Hp officejet 4315v all in one
I had a power failure durring an incoming fAX,,IS THERE ANYWAY TO RETREIVE THE FAX?
  • Anonymous May 29, 2008
    I have 2 hp officejet 4315's one made a loud banging noise and then any fax or print was coming out striped. I need to know what is wrong with this one if it is worth fixing or not. Then I replaced that one with the other one I had. I can fax out but when I try to receive a fax it says no connection. Not connected to computer. The fax should come through my devoted fax line. If I can fax out I should be able to receive. Please advise me on these 2 problems. Thank you Marguerite
How do I set the date and time on the all-in-one hp 4315v
Posted on Aug 04, 2008
My printer was unpluged. i put it back, now my printer will not work,help
Posted on Apr 21, 2008
  • donparr Nov 11, 2010
    To set the date and time
    1. Press Setup.
    2. Press 6, and then press 3.
    This selects Tools and then selects Date and Time.
    3. Enter the month, day, and year by pressing the appropriate numbers on the
    keypad. Depending on your country/region setting, you might enter the date in a
    different order.
    4. Enter the hours and minutes.
    5. If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM.
    The new date and time settings appear on the display.
SOURCE:
I disconnected the hp officejet all-in-one from my computer and later reconnected it. Now it thinks its a fax machine, and won't print from the computer.
it (Hp officejet 4315v series FAX) must be set to default that's why it would not print.The default printer should be the Hp officejet 4315v series,the one without the word fax in the end.
Here's how you do it:
for windows XP operating system
  1. click on the start button on your computer.
  2. click on printers and faxes.If it is not on the start-up list you can click on control panel ,click on printers and faxes or printers and other hardware.
  3. in printers and faxes,it will display all the printers installed on your computer
  4. look for officejet 4315v series or officejet 4300v series then right-click on it's printer icon then left- click on set as default.
  5. try printing from the computer.
for windows vista operating system
  1. click on the start button on the computer
  2. in the search box,type in printers,hit enter key on the keyboard.
  3. in printers,it will display all the printers installed on your computer
If it does not print download the print diagnostic utility from the hp website.It is a helpful tool in diagnosing printing problems.I will provide you the link.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-91793-1&lc=en&dlc=en&cc=us&os=228&product=1138346&sw_lang=
Jul 09, 2011 | HP Officejet 4315v All-In-One InkJet...
Hello all I have a hp 4315v all in one printer /fax and i would like to see if the fax is working is there a test number i can use to test it out with
HP has a Fax no. to test.
Send any test page as fax on the 1-888-473-2963 and wait till it is send. Once the fax is sent, you will receive a fax as notification ( confirmation ) of the fax being received by HP.
This above no. sometimes is busy so you may need to give couple of tries till you succeed.
Or the best way is to send fax to any of your friend who owns a fax machine and ask them to send fax back to you.
Regards,
Ron
Mar 07, 2011 | HP OfficeJet 4315V All-in-One Printer
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
4315v Officejet all in one not faxing
Perhaps it is not connected to the phone line? Maybe you don't have a fax number set up? If your phone is having issues, it will affect this.
Apr 20, 2010 | HP Officejet 4315v All-In-One InkJet...
Hp4300 series disc won't work with my new hp window vista computer my printer is a 4315v
Please perform the steps given below and check if yuo are able to fax
1. Open a MS Word Document.
2. Click File -> Send to -> Recipient using a fax modem.
3. Follow the instructions given in the fax wizard. Ensure that you select the HP all-in-one as the fax program.
Now check whether you are able to send the fax.
OR
Try setting up the Fax once again
=== Fax Setup wizard ===
- Double-click on the HP Solution Center to open it.
- Go to Settings --> Fax Settings & Setup --> Fax Setup Wizard.
Complete the fax setup wizard and then, try to fax
Vishwanath V U
May 19, 2009 | HP Officejet 4315v All-In-One InkJet...
My HP 4315v won't fax or receive faxes. What can I do?
printer said check manual, cartridge problem. i also tried to fax, would not let me.
May 01, 2009 | HP Officejet 4315v All-In-One InkJet...
HP Officejet 4315v Error Code 344*
1. issue may be with telephone line conditions,  try sending a fax at a different time 2. Disable Error Correction Mode 3. reduce thefax speed 4. try a fax test to  hp at 1888 473 2963
Jan 26, 2009 | HP Officejet 4315v All-In-One InkJet...
I have a hp officejet 4315v all in one fax machine i can send a fax but i cant recieve.
Try unplugging and plugging in again. Many modem failures on this model.
Aug 26, 2008 | HP Office Equipment & Supplies
Fax problem
I am having a problem receiving faxs, please help.
May 20, 2008 | HP Officejet 4315v All-In-One InkJet...
Open Questions:
521 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
