Question about Panasonic DMR-ES35VS
Panasonic DMR-ES35V with U61 error code
I have a Panasonic DMR-ES35V and get a U61 error code when I power on the unit. The error messae states self check failed.
Any solution other than get a new one?
  • 3 more comments
  • Anonymous Apr 27, 2008
    Can not regonnize the DVD
  • cheyennem May 30, 2008
    i have the same problem error U61 on a
    DMR-ES35V, any idea how to reset or erase this message??
  • bobo45 Jun 10, 2008
    Having same problem in St. Louis - U61 Error Message; have even tried disconnecting power supply.
  • Steve1001 Jul 23, 2008
    Have exactly the same problem as you have described, except this is the third time it has happened to my unit. Fixed twice by repairer whilst under warranty, now out of warranty and it is still broken. Have tried powering down the unit and rebooting but to no avail. Have approached Panasonic who have offered an out of service warranty claim procedure but they will not commit in a dollar amount how much they may assist me in my repair bill or if they will assist me at all with my repair bill. It's all a bit of pie in the sky assistance by Panasonic
  • mark179 Nov 25, 2008
    I have the same problem with DMR-ES35V giving the u61 error message. Then it ejects the CD tray and powers itself off automatically. The only solution I have so far is I have already bought a SONY replacement. This one was only one month past the 1 yr. warranty period That is just not acceptable that things are only made to last one year. I contacted Panasonic who agreed to ship it to Indiana or somewhere for $130 plus parts. I then had a Sears repair store send it to try for $29.95 minimum... they sent it back and said it needed a new hard drive... approx $370. That's why I bought a competitor's. I still need this one fixed if the hard drive is not fried.
2 Suggested Answers
shinma
  • 5 Answers
SOURCE: Error code U61 on a
The manual refers to the U61 as being a recovery mode. Have you left it at U61 for a period of time while it tries to recover?
U61 ≥There was a power failure or the AC plug was disconnected while the unit was on. The unit is
carrying out its recovery process. This process restores the unit to normal operation. The unit is not
broken. Wait until the message disappears.
You could always try to force it into standby mode and back out again:
Press [í/I, POWER] on the main unit to switch the unit to standby.
Now press [í/I, POWER] on the main unit again to turn the unit on.
If that doesn't take care of it, everything thing I've found points toward a replacement of components inside the system by a repair service. Hopefully you are still under warranty!
Posted on Sep 21, 2008
  • 55 Answers
SOURCE: PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
Posted on Apr 22, 2009
I have a Panasonic DMR-EZ47VEB and after recording overnight next morning dicovered the machine had swiched off with the word"Hello" on the front display. When switched on the unit displayed the...
U61 is a common fault in the Panasonic DVD recorders. It is generally a failure of the DVD-RAM drive and/or the digital controller board (in some cases it is both and both must be replaced together as a module). Unfortunately these are not repairable at individual component level; they would most likely need to be replaced and fitted by a qualified technician in an authorised Panasonic service centre. The only trouble here is the potential cost(s) involved (such as labour, the DVD drive, etc) - could be expensive and/or uneconomical. However, you can always submit your unit to a repair shop for a quote and a second opinion (on the costs of the replacement part(s) as well as estimated labour charges and the extent of the problem - this allows you to make an informed decision afterwards to get this fixed, but it is up to you.
The cost of a new DVD-RAM drive (if that is the actual problem, and not the board it is connected to) is quite high; anywhere between $130 US (for XVY1961 to suit DMR-ES35V/DMR-EZ47V models) up to $450 AU for the same device plus labour costs should you choose to have it replaced.
I assume you like your unit and want it working properly. If you do decide to deal with an authorised Panasonic service centre, ensure that when the work is completed they provide a detailed report, and some sort of warranty on that repair, especially if it involved replacing the DVD drive. Unless you have an extended manufacturer's warranty on this; which means it won't cost you anything to have it assessed and repaired fully.
Apr 21, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Paqnasonic DVD recorder Model DMR-EZ45VEBS is stuck with error code U61, and now will not play any disk. Every time I insert a disk it comes up with the error code, Problem started whnI was recording a TV...
try cleaning the OPTICAL LENS directly with a Qtip , gently rub , try again , the code U61 means a self test procedure that the unit is running according to PANASONIC tech people, good luck , AJ
Nov 30, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dmr-es35v dvd/vcr recorder reads hello, then u61, then
Plug AC power cord to wall electric socket if it is plugged into a surge protector or extension, if not try a different socket, if issue still exist have unit service.
Sep 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47VEB stuck on self check
Check IC in primairy power supply
Aug 29, 2009 | Televison & Video
From User guide:
Feb 26, 2009 | Panasonic DMRES15 DVD Recorder
Error code U61 on a panasonic DMR-ES35v When I turn it on it says "Please Wait" end the code U61 occurs after som while.
Aug 30, 2008 | Panasonic DMR-ES35VS
component failure, the DVD Disk Drive Control Board
(Part No. VEP79132).
Panasonic will not sell this individual part but packages it a module, called the RAM/Digital PCB Module
(Part No. RFKNES15P).
Aug 20, 2008 | Panasonic DVD-LV50 Portable DVD Player...
Panasonic dmr-es35v dvd recorder
It can be repaired however I am not sure if the hard drive is available for that unit or not. I would contact panasonic to inquire as to the availability of a new drive.Sorry I couldnt help you more with it.
Apr 06, 2008 | Panasonic DMR-ES35VS
Panasonic DMR-ES35VS Logo
436 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
