Question about Baby Lock Evolve
Warning screen When I turn on the sewing machine the pressure foot is up but the warning is on the screen that the pressure foot is down. I have moved it up and down but he warning stays. It only happens with the embroidery unit on. Thank You, Kippi
  • 3 Answers
I don't think you have an evolve, dear. It's a serger. If you put this question under the right product, you will get helpful answers. All I can think is that your machine wants the feed dogs lowered manually? I have no other suggestion.
Posted on May 07, 2008
It seems the problem is the excess pressure of the foot when down.. it must somehow be related to thread tension.. can I change foot pressure?
Depends on the make/model of your machine. Most machines do have a pressure adjustment for the presser foot. Sometimes it is explained in the owner's manual.
Newer machines have a dial somewhere. Older machines will have a screw at the very top of the presser foot bar (sometimes under the top cover). Turning the screw right will increase the pressure, left will release it. Other machines have a plunger type projection on the top left of the machine. Pushing the plunger down will increase the presser foot pressure. To release the plunger, press down on the ring that encircles the plunger.
http://makeitsew.biz/presser-foot-pressure
http://www.sewdaily.com/how-to-sew/sewing-machine-basics/the-best-kept-secret-on-your-sewing-machine
Sewing Machine Pressure Settings for Machine Quilting
Dec 29, 2016 | Sewing Machines
The pressed foot lifter won't hold the material, I can push it up down turn it around this is not right
Are you saying the presser foot has very light pressure on the fabric? If so, most machines have the ability to increase the pressure the presser foot applies to fabric and feed dogs. It depends on your machine's make & model where & how that pressure is adjusted. Older machines usually have a large skrew or knob at the top of the needle bar that tightens down on a big spring, thus the tighter spring increases the pressure. Newer machines sometimes have a dial usually located on the top left or side of the machine head. (Consult your owner's manual.)
The Best Kept Secret on Your Sewing Machine Sew Daily
Parts of Sewing Machine Pressure Adjustment
Under Pressure Adjusting Presser Foot Pressure
May 25, 2016 | Sewing Machines
I am using my walking foot to stitch in the ditch my quilt. The foot is not pulling my fabric through consistently.
The quilted fabric may be too thick for the walking foot to move along smoothly. Try using a zipper foot which is much slimmer and can get close to the line of stitching.
Apr 18, 2015 | Brother CS6000i Computerized Sewing...
When I put the presser foot down and begin to stitch, the needle just keeps sewing in the same place, and the presser foot won't allow me to easily move the fabric.
You might want to see if the drop feed control is down. There's a switch (for my Singer machine, you have to take off the removable sewing table/storage, and the switch is behind the machine)...if the drop feed is down, you can't see the "teeth" as I call them which grips the fabric.
Another idea is to back stitch (reverse sewing lever) a couple stitches and then try sewing.
Make sure the foot speed control is hooked up correctly. https://wiki.artisansasylum.com/images/0/0f/Sewing_Machine_--_Singer_3116_--_Manual.pdf This is the manual for your sewing machine model you posted. Good luck.
Jun 13, 2014 | Singer 3116 Simple
Feeddog won't move with pressure foot down. I have a Baby Lock BL4-428. I haven't used it in a while. I cleaned it up and oiled it. The feeddog moves when the pressure foot is up but as so
it sound like the feed dog & the presser foot need to be adjusted
so they work togeather,,it's very possible they need to be timed
a sewing machine repair shop can tell you for sure
Sep 05, 2012 | Baby Lock Sewing Machines
Hi the pressure foot in my toyota RS2000 does not move when i try to sew. What could be the problem
check the feed dogs that are under the needle plate to see if there up or down,, if they are up you can feel them when you slide your finger over them,, only if there up can the machine sew,
the pressure foot holds the fabric against the feed dogs & the feed dogs move the fabric
Aug 26, 2011 | Toyota STF39 Mechanical Sewing Machine
What is pressure foot on sewing machine. where is pressure foot
This is the foot that comes down and holds the fabric layers under the needle.
There will be a pressure foot lever to raise and lower the pressure foot at the back of the sewing area, it usually operates vertically, although some makes have a lever that works horizontally.
The pressure foot needs to be lowered BEFORE you start stitching as it activates the top tension and also helps with the stitch formation by holding the fabric firmly as the needle moves up and down.
You can read some general sewing machine info at www.sewing.about.com too.
Mar 29, 2011 | Janome Harmony 2039 Mechanical Sewing...
Cloth will not move forward
Cogs are feed dogs.
Check your manual to see if there is a pressure adjustment for the presser foot.
This may be a nob on top of the machine directly over the presser foot.
Turning the adjustment left/less or right/more pressure.
Also, refer to the manual for cleaning the bobbin and feed dog area as lint may be causing a bit of the problem.
May 01, 2010 | Elna 2005 Mechanical Sewing Machine
Very old Necchi sewing machine - sews in place
sounds like the feed dogs may be down or not working. Watch to see if the little teeth are moving under the pressure foot when you stitch( try to run unthreaded and with foot up no fabricto check) May be a button to turn up the feed dogs.
Oct 27, 2008 | Necchi 3101 Mechanical Sewing Machine
Sewing Machines Logo
79 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
