Ricoh cn 4100 printer
I am getting the service code 442 and cannot figure out what it is or how to solve it
  • 87 Answers
Its a problem with your transfer belt. Either not turning, or bad connection.
Posted on Apr 01, 2008
How do I turn off user codes
There are no internal user codes. User codes are only via the print driver. Is the correct IP Address, Subnet Mask, and Gateway Address entered into the printer?
Jan 06, 2015 | Ricoh Office Equipment & Supplies
How so I clear error code SC 442 on Aficio SP C811DN?
This is a ITB contact motor error.
Check/clean/replace contact sensor.
Replace transfer belt contact motor.
Check harness and connectors to motor and sensor.
Check for mechanical binds.
May 19, 2014 | Ricoh Intermediate Transfer Belt Unit for...
Ricoh Aficio MPC 2500 error SC 442
image transfer belt contact sensor is dirty clean it
Feb 17, 2014 | Ricoh Office Equipment & Supplies
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
SC 107 code
The error SC107 means Lamp regulator malfunction.The possible are
--Lamp regulator defective(Pcb)
--Exposure lamp open
--Optics thermoswitch open
--Scanner control board defective or poor connection
This is a very old machine so I hope you have some luck solving the problem
Feb 24, 2010 | Ricoh Office Equipment & Supplies
Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Jun 09, 2009 | Ricoh Aficio AP3800C Laser Printer
I have a Ricoh 2045E I changed the toner and now get a SC680 error?
There are no SC 680 codes listed in the service manual for a 2045e
Please re check the code
Feb 26, 2009 | Ricoh Aficio AP3800C Laser Printer
Can i have solve my proplem is sc 542
sc542 is a fuser code that needs to be reset by a service technician. It may be just a dirty sensor or it could be something more serious. Contact your local Ricoh service tech for assistance.
Oct 20, 2008 | Ricoh Aficio AP4510 Laser Printer
Getting "service code 442" on startup
SC442 Transfer belt contact error The transfer belt contact sensor does not detect the movement of actuator at the sensor while the polygon motor rotates. • Dirty transfer belt contact sensor • Defective transfer belt contact motor • Disconnected connector of transfer belt contact sensor or motor • Disconnected cable 1. Replace the transfer belt contact sensor. 2. Replace the transfer belt contact motor
Apr 01, 2008 | Ricoh Aficio SP C410DN Laser Printer
164 people viewed this question
jasbo
jasbo
