Question about Arris WR850G Router (DHWR850G)
WR850 Install Problem on new VAIO Laptop with VIsta
New VAIO Laptop. I enter WEP address. It states it is invalid. I reset the WEP address on my Motorola WR850G Router to make sure the WEP address is correct. SO.....
I then try to install the Motorolla software on the new VAIO Laptop that is running VIsta. It goes through the who process unitl it veries IP address. It times out stating: "In order for the installation wizard to communicate with the device, your computer settings must be changed to use Dynamic IP addresses (DHCP). I have gone through the control panel to make sure it was not set on TCPIP and to find an IP address. It still does not work. ANy advice on how to get this darn computer to connect wireless to the internet? I am able to access this website by connecting the Ethernet Cable from the Cable Modem to the WIreless Router and then to my PC.
Please help. I would appreciate any assistance.
MIke from Atlanta.
  • Anonymous Aug 03, 2008
    same problem
Try to change your OS! frfom VISTA to XP. because sometimes the problem is in not the router rather the problem is, conflict bet. IPv6 and IPv4.
Posted on Apr 28, 2008
SOURCE:
Wep key invalid ? but correct wep key?
In which computer you have inter net in that computer please click on START and click on RUN in that box enter CMD. You will get command mode. In that command mode type this command. 'ipconfig'. You ll get the ip address and gate way. Please close all of the window and open internet explorer in that same computer and enter the gateway ip address in that address bar. it will open new webpage. then enter the username and password of the router. in that window you can find the wireless settings and security key. If you don't know the username and the password of the router please open this link and find the name of your router in this page and take the username and the password. The Link is : http://www.phenoelit-us.org/dpl/dpl.htm
Aug 02, 2011 | Computers & Internet
Hi,my Sony Vaio VGN-N21 won't open vista, it asks me if I want to take the recovery option or open windows as normal ... I've tried both options but it just restarts then loops me back to the same error...
Try this...
on the just after opening the power of the laptop...continiously tap F8 until a new window opens for ADVANCE BOOT OPTION...then look for safemode with the use of the arrow keys choose that option and press enter...from here on you show be able to log to the windows screen in a basic setting... if you know how to do system restore please try it...
Oct 01, 2010 | Sony VAIO VGN-CR220E/P Notebook
Router does not accept mac address
in network adapter properties enable dhcp reset router
Apr 07, 2010 | D-Link DIR-615 Wireless Router
We have anew acer p.c, and cannot access the internet. it accepts the wep key. help. wireless linskey, 3 other p.c.s no problem.
What is the operating system of your laptop? Is it running Windows Vista or XP? Can you check if you're getting an IP address wirelessly?
Go to start>run>type cmd and then hit enter.
On the black screen type, ipconfig/all and see if you're getting an IP address similar to the IP address of the other working computers. If not, then that is the problem, that means that the wireless security that was entered on your new laptop is incorrect. To make sure that you entering the correct key, save your security key on a notepad and then copy and paste it on your wireless adapter settings.
Jun 27, 2009 | Linksys Computers & Internet
Motherboard replacement instructions vaio vgn
IF YOU CHANGE THE MB.. SHOULD THE PCU IS COMPATIBLE WITH THEN MB.. ABOUT THE RAM SHOULD BE COMPATIBLE ALSO...LOOK THE COMPATIBLITY OF YOUR SPESIFICATION OF YOUR SYSTEM.... THE VIDEO GRAPHICS ACTUALLY IS BUILT IN THE MB JUST INSTALL THE RIGHT DRIVER.. ABOUT THE BIOS NO NEED TO RESET.. AFTER THE FIXING THE MB..FORMAT YOU HDD. OR INSTALL NEW ONE NOT OLD.. BECAUSE NEW MB.. IF YOU USE THE OLD OS YOU WILL MEET A LOT OF PROBLEM,, LIKE BLUE SCREENN,, AUTOSHUT OFF,, SOUND NOT WORKING, OR ANY POSIBLE BECAUSE OF FEATURES SOMTIMES.
Jun 24, 2009 | Sony VAIO VGN-FZ230 FZ Series Notebook
Cannot connect to DLink DIR-655
The part below is all you need to look at, the rest is Ethernet which is your wired connection, ethernet card.
Here is what are causing your problems from what you gave me and basically your computer is not communicating with the router:
1)I don't see any IP address for your laptop so you can't get on the internet if you don't have an IP address, also, I don't see any gateway address. The gateway address is your router address, and that address is given to the router automatically from your Internet Service Provider.
So if your computer cannot see the gateway address then the gateway address (router) cannot give you an IP address to get on the Internet.
Your Wireless card looks ok, that is the physical address and if you were able to do the loopback then its working.
So on your laptop I would begin from the beginning. Go into network connections and delete the DLink connection if it is there. Then Start>control panel>Network connections>click wireless network connection>click change settings of the connection on the left window>click wireless network tab>make sure checkmark"use windows to configure my wireless network settings>click add a new network>TYPE IN THE SSID FOR THE NETWORK>ENTER WEP/WPA KEY>CLICK OK, then close and you should be connected.
You said other computers are able to access the internet thru the DLINK so it all points to your laptop not being configured correctly.
HOWEVER :)...I see alot of "Media disconnected in your list. Make sure all of the lights are working on the front of the router, if not check the cabling or call the ISP sometimes the problem is on their end. Hope this helps, keep me updated.
C:>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : HPdv7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5009 802.11a/g/n WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2B-12-FD-63
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
May 01, 2009 | D-Link Xtreme N DIR-655 Wireless Router
HP laptop not recognizing Linksys Wireless B Security Key..
The WEP encryption is consist of 10 characters for 64 bit hex, 128 bit hex is 24 characters and WPA is 8 to 63 characters. So it seems that you have a vista computer? The compatible encryption for vista is WPA, sometime using WEP it is not working properly. So I might advise you to access the configuration of your router (192.168.1.1) and change the wireless settings of your router to WPA-Personal.
Mar 09, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Invalid address
First, you have to make sure that you are in the right state. If you are looking for an address in Virginia, but the GPS is set to locate addresses in Tennessee, the address will be invalid. Try going into the settings to be sure that you are searching the correct area.
Feb 05, 2009 | Magellan Maestro 4040 GPS Receiver
Ip address
Reboot the laptop a couple of times and it should pick up a new address
Dec 11, 2008 | Linksys Wireless-G WRT54G Router
Open Questions:
naSHI^%@#$ Amazon Prime rEfUnD pHoNe O*^%{+1++85O++8I2++4OO9*^ how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 21, 2019 | Amazon Computers & Internet
See all Arris WR850G Router (DHWR850G) Questions
Arris WR850G Router (DHWR850G) Logo
207 people viewed this question
Top Arris Computers & Internet Experts
Ekse
Greg Ulan
Ann Moroz
Ann Moroz
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
