posted by DocterJ16 on Apr 01, 2008
I want to make a hard reset on my phone, but i have no idea how to, is there a way to hard reset my Razr v9?
Comment by DocterJ16, posted on Apr 03, 2008
This is a verizon phone.
Best Solution
posted on Apr 01, 2008
- Menu
- settings select
- initial set-up select
- master re-set select
Rating Locked! (?) DocterJ16 has rated this solution as Thanks for Trying
Solution #2
Hello DoctorJ16,
If you mean hard reset as in reflashing the unit with software, it shouldn't make too much of a difference. Are you experiencing a problem with the unit or you just want to set everything back to default?
You can get similar results by performing the master clear and master reset option.
Go to the Menu and click on Settings
From there you'll want to scroll down to "Initial Setup"
Scroll down to the bottom and you will see both Master Clear and Master Reset.
I suggest you do the Master Clear first, the code should be six "0", entered "000000".
After which you can perform the Master Reset, same code.
Hope this helps,
cHiPz.
Hope this helps,
cHiPz.
Suggest a new solution for this problem
Post a New problem for Motorola MOTORAZR2 V9 Cellular Phone
Email this problem
Email this problem
Can you Help with these Cellular Phones problems?
Motorola razr2 v9
Motorola razr2 v9
When you hide a number in your... Answer This...
external touch screens
only have music external touch... Answer This...
phone will not turn off by...
My keypad works well, excey!... Answer This...
Repair Service
Find Cellular Phone Repairman Near You:
