficio 1035 Copier
User manual for Ricoh FT 4427
I WILL GIVE YOU A MANUAL RICOH FT 4427 BUT YOU NEED TO PAY 100 US DOLLAR. EMAIL panlaqui08@yahoo.com.ph
Mar 20, 2008 | Office Equipment & Supplies
Ricoh CL2000N Error Code SC230
The manual says this code means " BCU Received no Feedback from LD" I have no idea what that means, but maybe it will help a tech on hear tell you more.
Jan 24, 2008 | Ricoh Aficio CL2000N Laser Printer
Ricoh 6513 Copier Logo
105 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
