Question about Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A
Door When this freezer was new, the door made a sound like air excaping when being closed. The freezer does not make this sound now. The freezer was purchased new Aug. 8, 2007. FFU2124DU
  • DEan R Larson Apr 18, 2008
    Thanks for the suggestion. The freezer did not have frost and it was still freezing. A service man was contacted, but so far I don't have his results.
  • 145 Answers
If the door is not sealing because of frost build up or product blocking it it won't make the noise. Is it still cooling ok? If you haven't defrosted it you might do this now. Is it in a cold location, i.e. unheated garage up north? This can cause it also. Check the door and the cooling first if it's not right I would call for service. You should have a one year warrany.
Posted on Apr 18, 2008
Freezer door does not make vac sound
Might need a new seal.
A better test than sound is the put a dollar bill in sealing area and close door. Check how hard it is to pull dollar out (check tightness).
Do this all around the door in various spots.
Jul 22, 2013 | Freezers
My freezer has condensation inside
Hi - From what you have described it sounds like the freezer has a poor door seal. When cold air and warm air outside is entering it causes condensation. Try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then I suggest contacting your manufacturer and see who they recommend to repair the unit.
Oct 06, 2012 | Frigidaire Freezer 16.7 Upright Freezer,...
I have 20 cf Whirlpool model #evl202nxtn freezer,I can feel cold air from the top of the door seal.Anyway to stop this with out replacing the seal.The freezer 18 mth old.Thanks
oh wow . i have the same freezer with same exact problem. i bought it brand new. i can definately see the seal on top is not installed properly. i always thought it was only my freezer but i guess its a manufacturing issue.
Sep 24, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Door was left very slightly open. reclosed but so...
This is normal when compressor starts u can hear some gurgling from evap. from feron flowing. If you hear gurgling only when you close the door it's water in drain pan when you close the door air is forced down drain tube blowing air into water.
May 17, 2010 | Freezers
Weird (Pressure Release) Noise After The Door Has Been Closed
The freezer being closed up tight and so cold can create a negative pressure inside. This negative pressure will cause the door to be very hard to open and could pull the door closed too quickly. Most manufactures today use small air valves the open and release as the door is being opened and closed. They are most often found on the bottom of the door itself or sometimes in the cabinet behind the back wall.
The noise is perfectly normal, my wife says it is there to alarm her when I am eating too many ice cream bars.....
May 03, 2010 | Frigidaire 14.1 cu. ft. / 399 liter...
Ice if forming along top gasket area and side of freezer where
If we have ice on the inside of the freezer it means air is being pulled into the box somewhere. The most likely place is the door seal, it sounds like you already checked it, but I would suggest that you look very close at the bottom and aides of the seal too, it could be leaking in air from there. Check the inside liner for cracks and seal them if you find any. Look at the corners of the cabinet to make sure there is not room for air to come in.
Air leaks will lead to frost, it is just hard sometimes to find where it is leaking in.
Apr 13, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Bubbling sound coming from the bottom of my freezer
There is a vacuum build up in the freezer compartment when you close the door. This can make the door difficult to open. You can overcome this by sticking a small lollipop stick to the bottom part of the door gasket. This will act as a vacuum breaker.
Mar 06, 2009 | Whirlpool Upright Freezer EV161NZRQ
GE Upright Freezer problem/door
The door seal is damaged or the hindge alignment have allowed the warm air to enter and the cold air to leak out the of the freezer. Look and feel around the door for the cold air and check the top and bottom hinges to make sure they haven't become loose. Look for tears also around the seal because this will do the same thing. Let me know what you find. JT
Oct 23, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A Logo
124 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
