Samung dlp problems
My samsung dlp is shutting off on its own and doing it more often... it doesn't make the normal shut off sound... it just shuts off.
  • hacim Apr 01, 2008
    I actually used to get a blinking red light on the front, any time it was on. However, it hasn't been doing that for quite some time. And now this problem occurs... are those issues connected? I will get the model number later, but it is a 50 inch I purchased about two years ago from circuit city.
  • Juudjr May 11, 2010
    Are you getting a red blinking power led? If so count the times it blinks then pauses. This is an error code which may help narrow down the circuit which is failing. Need model number also.
  • 81 Answers
Samsung dlp's are known for this and the board must be replaced. check and see if recalled.
Posted on Apr 01, 2008
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP
Yup definitely sounds like the ballast, if not then you have a problem in the power supply. Probably some bad capacitors. Call a local tv repair shop.
Nov 28, 2009 | Samsung DLP HL-P5663W 56" TV
My samsung DLP hls5687wx xaa shuts off by itself. How do I fix it?
The lamp ballast or Color wheel might be the problem. We have experienced both issues with the tv shutting down. Also check the hours on your lamp as it might be getting old.
Jul 07, 2009 | Samsung 56" Slim-Depth LED DLP HDTV
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung dlp turns on for few seconds and shuts off
lamp shuts off first..with sound still on and black screen.then turns off and has three blinking lights on front panel.
Jan 10, 2009 | Samsung DLP HL-P5663W 56" TV
52" Samsung DLP
It is unlikely that you can do anything yourself.
It sounds to me that there is a power supply problem that has steadily gotten worse and that cannot be confirmed remotely, it must be done on site by an equipped professional.
May 13, 2008 | Samsung DLP HL-P5663W 56" TV
PROBLEM WITH SAMSUNG DLP TV
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Apr 07, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP TV HL-R5667W shuts off intermittently
Afraid there is no simple answer to this. This set has multiple things that could shut it down, one may be the balest needs a upgrade , this could be why it seems to be eating lamps. Another is what sounds like a fan is a color wheel , these have known problems of failing, and when this happens sometimes they shut down the set. And finaly does the set have good ventalation, overheating can cause huge problems with this set
Feb 13, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
138 people viewed this question
Top Televison & Video Experts
