Question about Kenwood VR-405 Receiver
Kenwood VR-405 Every time I turn on the receiver It goes into standby mode after 2 secondes, and display goes off with no other options avaible?
  • Anonymous Apr 07, 2008
    mine won't turn on, how do i fix it, stand by light is lit though
You need to unhook all of the speaker wires from the back. they are crossed. i had the same problem with mine. unhook all the wires and turn the unit on. turn the volume all the way down. Make sure your wires arent crossed next time you can damage your reciver.
Posted on May 19, 2008
  • 1,512 Answers
Hi changeman5 Have you tried to do a full reset on the unit. Disconnect from the wall for 24 hrs. Then try again. If the problem persists, it may have power supply issues, or a DC offset problem shutting it down. If you are game, I could talk you through some more diagnostics...
regards
Graeme
Posted on Apr 01, 2008
SOURCE:
I have no sound coming out of the sub rca output
Was it there when you ran the test tones?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-VR-405-Receivers-manual/id/480ag202/t/2/
Start on Page 15
Mar 06, 2011 | Kenwood VR-405 Receiver
I have a Kenwood vr-405 and for the most part it works. I have been noticing that one front speaker is quite a bit louder than any other speaker. I have tried to adjust it many times and it seems like...
Maybe you should first isolate the problem to the receiver or the speaker by swapping the front speakers with each other to see if the loudness stays with the channel of the speaker.
Or, the acoustics of the room just make that speaker seem louder at the listening position. Try taming it with the adjustments provided in the receiver.
The manual can be found at http://www.retrevo.com/s/Kenwood-VR-405-Receivers-review-manual/id/480ag202/t/1-2/
Aug 18, 2010 | Kenwood VR-405 Receiver
Kenwood vr-405 turns on only momentarily and then shuts off
your receiver has a bad audio output ic.replacing ic will take care of the problem
Apr 10, 2010 | Kenwood VR-405 Receiver
Subwoofer doesn't work in stereo mode on kenwood vr-405 receiver
such is the case with sony receivers when stereo mode is used
Nov 01, 2009 | Kenwood VR-405 Receiver
Does kenwood VR-405 play DTS-HD Master
I have the 405 and a Samsung 3600 which has onboard DTS Master/ Dolby True HD. Out of the 6 movies I 've watched, only 2 have given me Dolby Digital. Bottom line: If the movie doesn't have DD, you cant get DD on the 405. I thought just about all blu rays had DD but its not so. Its time for us to upgrade!
Oct 24, 2009 | Kenwood VR-405 Receiver
Vr-405 no sound - looking for service manual
Try cleaning cleaning all the switches/connections you can. The fact that it sometimes works indicates that the components are good but that you have an intermittent connection somewhere such as a bad solder joint
Aug 26, 2017 | Kenwood VR-405 Receiver
Kenwood VR-405
more info would be nice. If you're using optical, make sure its securely in both the tv and your vr-405 receiver. I have owned the vr-405 since 2000 and i just purchased a sony 32xbr6. HDMI into the TV, optical out to the receiver, it sounds amazing!
Dec 01, 2007 | Kenwood VR-405 Receiver
Kenwood VR-405
you have some wire touching or cross.
Nov 21, 2007 | Kenwood VR-405 Receiver
Kenwood VR-405 Receiver Logo
328 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
