Hp deskjet 960c
My printer will not print. get an popup asking for file name to save loads jobs on printer but will not restart or resume printing..
    Problem Solver:
  • 7 Answers
Go 2 : ADD/ Remove , Delete the Printer & All related in [ regedit ]
-> Re-install & THEN Plug the USB Back in !
Posted on Apr 01, 2008
I have a manul I'm wanting to print, but now I don't want to print it. How do I stop it? And also it is printing little boxes (Not the words) What do I do about that?
Runaway print jobs are always a pain! First, power off your printer to stop it from wasting paper. If the power button doesn't work, pull its plug. That will stop the printing for now but your print job will probably restart when the power is resumed.
Whether you are using a PC or Mac, documents that you send to the printer are managed by a printer management service which is responsible for printing documents in the correct order and handling any printer problems that occur. When the printer is turned off, any documents you print will be saved (queued) for printing when the printer starts again. To fix your runaway printing problem you simply need to delete the copy of your large document that is still queued for printing.
On Windows you will see a small icon on the toolbar at the bottom right of your screen that looks like a printer. When you click on the icon you should see a window appear which has the name of your printer in the title bar (e.g. HP Deskjet) and a list of any documents waiting to be printed. To delete a print job, simply right-click on the document name in the list and select "Cancel". When asked "are you sure you want to cancel the document" click on YES and the document will be deleted from your printer queue. Repeat this for all documents in the list until it is empty, then you can restart your printer.
The process on a Mac is similar and even easier since you will see a bouncing printer icon with an exclamation point on it on your toolbar. Click on that icon to see the print queue, click on the document you want to delete and press the DELETE key to remove it.
Jul 30, 2013 | HP DeskJet 6540 InkJet Printer
Hp deskjet 948c. What Do The Button's Do
buttons and lights The HP Deskjet printer buttons let you turn the printer on and off, cancel a print job, or resume printing. The lights give you visual cues about the state of the printer
sayurisan20_33.jpgcancel button
print cartridge status symbol and light **The light above the Print Cartridge Status symbol flashes when a print cartridge is low on ink or incorrectly installed.
sayurisan20_35.jpg resume button and light
**The light above the Resume button flashes when an action is required such as loading paper or clearing a paper jam. When the problem is fixed, press the Resume button to continue printing.
sayurisan20_36.jpg power button and light **
The Power button turns the printer on and off. It takes approximately five seconds for the printer to turn on after you press the Power button. The green light above the Power button flashes when printing is in progress. Caution! Always use the Power button on the front of the printer to turn the printer on and off. Using a power strip, surge protector, or a wallmounted switch to turn the printer on and off may cause premature printer failure
Jun 17, 2011 | HP Office Equipment & Supplies
My HP Deskjet 960c was out of black ink I replaced the cartridge and now the ink light is blinking and will not print.
Check if you replaced it with the correct ink cartridge or return to supplier for a replacement.(Also ask your supplier to test it)
Apr 24, 2010 | HP DeskJet 960c InkJet Printer
I am getting unwanted black stripes when i do colour-printing. on my old pc i used to be able to clean/test the printing head but i dont have that facility now & can't see it on the net. any tips...
First run a cleaning cycle and test print. You can get this from Control Panel - Printers - Select Printer name and right click - select Properties and then Maintenance.
Then
1. Select Normal or Best, rather than Draft, in the Paper Type/Quality option in the Page Setup Screen.
2. Align the print cartridges. Select the Calibrate panel on the HP deskjet utility screen, then click the Align button.
3. Decrease ink density or drying time.
a. Click File > Print > Paper Type/Quality.
b. Click the Ink tab.
c. Use the sliders to adjust ink density and ink dry time.
Oct 07, 2009 | HP DeskJet 960c InkJet Printer
How can I stop my hp deskjet 960c from printing unwanted pages once it has started printing?
Turn the printer off and unplug the printer cable from both ends (printer and computer ) and cancel the documents from the printer list.
Sep 25, 2009 | HP DeskJet 960c InkJet Printer
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Jan 22, 2009 | HP DeskJet 960c InkJet Printer
In between print jobs all three light (and the power) on my deskjet 960c went out, and despite several attempts to woo them on again, it looks like that part of the system in dead. Do these symptoms ring a...
Is it still printing properly? If so forget about the LED's and control the printer operation from the PC itself.....otherwise visit their service center for repairs....sodeep
Dec 26, 2008 | HP DeskJet 960c InkJet Printer
Printer won't stop printing garbage
Try and re-install your printer drivers...first remove the drivers and delete the printer...then re-install.
Dec 03, 2008 | HP DeskJet 812c InkJet Printer
HP Deskjet 960c will not print
Hi, I have the driver files that you need but the size is 15Mb and also I am unable to send you the link so you can download it yourself as it requires a member login. So...can you email me and I will reply sending an attachment with the files in it.
Hope this helps,
Let us know
SeaJade
Nov 27, 2007 | HP DeskJet 960c InkJet Printer
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
