Question about Canon PowerShot A520 Digital Camera
Problem I have a Canon PowerShot A510, PC 1107, I bought it from Malaysia in 2005. It worked well. But since last 6 months no batter is working. I have changed batteries and also the charger. Can u pls suggest which battery should I use?
  • Anonymous Apr 11, 2008
    Bought in 2005 Oct. Recently, fell on the floor while the lense is open. Now, it is stuck in that position and doesnot work at all. Changed batteries. no luck.
  • 477 Answers
Goto http://www.digitalcamrepair.com/self_diagnosis_page.htm
for self diagnosis.please let me help you before leaving a bad feed back.
Posted on Apr 26, 2008
How to get a manual for a canon PowerShot A510 camera
You may download the manual and more from the Canon website here.
Jan 08, 2013 | Canon PowerShot A510 Digital Camera
What is the maximum size of an SD card that can be used in a Canon PowerShot A510?
You can use any size SD card. Just keep in mind that SD cards max out at 2GB; any larger cards are actually SDHC cards and will not work in the A510.
Feb 05, 2011 | Canon PowerShot A510 Digital Camera
I have inserted a new PNY optima SC HC memory card and window in camera says "memory card error". Does the canon not take this card?
Correct. The A510 uses SD cards, not SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work.
Nov 02, 2010 | Canon PowerShot A510 Digital Camera
Canon Powershot A510 - black screen
well giving it a tap/thump it might have a dry joint ....
Sep 14, 2009 | Canon PowerShot A510 Digital Camera
Cannon a510 memory card error
Yes, Don't panic please.
Simply, just take memory card outside and attach it to your laptop or PC. FORMAT that memory card using FAT32 and you will get it working again.
May 28, 2009 | Canon PowerShot A510 Digital Camera
Can't format memory card in A510 Canon digital camera.
Have you used this card in the past? Is this a new card?
Is this card rated to be used with this camera. Some cameras can only support cards of certain sizes.
If the card is compatible, take the card to target or best buy and format it on a camera there and see if it works then put it back in your camera and see if it works after.
Mar 07, 2009 | Canon PowerShot A510 Digital Camera
How do i change the movie resolution canon a510
set the camera in movie mode.
press the function(f) button.
select up and down arrows to select your selection.
Mar 05, 2009 | Canon PowerShot A510 Digital Camera
Your LCD display might have switch off by mistake.
Press on the display button in the camera.
Jun 09, 2008 | Canon PowerShot A510 Digital Camera
Problem in Manual Focus of Canon Powershot A510
Some how it seems the auto focus- which in macro mode is looking at something else[because of parallax]is over riding your manual focus attempts. Check the manual carefully to see if there is a mention here for special things to do for close work or contact the Canon Technical Support
May 15, 2007 | Canon PowerShot A510 Digital Camera
Canon PowerShot A520 Digital Camera Logo
85 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
