Question about Kenmore 95592 / 95594 / 95595 / 95599 Electric Kitchen Range
Oven for a C970-656932 glass top range
I have a Kenmore C970-656932 glass top range stove. The oven is not heating anymore. It was working fine and automatically quit. The timer and clock screen is very dim. Can hardly see the numbers. What do I need in order to get it fix. Both elements ( top & bottom) are not heating
  • iguanajose Aug 30, 2008
    i checked for fuses oven does not work kenmore num.ser.6h286169
SOURCE:
docjohn174
  • 943 Answers
SOURCE: kenmore model c970-655632 LED Display is very dim
hi joe. thanks for the question . you replace the clock to repair your problem . i have seen this happen on a regular basis . thanks the appliance doc
Posted on Oct 05, 2008
SOURCE: Kenmore oven stopped working and clock/timer is dead
Try and knock off the oven , leave it for about 10-20 minutes then turn it back on , if its still the same go to the manufacturer or where you bought it... Hope i helped
Posted on Dec 30, 2008
  • 492 Answers
SOURCE: My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Posted on Apr 30, 2009
SOURCE: GE Spectra range
I just moved into a new apartment and my stove wasn't working properly. After reading the very helpful information posted by kd3ke, I decided to turn off the breaker to my stove, take off the back covering, and check out what was back there. I was experiencing the same problem as posted.... the burner light, oven light and clock were all working however, the burners did not get hot nor did the oven. After taking off the back panel, the cord did have just as he stated, a black, white, and red wire however the plug attatching to the stove did not have cordinating colors. It was just a grey cord with 3 copper wire heads. It seemed to me that the cord was twisted and therefore everything was backwards. Since I was relying on his post, that would explain why the stove still did have some power, just not all, because the voltagages were wrong. I flipped the three cord wires, reconnected them to the stove and then plugged it in and turned on the breaker... everything works now!!! :) I don't know if this will help anyone else since it may not be the same problem if your stove was working properly previously, but it fixed the problem for me since I had just moved in.
Posted on May 24, 2009
smartr10U
  • 1305 Answers
SOURCE: Can I replace the glass stove top on my Kenmore Range????
Yes! check at repairclinic.com you can find parts for your appliance. be sure to have your model number handy.
Posted on Jun 06, 2009
Our 6 year old Kenmore Electric Range's oven just quit working. The stove top burners work fine, the light in the oven comes on and the breakers in the main house panel are all fine. It just quit heating...
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Aug 07, 2010 | Kenmore Kitchen Ranges
The oven won't heat up anymore. It was fine and now doesnt work. The broiler works fine and stove top is fine.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 29, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
Kenmore stove not heating up anymore.
if no broil or bake work, check the thermal fuses in back. some are resetable
Feb 09, 2010 | Kitchen Ranges
Jun 06, 2009 | Kenmore Kitchen Ranges
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
Stove top works oven wont heat on 465
the ignitor needs replacing, that's the glow that you see. it's not getting hot enough to open the safety valve.
Dec 07, 2008 | Whirlpool GS460 Gas Kitchen Range
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Kenmore Stove Glass top
I have a Kenmore glass stove, not sure what the model number is I don't have it with me right now. Yesterday, the timer started to beep and F1 started to flash in the display. The stove top is working, but the oven does not. The only way I can get the timer to stop beeping is to unplug the stove.
Any suggestions as to what is going on with this stove. It's only 4 years old.
Thanks
Oct 22, 2007 | Kenmore 46123 Stainless Steel Electric...
Kenmore 95592 / 95594 / 95595 / 95599 Electric Kitchen Range Logo
269 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
