Question about Xerox DocuColor 12 Printer
Error code 9-342 at start up / docucolor 12 - Xerox DocuColor 12 Printer
  • 1 more comment
  • Anonymous Apr 24, 2008
    same happens to one Dc 12 I been servicing, already replaced the 2nd BTR assy, the 2nd Btr photointerrupter, and tha 2ND btr Clutch, still the same error
  • ahmed1990_6 Nov 06, 2008
    i have the same problem, can anyone help me
    thank you
  • mushuka Mar 28, 2010
    I have a Xerox DC 12 printer/copier with the following problem:- At start up it is bringing the error code 9-342 How do I solve this problem
Likewise I had done a major service on the BTR assembly as well as a fuser. The BTR reply to this message helped me look deeper into the problem as to why I was getting the error code. I found that it was because I had the nudged the little non-operator micro switch out of its socket. When replaced the machine worked fine.
Posted on Apr 25, 2008
    President:
  • 2,072 Answers
That is a BTR contact failure. The Bias Transfer Roller is not making proper contact.
Most likely time for the BTR assembly to be replaced.
Posted on Apr 01, 2008
Estirar los 2 springs un poco de el 2nd BTR para que tengan menos tension, limpiar y engrasar las levas de el 2nd BTR
Andrel
Posted on Nov 07, 2008
El 2nd BTR it has 2 springs estirarlos un poco para que tengan menos tension. limpiar y engrasar las 2 levas de el 2nd BTR
3 Suggested Answers
SOURCE:
pineworks
  • 4345 Answers
SOURCE: Error code 10-356
Hi
10-356 code i pws mode
remplace the fuser
Posted on Feb 10, 2010
  • 2072 Answers
SOURCE: docucolor-12 10-389 CODE
That is a fuser jam indication.
  1. Clear the Paper Jam and Obstructions in the Machine
  2. Make Sure the Paper is the Correct Size, Type, Weight, and Orientation
  3. Make Sure the Paper Supply Setting Matches the Type of Paper Loaded in the Paper Tray
  4. Load the Paper Trays Correctly
  5. Fan the Paper, Turn the Paper Over and Reload the Tray
If the above are all correct, you may just have a small piece of paper stuck on a sensor. Just has to be a small piece of paper directly on one of those. Also see if a sensor flag is dislodged. A sensor may be bad but not likely
Posted on Mar 12, 2008
Error code 9 343
Error code 9 343 - Xerox DocuColor 12 Printer
Jan 08, 2014 | Xerox DocuColor 12 Printer
Error code 10-356
Hi
remplace the fuser
Feb 09, 2010 | Xerox DocuColor 12 Printer
Xerox dc 12 error code 9-357
9-357 Black Toner Dispenser Broken.
Dec 19, 2009 | Xerox DocuColor 12 Color Copier
Error Code 10-399
Hello sir; The problem you have can be reset, just follow the steps as below;
1, power on the machine.
2, while hold down the 0 key, press start.
3, enter the access number 6789
4, click onNVM reset/NVM initialization.
5, enter 777-018 press start.
if still have problem let me know
Jan 02, 2009 | Xerox DocuColor 12 Color Copier
Error code 10-355
That is a magenta toner empty message, either the magenta is empty of there is an issue with the magenta toner dispencing.
Dec 29, 2008 | Xerox DocuColor 12 Color Copier
Xerox dc12 error code 9-378
9-378 Drum Cartridge count expired (40K)
Aug 12, 2008 | Xerox DocuColor 12 Printer
Error code 10-162 docucolor 12
I honestly can't find that code in the documentation or I would have sent it to you.
Apr 03, 2008 | Xerox DocuColor 12 Color Copier
Solving problem of system error
That is a contact issue with the BTR roller..
Mar 18, 2008 | Xerox DocuColor 12 Color Copier
Docucolor 12
como puedo limpiar el area caliente de la maquina ya que no se como desarmarla me pueden ayudar gracias
Mar 05, 2008 | Xerox DocuColor 12 Printer
Error code 14-372 after power on
Chain 14 has to do with the scanner not passing self test, not comming to ready.
CCD Module, exposure lamp or one of the scanner baords.
Jan 03, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Printer Logo
2,105 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
