Question about Dryers
Frigidaire affinity dryer problem
Hello
I have a frigidaire affinity dryer that is 2 months past warrenty and of course it breaks now.
It spins in times dry when in noheat/air fluff mode. The manual said to replace the themostat and I told the repair guy to do that today to no avail and he said i may need a motherboard as the codes are not in the tech manual.
The codes are:
E9E
E4A
and now when I have done the test the code is coming up E68, but the repair guy did not get that code today.
Thanks SOOOOOOOO much for your help
The model number is AEQ6000ES2
  • 2 more comments
  • twistedkd81 Jun 09, 2008
    error code e4a
  • Anonymous Jul 17, 2008
    I have similar problems also. I am going to start tearing this apart to figure out what is wrong with mine. 1st error code was a E68then the unit would run for 30 seconds, then an E4A error code pops up and the unit stops running. Tech says it's a control panel and wants $600 to fix it. I don't think so, I will try to locate a control panel and replace it myself.
  • anayalopez Apr 06, 2009
    Affinity dryer stops, displays E68 and beeps.
  • Anonymous Mar 24, 2014
    error code ef2
Message "ad" showing on my affinity frigidaire, anything wrong with this?
Posted on Sep 27, 2008
I had the same problem with my Frigidaire Affinity Dryer, no heat. I took the vent off the back and let it run for 5 minutes. It started heating up. The hose for the vent was clogged. It works fine now. Check your hose and inside the dryer where the vent attaches. Unplug it first of course. Hope this helps!
Posted on Jan 01, 2011
Help[ my affinity dryer is somehow tearing /slashing rips in my clothes.
Posted on Sep 05, 2008
Inside my affinity dryer I found a service tech manual taped on the wall near the drum motor that lists fault codes. It also tells you how to go into diagnostic mode to help figure out what is wrong. On mine there is a aluminum louvered panel in the lower left looking from the back. It is held on by 2 screws. Make sure the dryer is UNpluged because the motor and belt drive are right behind this. Look inside and you may find an evelope taped to the inside wall. I am in the middle of figuring out what is wrong with mine but it is about the same age and just out of warrenttee too. I looked on www.mrfixit.com and I have no clicking sound and they are pointing to the igniter or possibly the radiant sensor. I am off to check these now. I hope this is helpful.
Posted on Jul 12, 2008
2 Suggested Answers
  • 240 Answers
SOURCE: frigidaire affinity dryer problem
the thermistor in air outlet duct is very common for these. with front panel off find plastic duct from blower at bottom. pull out thermistor and look at inner side. it has triangular shape and if you can see shiny redish color at tip instead of all black then its worn. this causes numerous heat and control issues.
Posted on Jul 04, 2009
Clean tub options keeps blinking on affinity frigidaire fafs4474lwo model
Hello Jodi, thank you for your post!
Your Frigidaire washer (FAFS4474LW0) will automatically prompt you to run the CLEAN WASHER cycle typically every 50 cycles. If you wish to begin the cycle, press SELECT when prompted. This maintenance cycle uses hot water and two rinses to remove residue that may cause odor. For best results, I recommend to use the CLEAN WASHER cycle once a month
You may press the CANCEL button to manually perform the cycle at another time if you prefer. You can do this by following these directions:
    ·Rotate cycle knob to Rinse & Spin
    ·Then press the CLEAN WASHER option button
    ·The LCD screen will display "SYSTEM CLEAN"
    Hope this helps! - Z
Jul 19, 2014 | Frigidaire Fafs4474lw Affinity 3.81 Cu Ft...
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Feb 05, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Affinity dryer burning clothes
Probably a seal around the drum or blower needs to be replaced.
Affinity service manual
Nov 24, 2012 | Frigidaire Affinity FAQG7011KW 7.0 Cu. Ft....
Frigidaire Affinity gas dryer problem
I would bet you need new door lock switch
Jul 13, 2017 | Frigidaire Dryers
I have a Frigidaire Affinity dryer that shows power but when I press start it has a humming noise and wont spin.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 01, 2010 | Frigidaire Affinity AEQ6000WH Dryer
I have an Affinity Dryer that works for the first 5 minutes, exactly, then in flashes AD. It continues to spin but not dry at that point.
Problem is going to be with the thermistor located on the blower housing at the front. You will see 2 plastic pieces with wires going to them. The thermistor is the one on the left. Cannot jump this out all you can do is change it.
Mar 10, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Mar 29, 2009 | Frigidaire AEQ6000ES Electric Dryer
Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Dryers Logo
5,408 people viewed this question
Top Dryers Experts
