The red brake light tells you you are low on fluid or that your parking brake is engaged....the abs light tells you your anti lock braking system is malfunctioning. get the car up to 40mph and SLAM on the brake pedal. the pedal should pulsate and the wheels should as well. if the wheels lock up and you slide to a stop, your antilockbrake system is malfunctioning and you should have a certified mechanic check it out......tires plus and midas both do free brake inspections.......
